rear brake pad ware? - MG-Rover.org Forums
Old 09-08-2007, 19:28   #1
diablo s
Car: MG TF
had the car service and they told me the back pads are 70% worn and they need changing. am I right in thinking that if the car has done 25000 miles and had 70% ware. 30% of 25000 miles is 7500 miles so I have around 7000ish miles till then need changing? I have had a look and they look ok????????????
diablo s is offline   Reply With Quote Quick reply to this message
Old 09-08-2007, 19:53   #2
MG-BOY
Car: 1998 MGF 1.8i mpi
I would suggest you get them changed just to be on the safe side, it's very cheap and easy, perhaps you could do it yourself, or I would be happy to do it for you if you are local?
MG-BOY is offline   Reply With Quote Quick reply to this message
Old 09-08-2007, 19:57   #3
Tim.
Tim.'s Avatar
Car: MGF Trophy 160, MG ZS180
The minimum pad thickness is 3mm. However, depending on type, they do occasionaly tend to crumble and break away as they get thinner. If this happens its new disks as well.
Tim. is offline   Reply With Quote Quick reply to this message
Old 09-08-2007, 20:34   #4
smbMG
Car: MG TF 135
the general concsensus is to change the pads at 5mm thickness to avoid any defficiences in braking performance, so get your ruler out with the wheel off!!
and have a crack yourself at changing pads if the disks are ok, plenty of howto's on here so you'd be surprised how easy it is. just takes a little time and effort!
smbMG is offline   Reply With Quote Quick reply to this message
Old 09-08-2007, 23:05   #5
Chris T
Administrator
Chris T's Avatar
Car: MG TF 135 Platinum Silver, Skoda Roomster
The other thing to watch is that on the rear the inner pad ware rate is much higher then the outer pads.
__________________
Proud Member of the HD-HU-CGAF Club.
North Leicester MG Club: www.northleicester-mg.org.uk
Chris T is offline   Reply With Quote Quick reply to this message
Rear Brake Pad Clips DJMARK MGF and MGTF (Sponsored by MGFnTFBITZ) 6 04-02-2008 11:10
R200 VI rear brake pad fitting vidriver MG ZR / Rover 25, 200 & Streetwise 5 17-02-2006 12:16
MGF Rear brake pad replacement KevinKiteley MGF and MGTF (Sponsored by MGFnTFBITZ) 2 24-06-2004 10:38
Rover 400 rear brake pad change adrian williams MG ZS / Rover 45 & 400 6 05-03-2004 08:51
R25 GTi rear brake pad replacement flippy MG ZR / Rover 25, 200 & Streetwise 4 18-07-2003 18:35
