speed sensor removel - MG-Rover.org Forums
Old 28-06-2007, 12:21   #1
steven young
Car: MG ZS
speedo still not working ,took to garage and told sensor is faulty but they tried to get one and cant get anywhere so ill need to go to breakers and get one but cant remove the old ,i ve teken off the wire and the black connecter its fitted to but cant remove the remove the actual sensor.
can anyone help ive posted a picture of it below
http://stevenyoung69.blogspot.com/20...r-removel.html
steven young is offline   Reply With Quote
Old 28-06-2007, 17:51   #2
Matt MGZS
Car: MG ZS 120
Send a message via AIM to Matt MGZS Send a message via MSN to Matt MGZS
What garage did you go to? did you try a xpart garge?
Matt MGZS is offline   Reply With Quote
Old 30-06-2007, 02:52   #3
catcha
Car: Rover 45
The black bit you have already unthreaded is the sensor !!
The other white bit you are looking at in the gearbox is the drive and it just has the cog underneath it .
Its unlikely to be the drive thats at fault so really unless you really want to check the cog in the gearbox you can just replace the bolt youve taken out of that and leave it.
The Black bit in your picture is the actual transducer / sensor and its this that you need to change , but sometines its either just the earth that goes to a connector under the gearbox thats coroded or loose .
It could also just be the connector iffy on the topo of the transducer , clean it with some wd40 .
Inside the trandsducer you will / should see a black matchstick sized piece of plastic that fits into the drive as a cable would do , this spins the magnet inside working the sensor - it is sometimes these that snap.
I have a spare working tranducer somewhere if you realy are struggling to find one , never needed it in the end and you could have it for cost (£10.00) think there way over that from rover , I also have a spare drive & speedo , its a long story LOL .
Best of luck - try cleaning it all up and check the connectors and especially any loose earth leads surprisig how easy rain water gets in these , mines now all siliconed up ; ).
catcha is offline   Reply With Quote
Old 30-06-2007, 12:22   #4
steven young
Car: MG ZS
ill have a look at it and let you know if i need the one you ve got
cheers
Old 01-07-2007, 10:33   #5
steven young
Car: MG ZS
looked at it today and as you said catcha the match like bit in the middle had broken ,got one out the breakers yard of a rover 45 and it works fine now.
thanks
Old 02-07-2007, 04:34   #6
catcha
Car: Rover 45
Glad you got sorted , seems to be a common problem
You may not post replies
speed sensor fourstrings MG ZR / Rover 25, 200 & Streetwise 1 06-04-2008 13:19
speed sensor fourstrings MG ZR / Rover 25, 200 & Streetwise 1 13-03-2008 17:06
Speed Sensor simon-g MGF and MGTF (Sponsored by MGF Mania) 2 16-07-2007 17:09
Speed sensor testweight MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 04-04-2006 08:35
speed sensor korabetsni Others 3 30-11-2004 20:52
