#1 |
How can I tell if my rover 416I 1996 has ABS it has brake disks all round but no ABS kicks in there is also a multi plug which is not connected it is nnear the internal fuse box above the drivers footwell I cant see where it plugs in
Has my ABS failed and been unplugged before the car was sold to me?? How else can I tell Cheers Mathew |
#2 |
Car: Rover 200 (-95)
I think there should be a light which comes on when the ignition is in the red position and goes out after a few moments - similar to an air bag warning.
#3 |
But they might have disconnected it hence the wiring plug near the fuse box
#4 |
If you take the car to a Rover dealer, they should be able to tell from the car's chassis number whether or not it should have ABS. I doubt they will charge for this, but they will if there is a fault and you want them to fix it!
#5 |
Car: Pug 205
No worries nx - the dangling connector is the diagnostic port. Should be free for a dealer tecky to plug into!
Look under the bonnet for a large alloy unit with lots of brake pipes coming from it. It's on the RHR of the engine bay as you look at the engine from the front. |
#6 |
Administrator
Spot on 'Brown'!
__________________
![]() '06 330d M Sport Auto || Evolve Switch 300PS 500ft/lb || BMW Performance Brakes || Paddleshift Retrofit || Alpine HiFi Upgrade || 6CD retrofit || BMWP Gloss Grilles || oh and a Witter detachable hidden towbar LOL |
| Bookmarks |
| Thread Tools | |
| Help,ABS | richard620gsldi | Diesel Forum! | 7 | 12-05-2008 21:43 |
| ABS or NO ABS that is the question? | dan_zr+ | MG ZR / Rover 25, 200 & Streetwise | 7 | 20-08-2007 12:39 |
| Problem - Snapped ABS Rings but NO ABS Light | Archane | MG ZR / Rover 25, 200 & Streetwise | 5 | 07-08-2007 07:55 |
| Brake Pads low, ABS Light, Abs Fault....and cruise control | lildevil | MG ZT / Rover 75 | 4 | 01-06-2007 08:47 |
| I have an ABS light on my dash, but I don't think I have ABS. | Stiff | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 18 | 13-04-2007 11:51 |
