#1 |
Administrator
As always, DO NOT ATTEMPT this work if you are not competant with the spanners.
Anyway, here goes....a brief how to..... Take wheel off.... ![]() Beat the screws which hold the disc to the hub - this loosens their grip, allowing removal. ![]() Undo screws x 2 using a large cross-head screwdriver and store safely! ![]() Slacken brake pipe union just enough to allow removal with the caliper off the car... ![]() Undo two 15mm headed bolts that secure the caliper to the carrier ![]() Prise the pads apart to allow caliper to be drawn off the disc ![]() With a large hammer, beat the old disc off the hub - these can often be very corroded. Wear goggles to protect your eyes. ![]() Remove brake disc ![]() Clean both hub and mounting surface before fitting new disc, this is important if you are to avoid brake judder in the future ![]() Fit disc, insert and tighten two screws. ![]() Make sure you have the correct caliper - they are sided. Make sure the pads are fully pushed apart. ![]() Fit the caliper, torquing the bolts up. ![]() Clean the mating surface of the hydraulic connection.... ![]() Fit the hydraulic connection - do not overtighten! Use new copper seals. ![]() Bleed brakes! ![]() Fit wheel back on.......using a torque wrench, no air tools! ![]() ![]() The finished job.......looks nice! ![]() and one happy Curgy! ![]()
__________________
![]() '06 330d M Sport Auto || Evolve Switch 300PS 500ft/lb || BMW Performance Brakes || Paddleshift Retrofit || Alpine HiFi Upgrade || 6CD retrofit || BMWP Gloss Grilles || oh and a Witter detachable hidden towbar LOL |
#2 |
Genetically Different!!
Location: Darkest Wiltshire Car: Project F2000 coming soon....
Wish i'd seen this before doing mine....my calipers are upside down!
![]() Curgy......may i recommend some pies
__________________
Out with the old....In with the new. Project 2000 coming soon Follow my progress here: http://forums.mg-rover.org/showthrea...t=292529Bucket MG/Rover models bucket seat fitting 'How To' Here: http://forums.mg-rover.org/showthrea...08#post3116708
#3 |
Administrator
Are you serious? How did you bleed them??
__________________
#4 |
Took hours and 3L of fluid, believe me - but i DID bleed them. Gonna swap them round as soon as i get the car back......
__________________
#5 |
Car: MGB
It's a shame you didn't clean up those rusty old disc's.
#6 |
Moderator
why? The journey home would have cleaned them a treat!
It was minor surface corrosion because the day curgy got them (A year ago tomorrow) it was peeing it down.... I can assure you those discs had never been used in anger before they were fitted to his car.
#7 | |
Sports Tractor
And they're still lovely and clean now!
__________________
MGF Register (Yes I'm aware I own a ZT) Webmaster & Resident Loon
james.curgenven@mgfregister.org Custom MJS Straight Through Exhaust, Decat, 20PSI Boost, MKIII Air Intake (Ducted to Front Bumper), Synergy 2, EGR Bypass, K&N Filter, 190 Brakes with Redstuff pads & Earl's Custom Stainless Braided Brake Hoses. |
#8 |
Administrator
Was it really? Blimey, so it was!! Where has that year gone, eh??
__________________
#9 |
Administrator
heh, just how many of these F/TF AP brake conversions have you done now Dave?!
__________________
F/TF Hybrid in Firefrost Red TF 135 in Anthracite with Red Interior 260? What 260? |
#10 |
I prefer to use an impact screwdriver to remove the small disk locating screws and if available I replace them.
The arrow indicates the normal rotation direction, which is more obvious than pointing the arrow upwards iin whatever location/position the caliper is. I prefer to use axle stands and(/or) put the wheel under the sill.... if something goes wrong, there's always the wheel. |
#11 |
| Bookmarks |
| Thread Tools | |
| Curgy visits the RCH - MGF - TF160 AP Brake swap | Dr Dave | Rover Car Hospital Threads | 58 | 31-10-2009 07:49 |
| Brand New MGF/ TF 160 Brake Upgrade Kit | BRG_MG | For Sale | 14 | 22-06-2009 18:39 |
| MGF Trophy/MG TF 160 AP Racing 4 Pot Brake Calipers | BRG_MG | For Sale | 9 | 18-06-2008 17:15 |
| AP 4 POT for mgf/TF | MGTF-Bugman23 | Wanted | 0 | 24-02-2008 21:13 |
| WANTED - MG TF AP brake kit | Dr Dave | Wanted | 3 | 13-08-2007 21:51 |
