Alpine Sub woofer fitting - How to - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > MGF and MGTF (Sponsored by MGF Mania)
Old 30-07-2007, 20:26   #1
CJJ
CJJ's Avatar
Car: MGTF 160, TF LE500, Focus ST2, KTM 640, Kangoo Van, Freelander
Well, there are several places you can mount this sub, behind the passenger seat or maybe even in the passenger footwell, but both mean that you will lose either some travel on the seat or some leg room.
So, I decided to mount mine behind the armrest. This means that I lose a small storage space, but to be honest, I never really used it as it was insecure and things tended to fall out when you opened it.
The first thing I did was make a template for any trimming that I needed to do.
The main reason for this was I was going to fit the sub below the drivers seat. It was a close fit with the sub on the carpet, so I thought if I made a cut out for it to sit in then it would just fit. But it didn't
Be very carful before you get busy with the Stanley knife, as you can see here, there is often cables lurking behind carpet and soundproofing. Check before you hack.
As this didn't work, I replaced the carpet cutout and sought a new hiding place for the sub. After a while of placing it here and there I decided to try and fit it behind the arm rest.
I removed the T-bar cover and rear part of the cubby and I cut out enough of the carpet and soundproofing to give a bit more clearance.
I then placed the sub in position and closed the arm rest to see if it was feasable. It wasn't a perfect fit but was close enough that I knew a bit of trimming would sort it.
I then fitted some Dynamat, as a tribute to Lucky. Actually, it was just to replace the soundproofing that I had cut out. I didn't want to hear the engine above the sub.
I then secured the sub into it's final resting place with some heavy duty velcro sheets.
And then offered the plastic housing of the cubby box up so that I could mark it and trim it to shape. I trimmed a chunk of each side and trimmed out the main storage part of the box. The smaller storage space has remained. The photo was taken before I cleaned it up with a file. I also trimmed a small amount off the back of the centre tunnel. Just behind where the arm rest screws on.
The cubby box was then screwed back in place over the sub. The wires were fed down the drivers side of the tunnel and connected to the head unit. Here you can see the blue/white remote cable (switches the sub on when the head unit is switched on) and the phono connections.
__________________
How do you get 2 wales in a TF?
CJJ is offline   Reply With Quote
Old 30-07-2007, 20:38   #2
CJJ
CJJ's Avatar
It looks a little untidy, but that is the nature of wiring. We will tidy that later. You could always just stuff it into the cubby box and close it.
The black earth cable was attached to a chassis bolt under the dash. Any good chassis point will do.
The yellow power cable was fed along the tunnel, over to the passenger side, up behind the glove compartment and out through an unused gromet.
The cable was then attached directly to the battery possitive. If you do this, always fit a fuse as close to the battery as possible to protect against fire.
And now we tidy the wiring using cable ties and sticky back cable tie mountings.
Replace the cubby box and ash tray and all looks normal. Sorted.
As I said, this is where I decided to fit it but it is personal taste.
__________________
Old 30-07-2007, 20:41   #3
Chris T
Moderator
Chris T's Avatar
Car: MG TF 135 Platinum Silver
Superb write up as ever
__________________
Proud Member of the HD-HU-CGAF Club.
North Leicester MG Club: www.northleicester-mg.org.uk
Chris T is online now   Reply With Quote
Old 30-07-2007, 20:45   #4
CJJ
CJJ's Avatar
We aim to please.
__________________
Old 30-07-2007, 20:46   #5
Fast Jan
SWish
Fast Jan's Avatar
Car: TF160 + Freelander
CJJ that is absolutely fan-bleedin-tastic
__________________
** New F/TF Community Map ** - add yourself HERE
Fast Jan is offline   Reply With Quote
Old 30-07-2007, 20:51   #6
CJJ
CJJ's Avatar
Cheers.
Forgot to mention that I had to cut a litle out of the cup holders to give clearance for the arm rest to close properly. You can see it in the second from last pic.
__________________
Old 30-07-2007, 21:09   #7
My-Old-Flame
Car: MGF vvc / ZR TD se
Does it not make the cubby vibrate a bit at volume ?
It's certainly a good idea , funny enough i was looking at there very unit today, i just ordered a new alpine head and thought that sub might work well.
I'll be interested to hear your honest thoughts after a week or so's use..
Stu
My-Old-Flame is offline   Reply With Quote
Old 30-07-2007, 21:17   #8
CJJ
CJJ's Avatar
No rattling at all, and, as my wife will tell you, I tend to play music load when on the move. We sat in the car on the drive, with the engine off, and playing fairly loud and it didn't vibrate at all. The complete sound in my car is now superb. I am not saying it is up there with £5k professional installs, or even a spotty yoofs tricked up corsa, before anybody starts the "mine is better than yours" or "Amps is the way to go", but I think it sounds brilliant. I would recommend it to anyone who wants a sub and doesn't want to lose there boot or leg room.
__________________
Old 30-07-2007, 21:21   #9
My-Old-Flame
I've got to change the t bar to a mk2 as i have no rears at the mo anyway but i like that idea... nice one, that cubby is bloomin u/s anyway..
Trouble is i also got to cut wholes in the t new t bar for the roll hoops and then there the harnesses.... a winter project i think
Good photos as well ... nice one
Stu
Old 31-07-2007, 08:06   #10
Yigit
Car: MGF
Very nice work there CJJ, it is a creative idea to put the sub there, i am surprised that it does not rattle but a very good job. Your post is rich as usual with the photos
Yigit is offline   Reply With Quote
Old 31-07-2007, 09:43   #11
wildmurphy
Car: MGF 2000MY VVC!
Send a message via MSN to wildmurphy
have some rep mate, i think i may follow your lead with this, get the sub closer to my heed!!
Nice one!
wildmurphy is offline   Reply With Quote
Old 31-07-2007, 20:17   #12
CJJ
CJJ's Avatar
I must admit that I thought vibration might be a problem, but it isn't. Must be the superb MG build quality.
__________________
Old 29-12-2007, 17:48   #13
X-P0WER
Car: MG TF
Send a message via MSN to X-P0WER
lol @ cjj and mg build quality. I love my mgs but the build quality has something about it. Charachter i think. :-)
Anyway, great write up. Glad someones done it. Coz i jus bought one of them subs. In my zs180 mk2 i had 2 12 inch fusion subs, both powered by 1000 watt amps by inphase. Nice nice nice. But that was a big car. Lot of air to move.
I think il be putting my subs behind the seats. 1 behind each seat will do i think. Not on the floor, but standing up, if you like behind the bottom of the seat.
I like the idea of putting it where you put it, but whats the 2 brass screws holding together? Looks a bit unsightly. And i love the interior in your car. The grey velour seats are the best. :-)
Also, if anyone else is reading this and fancies putting a slim sub in their F or TF, Heres a few suggestions. I spent ages looking for these! But having a tf means very little space to put a sub.
Pioneer TS-WX11A *TSWX11A
Pioneer TS-WX22A *TSWX22A
Kenwood KSC-WA62RC
Kenwood ksc-8w1
Alpine SWD-1600
Blaupunkt THb 200A
Clarion SRV303
X-P0WER is offline   Reply With Quote
Old 29-12-2007, 18:33   #14
CJJ
CJJ's Avatar
Ah, character, that's the word I was looking for.
Putting the subs behind the seats is popular, but you do lose some seat adjustment and legroom, something I wasn't prepared to do.
How very dare you criticise my custom made highly polished wood screws. . These are actually nothing to do with the sub install. I did this before, as I was sick of the stupid plastic fixings on the T-bar breaking, and the squeaking of the cover while driving. So I snapped all the plastic fixings off and screwed the git in place. I need to do it a bit more professionaly when summer comes around.
__________________
Old 29-12-2007, 18:56   #15
Red_Devil
VROOOOOOOOOOOOM
Car: MGTF 135
I thought this too until recentely. If you stand it on its end I dont think you lose any legroom whatsoever.
Red_Devil is offline   Reply With Quote
Old 29-12-2007, 19:29   #16
X-P0WER
Car: MG TF
Smile
Yes this is true. I practiced by placing an object behind me seat, of the same dimensions as one of these subs, (i used a my 3 year old cousin mike) haha. And i had no problem with leg room. However, he did. Lol
Old 23-10-2008, 18:00   #17
X-P0WER
Car: MG TF
bump. Just going through all my old posts and noticed i hadnt updated this thread. If anyone does read this then heres where i put my sub.
Behind the seats. Ive not lost any leg room (im 6 foot) and my seats never been right up against the wall!
It sounds good. By the way, i put a sheet of 2mm ply behind the carpet to screw the subs into. :-)
Old 23-10-2008, 18:13   #18
CJJ
CJJ's Avatar
Chicken
__________________
Old 24-10-2008, 03:38   #19
X-P0WER
Car: MG TF
Well i didn wana go screwin through my firewall now did i. ;-)
Old 24-10-2008, 15:31   #20
darrelbmad
Car: MG TF 160 Trophy Blue
What speakers do you have on your rear T-bar? mine are 5 x 7's did you modify your T bar to fit them in?
darrelbmad is offline   Reply With Quote
You may not post replies
Alpine Cd Changer Fitting mwillo67 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 27-02-2007 09:52
Fitting Alpine Radio JOAN&GERRY MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 19-02-2007 15:29
fitting an Alpine CHA-S634 in a Hi-line Keith Alexander MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 19-01-2006 21:12
Fitting Alpine Head unit and CD changer ? rovea400si Others 7 15-05-2005 09:38
Fitting an /////Alpine Head unit Dark_Helmet In-Car Audio, Entertainment, Sat Nav etc... 13 09-09-2003 17:11
