oh yes, i'm another - MG-Rover.org Forums
Old 13-06-2007, 20:35   #1
ax50
Car: Rover 45
oh yes, i'm another
ive got a x reg 1.4k 45 which im certain is suffering from signs of head gasket failure (increased steam from exhaust, falling coolant levels, mayo gunk in expansion tank). just wondered if there is a strengthened or improved head gasket for the 1.4? or am i in for repetative failure?
any help would be great, rich.
ax50 is offline   Reply With Quote
Old 13-06-2007, 20:57   #2
markus250
Car: Car less for now - but driving the GF's ZR!!!
Send a message via MSN to markus250
Not another with head gasket failure!
OK. The head gasket you want is the Landrover one that looks like this:
That is a much better design and should help prevent the problem happening again! There is also a shim that goes on top of the head gasket itself:
The first picture also shows a redesigned oil rail which is what the head bolts go into and its designed to strengthen everything and lessen any movement of the head.
The gasket can be used without the improved oil rail though but thought i'd mention it.
As far as i'm aware, the gasket is the same for the 1.4, 1.6 and 1.8 k series engines.
Others here may know more than me but its a start for you!
Mark
PS I'm stealing your pictures again dr dave!!!
markus250 is offline   Reply With Quote
Old 14-06-2007, 09:02   #3
Rick420Di
Car: 25 2.0 IL Turbo Diesel
I take it diesels dont have this problem?
Rick420Di is offline   Reply With Quote
Old 14-06-2007, 09:15   #4
Mr Flibble
Your right,
They have the L series engine that is solid!
I need to get a diesel!!
Mr Flibble is offline   Reply With Quote
Old 14-06-2007, 16:47   #5
ax50
Car: Rover 45
Unhappy
cheers markus, and great having pictures to look at.
any idea of best place to buy one?
(let one thing go on a car, before you know it there are 50 things that need doing/replaced)
Old 14-06-2007, 18:19   #6
markus250
Not sure on prices but its made by landrover so i guess they sell it! You need to tell them its the newest designed head gasket thats for the k-series engine. Its used on the landrover freelander 1.8. The gasket is the same for all k series engines (1.4, 1.6 and 1.8).
May be costly from them but at least its the proper one!
Mark
Old 14-06-2007, 22:26   #7
Bob-T
Car: now an A3 tdi
Its a Landrover part so will be peanuts
Bob-T is offline   Reply With Quote
Old 19-06-2007, 21:50   #8
dread
Car: Rover 400 (95-99)
yeah also make sure when you get the job done that they skim the head this is very important otherwias you may have a repeat porformance not good!!!
dread is offline   Reply With Quote
Old 19-06-2007, 22:37   #9
Carliooo
Car: Rover 25
You only get the head skimmed if its warped surely?!
If you have caught the head gasket quick enough and it hasnt overheated it shouldnt need skimming..
Carliooo is offline   Reply With Quote
You may not post replies
