Old 25-03-2007, 16:30   #1
zilla
Car: MG TF 160 Lemans Green
zilla will become famous soon enoughzilla will become famous soon enough
Replacing Faded Badges MG TF - How To
Having just replaced the front and rear badges on my MG TF160 I thought I'd make a guide as a "how to" so others can benefit
Firstly, what you will need:
1. Can of Clear Lacquer
2. Dental Floss
3. Plastic spatular or similar
4. Something to remove grease (I used t-cut)
5. Soft cloth
6. 2x new badges
Note badge part number: DAB000160 - for the TF you need two the same (both 70mm). They are reasonable at £12 each from any x-part dealer. Mine came from Rimmer Brothers.
Firstly I used the clear lacquer to build up another layer on the new badges to help stop them fading like the originals. The Halfords own lacquer cost me around £6.50 and worked a treat.
Build up as many coats as you can be fussed to add, giving a couple of light sprays each coat. Make sure you wait 10 minutes between each coat until the lacquer is touch dry. I added around 5 coats on each badge, returning to add more coats whilst i was removing the existing badges.
Next, you need to remove the old badges. Many people have said that heating the badges helps remove them, but frankly there was NO way I was getting a heat gun or hairdrier anywhere near my baby... and I actually found you just don't need it.
The easiest way was to use dental floss (I used mint out of preference...) and put this behind the badge and use a sawing motion to cut the self adhesive pad out from behind the badge. It requires a little patience, but it only took about 5 minutes to get each badge off. Just keep sawing with the floss until they basically fall off of their own accord.
TIP: If you find that the floss keeps snapping, just double it up under the badge. I found this helped a lot and speeded the process up.
The pins on the back of the badge look scary but are mearly there for positioning and are not / should not be glued.
When the badge is removed there is likely to be part of the adhesive pad left, I removed this with some rubbing of my thumb, and a nice young lady with long nails A bit of perseverance and you can peel the remainder away. There is no need for any heat, paint stripper, sand paper etc etc...
The front badge is recessed into the bumper, but all you need to do is to help the floss under the edge of the badge using the plastic spatular. It's a bit of a fiddle at first, but gets better the more you cut through.
Now just use a soft cloth and something to remove the grease. I used a tiny amount of t-cut.
When you are happy that the lacquer on the new badges has hardened enough (touch dry, or over night if you can manage that... I couldn't ) simply peel the backing from the adhesive pads they come fitted with and gently press into place.
Job's a good 'un!
Now step back and admire your shiney new badges!
zilla is offline   Reply With Quote
Old 25-03-2007, 16:33   #2
DAVIDT6DCM
Car: MGTF160
DAVIDT6DCM has a spectacular aura aboutDAVIDT6DCM has a spectacular aura about
Nice Job,and handy bit bit of info,the old badges are bad aren't they? Dave
DAVIDT6DCM is offline   Reply With Quote
Old 25-03-2007, 16:34   #3
Chris T
Moderator
Chris T's Avatar
Car: MG TF 135 Platinum Silver
Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1
Nice one!
__________________
Proud Member of the HD-HU-CGAF Club.
North Leicester MG Club: www.northleicester-mg.org.uk
Chris T is online now   Reply With Quote
Old 25-03-2007, 16:37   #4
zilla
yeah, considering the car is only sept '02 the front one was shocking and made the car look a lot older. It's got a new lease of life now
Old 25-03-2007, 16:37   #5
tf karl
tf karl's Avatar
Car: MGTF 135 MGTF 115 MG ZR Express Van
tf karl will become famous soon enough
Send a message via MSN to tf karl Send a message via Yahoo to tf karl
Nice How to...? Z ,someones had a busy weekend
__________________
tf karl is offline   Reply With Quote
Old 25-03-2007, 16:39   #6
zilla
yep all good fun tho. Start small and then work up.... so a milltek exhaust, vader induction and lowered springs next weekend
also, get the diy stuff out the way whilst it's cold, 'cos lets face it, when it's warm I'll be driving it
Old 25-03-2007, 16:54   #7
Herbie
Werder Supporter
Herbie's Avatar
Car: MGF 1.8i & MGTF 1:18
Herbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these parts
Send a message via MSN to Herbie Send a message via Skype™ to Herbie
Good work Zilla
__________________
Stephan Hebert
MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ
Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling
Herbie is offline   Reply With Quote
Old 25-03-2007, 17:20   #8
Tim.
MGs on Track
Tim.'s Avatar
Car: MGF Trophy 160, MG ZS180
Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.
Good Job
Tim. is online now   Reply With Quote
Old 25-03-2007, 18:03   #9
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
excellent stuff do you mind if I link to this zilla ??
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 25-03-2007, 18:05   #10
iaross
Car: 99 MGF & 04 TF
iaross has a spectacular aura aboutiaross has a spectacular aura about
Thats brill.
Link pete! Add to your website.
Iain
iaross is offline   Reply With Quote
Old 25-03-2007, 19:19   #11
GazSuttonUK
Car: MG TF + MG ZR + MG BGT
GazSuttonUK is just really nice. AwwGazSuttonUK is just really nice. AwwGazSuttonUK is just really nice. AwwGazSuttonUK is just really nice. Aww
If you do fit 'Lowered Springs', a 'How to' would be very useful.
GazSuttonUK is offline   Reply With Quote
Old 25-03-2007, 19:23   #12
Pip
Car: MG TF
Pip is up and running. Hey we all have to start somewhere.
Send a message via MSN to Pip
Badges - another job on my to-do list. Last one I bought (for the centre cubby) only cost £6 though
Glad to see it's a doddle to change. Has anyone had new ones fitted long enough to determine whether lacquering actually helps?
Pip is offline   Reply With Quote
Old 25-03-2007, 19:32   #13
Petevick
regained interest
Petevick's Avatar
Originally Posted by Pip View Post
.....Has anyone had new ones fitted long enough to determine whether lacquering actually helps?
I have, can't remember when I did it, must be well over a year, and they still look as good as new *touches wood*
__________________
Old 25-03-2007, 21:01   #14
Yigit
MGF Istanbul Branch
Yigit's Avatar
Car: MGF
Yigit is starting to get known about hereYigit is starting to get known about hereYigit is starting to get known about hereYigit is starting to get known about here
Very nice Zilla. I love the TF badges.
Yigit is offline   Reply With Quote
Old 25-03-2007, 21:30   #15
zilla
not at all! It's there to help people so just go for it
Old 25-03-2007, 21:58   #16
Paula
Green Goddess
Paula's Avatar
Car: MG TF 80th Anniversary LE
Paula is a splendid one to beholdPaula is a splendid one to beholdPaula is a splendid one to beholdPaula is a splendid one to beholdPaula is a splendid one to beholdPaula is a splendid one to behold
Send a message via MSN to Paula
Why do some badges go manky and some dont? Mine are still in perfect condition, i check them every time i wash the car just in case.
__________________
80th Anniversary LE Goodwood Green#1469 MGFRegister Membership Secretary & Vice-Chair
members@mgfregister.org
Paula is offline   Reply With Quote
Old 25-03-2007, 22:01   #17
Chris T
Moderator
Chris T's Avatar
Your car spends a lot of it's time in the garage.
__________________
Old 25-03-2007, 22:02   #18
Paula
Green Goddess
Paula's Avatar
__________________
Old 25-03-2007, 22:06   #19
Emily
Car: Renaultsport Clio 197 & Renaultsport Clio 172
Emily is starting to get known about hereEmily is starting to get known about hereEmily is starting to get known about hereEmily is starting to get known about here
Send a message via Yahoo to Emily
Thats a great 'How To'. I've just bought a new badge for mine, and i wasnt sure how i was going to take the old one off and put the new one on, so i'll be using your guide now. Thanks!
Emily is offline   Reply With Quote
Old 26-03-2007, 10:37   #20
Catweazle
Car: MG TF 160g (Special Edition of 1) and Lexus RX300
Catweazle is a glorious beacon of lightCatweazle is a glorious beacon of lightCatweazle is a glorious beacon of lightCatweazle is a glorious beacon of lightCatweazle is a glorious beacon of light
Send a message via MSN to Catweazle Send a message via Skype™ to Catweazle
New badges just added to my shopping list...with that sort of How To...I am confident even I will be able to do it.
Thanks Zilla, this buffoon is learning...little steps but everything helps...
Catweazle is offline   Reply With Quote
Tags
f/tf how to, how to
You may not post replies
help with faded badges sash MGF and MGTF (Sponsored by MG Rover Parts Ltd) 19 03-09-2008 22:11
Replacing MG Badges on Mk1 ZR Darren199 MG ZR / Rover 25, 200 & Streetwise 3 04-01-2008 05:44
badges of tattiness (needs to be a tf) Deano MGF and MGTF (Sponsored by MG Rover Parts Ltd) 30 24-08-2007 12:40
Replacing emblem - MG TF agrasso MGF and MGTF (Sponsored by MG Rover Parts Ltd) 1 14-05-2007 21:48
Replacing badges Tonyrec MGF and MGTF (Sponsored by MG Rover Parts Ltd) 36 19-07-2006 21:31
Terms and conditions of use
