Bonnet catch problem solved - MG-Rover.org Forums
Old 22-05-2007, 07:52   #1
Wrenchitandsee
Car: Rover 400 (-95)
Smile Bonnet catch problem solved
Thought that I'd post this in case it helps anyone else.
My wife has a Rover 416 . Ever since she's had it, she's had trouble with the bonnet catch not engaging. So yesterday, I thought I'd get to the bottom of it.
Took off the whole catch, sprayed it with degreaser, and stiff brushed it, did it again till it was lovely and new looking, and then regreased it and replaced it on the car.
Gently lowered the bonnet, and it STILL wouldn't lock into place.
I was sure that the mechanism itself was OK, and it was really baffling me.
Then I happened to notice that the whole strut holding the bonnet lock was
bent inwards and as a result, the catch was not sitting vertically. This surely explained why it could not engage. Obviously not sure whether it should be like that or not, I nevertheless decided to pull it straight, as I was running out of other ideas.
Cut about a yard of rope, and got it round the strut, and with a couple of good pulls it was vertical again, and GREAT, the bonnet now opens and closes, just like new.
Be careful if you do this, that you don't lever anything against the front of the radiator whilst straightening the strut. That's why I decided to use rope.
Hope it helps someone anyway.
Wrenchitandsee is offline   Reply With Quote
Old 22-05-2007, 15:08   #2
Xorro
Car: Mazda3 MPS
Send a message via MSN to Xorro
Mmm, I might have a look at that. My ZS is a PITA to shut, I normally have to drop it (eek!) from a great height to get it to latch properly.
Xorro is offline   Reply With Quote
Old 22-05-2007, 19:33   #3
Wrenchitandsee
Smile bonnet catch problem
Yes. I'm almost certain that it was the constant slamming that had caused the problem in the first place.
Having said that, until I worked out the reason, it was the only way to shut it.
Anyway. If it sorts your problem too, that's great. Good luck.
Old 22-05-2007, 21:00   #4
patpending
MG3 in ? weeks!
patpending's Avatar
Car: ZS 180 Mk2 FireFrost Hatch
On both the Mk1 and Mk2 ZS, the bonnet catch could have been designed for the Audi A2 - the car whose engine says "there's nothing to see here. Now move along."
When I bought my brand new Mk1, I broke my 2-hour journey home by stopping at a motorway service station. "I'll just have a look under the bonnet" I thought.
I didn't feel quite so cool when I had been struggling for 5 minutes to open it!
__________________
MG. A well fly set of wheels, bro.
patpending is offline   Reply With Quote
You may not post replies
Bonnet Catch MAH54 MGF and MGTF (Sponsored by MGF Mania) 2 02-09-2008 21:33
bonnet catch Rossyboy99 MG ZR / Rover 25, 200 & Streetwise 0 23-05-2008 16:15
Sticky bonnet lock-problem solved slammer MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 24-02-2008 10:54
Airbag Light--Bonett Catch Etc Etc SOLVED WITH YOUR HELP :) northstand MG ZT / Rover 75 (Sponsored by Rimmer Bros) 10 28-12-2006 00:02
Bonnet Catch................. CJZR105+ Others 0 13-05-2003 10:44
