rear windscreen washer not working - MG-Rover.org Forums
Old 25-04-2007, 07:58   #1
shocka144
a minor annoyance on my "to-do" list
the front windscreen wash works fine but when i try to do the back all i can hear is the pump, no water comes out. i reckon theres a trap somewhere :P
any advice?
shocka144 is offline   Reply With Quote Quick reply to this message
Old 25-04-2007, 08:11   #2
coopsman1
Car: MG ZS
remove the boot trim to expose the washer motor,
more than likely your tubing to the motor has popped out, also put a pin down the jet nozzle to see if there is anything blocking it.
coopsman1 is offline   Reply With Quote Quick reply to this message
Old 25-04-2007, 08:15   #3
stu1982
Car: Rover 25
On my R25 i find that the one way valve behind the boot trim keeps blocking! Its managed to block itself again at the mo, i just spray it with some WD40 to loosen any dirt but am thinking i might remove it all together!
Stu
stu1982 is offline   Reply With Quote Quick reply to this message
Old 25-04-2007, 08:22   #4
mattshaw
Car: Pug 307 :(
Send a message via MSN to mattshaw
No need to go to this effort straight away..... first, pull back the black plastic sleeves between the top of the boot lid & the roof. This is where all the wiring (RHS on a R200) & water pipes (LHS R200) go. More often than not, the constant opening & closing of your boot has weaken the tube that runs through this section & cracked it. Simply repair this & youll be back on your way
(if this doesnt work, then go for the method mention by coopsman1, very similar but more uncommon )
mattshaw is offline   Reply With Quote Quick reply to this message
Old 25-04-2007, 10:25   #5
shocka144
cheers guys, what does the boot lid look like and how do i go about removing it?
as u can see i know nothing bout cars :P
Old 25-04-2007, 18:54   #6
214 no 1
Car: 214Si 16v '97 ; 2003 Peugeot 807 2.2HDi Exec
Send a message via Skype™ to 214 no 1
The "Boot Lid" is the door you pull up to gain access to the "Boot" , where your spare wheel etc lives. With this lifted up you will see two, black, rubber tubes going from the car body into the boot lid. The one on the left next to the hinge is the one that has the washer pipe in it.
HTH
214 no 1 is offline   Reply With Quote Quick reply to this message
Old 26-04-2007, 09:05   #7
egglington
Car: Mg ZR 120
I had the blockage problem recently on my ZR, it turns out the screenwash had caused the problem, it must have gone off or something and clogged up the pipes. It seems to have gradually freed itself up, but now my rear jets need lining up as i tried the pin treatment first off, they either don't spray far enough up the screen or past it, i just can't seem to get them right...
egglington is offline   Reply With Quote Quick reply to this message
Old 26-04-2007, 09:08   #8
gotenks1321
Car: TT MGF #0002
Send a message via MSN to gotenks1321
How do you line them up? Mine are out at the moment as well. Do you just stick a pin in them and move them like that?
gotenks1321 is offline   Reply With Quote Quick reply to this message
Old 26-04-2007, 15:26   #9
shocka144
found the rubber tube was able to expose the blue pipe but it looked bone dry
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Rear Washer Working Too Well?! Joe-ZR MG ZR / Rover 25, 200 & Streetwise 5 13-05-2008 00:47
Rear windscreen washer Thorpy1987 MG ZR / Rover 25, 200 & Streetwise 4 05-04-2008 22:42
Rear windscreen washer parkes1978 MG ZR / Rover 25, 200 & Streetwise 3 04-02-2007 12:58
Rover 214 rear windscreen washer alek Others 3 16-11-2005 15:24
mk3 200 rear windscreen washer not workin projectgaz MG ZR / Rover 25, 200 & Streetwise 1 01-07-2005 18:26
