Can't open bonnet - MG-Rover.org Forums
Old 13-08-2007, 13:18   #1
mark_dubo
Car: Rover 75
Can't open bonnet
I have a problem with my bonnet release. The small lever down the right hand side of the driver is not flush and tight (like it used to be) but is loose (and has no effect when pulled). The bonnet is closed tight and I have no idea how to get it open. This happened a few months back after my last service so I took it back and they sorted it (I'm not sure what they done though). Can anyone tell me how to open the bonnet and/or what is causing this problem.
Thanks in advance
Mark
Edit: It's a Rover 75 Conn 2.0D
mark_dubo is offline   Reply With Quote Quick reply to this message
Old 13-08-2007, 14:24   #2
The Hobbit
Car: MG ZTT
Sounds like the cable has come detached from the handle.
Pull off the cover in withe the handle sits and check the mech, only takes 5 mins.
Barry
The Hobbit is offline   Reply With Quote Quick reply to this message
Old 14-08-2007, 01:34   #3
crofts
Car: Rover 75 CDTi Tourer, Conn, SE (131 PS)
Bonnet pull
For security reasons this info is usually only aval. from a moderator.
After opening bonnet :-
The common problem lies in the 'one into two junction box attached to the offside wing under the bonnet. There is a slide block that the 3 cable nipples slot into inside the casing.
Re-insert dislodged cable nipple, then make sure the slide block is replaced inside the casing with the '3 nipple side of the slider' facing the case, not the wing. Lubricate and replace.
Oh yes, the case is detached by pressing in centre, top & bottom, to release the clips that pass through holes in the wing
crofts is offline   Reply With Quote Quick reply to this message
Old 14-08-2007, 15:58   #4
clevertrevor
Car: Rover 75
Bonnet release
Hi Mark,
I've sent a private message - if you reply I can send the details.
Trevor
clevertrevor is offline   Reply With Quote Quick reply to this message
Old 26-08-2007, 10:31   #5
Caseyl
Car: Rover 75
Originally Posted by clevertrevor View Post
Hi Mark,
Trevor
Hi Trevor
New member, same car same problem can you help me also
Regards
Ken
Caseyl is offline   Reply With Quote Quick reply to this message
Old 12-12-2007, 14:49   #6
docmilsap
Car: Rover 600
Originally Posted by Caseyl View Post
Hi Trevor
Regards
Ken
Same problem for me. Rover 600 can't open bonnet, can you help....Please!
docmilsap is offline   Reply With Quote Quick reply to this message
Old 12-12-2007, 14:52   #7
felpham_ant
Car: Rover 220 Coupe, ZS180 in T/Blue, ZT190+ in Monogram Typhoon
Send a message via MSN to felpham_ant
You have to respect that it looks a bit dodgy, new members asking for details to open the bonnet!
It seems like the ZT/75 has a common problem with bonnet releases!
felpham_ant is offline   Reply With Quote Quick reply to this message
Old 12-12-2007, 20:53   #8
wilson21
Car: Rov.75cdti conn se auto. 54.
Mark, I had exactly the same problem in Aug just after I bought the 75. The pull lever was slack and the bonnet would not open.It was sugested that the front grill might have to be destroyed to gain access to the two locking plungers to release it. However with one man pushing up and down on the bonnet while I operated the lever the bonnet sprung open. the problem was the plastic housing under the bonnet where the pull cable joins the two cables that operate the locking plungers. the housing is too flexible for the job and the pull cable almost comes out of its location. I used a small bridge piece ,held on by self tapping screws, across the open U section. This made the unit more rigid and I have had no further trouble. However if you cant get the bonnet open to do the repair you may need a body shop, wilson21.
wilson21 is offline   Reply With Quote Quick reply to this message
Broken Bonnet release cable, How do you open Bonnet? Johndotcom MG ZT / Rover 75 (Sponsored by Rimmer Bros) 28 27-05-2013 23:21
How do you open the bonnet??? Jadeybabey MGF and MGTF (Sponsored by MGFnTFBITZ) 2 01-06-2006 22:05
Bonnet won't open, HELP! DZL PWR Others 5 08-01-2006 15:03
How do i open the bonnet? graham3232 Others 4 22-01-2003 13:41
