crank timing - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > 'R8' Rovers (aka Wedges!!)
Old 15-08-2007, 20:43   #1
sexycoupe
Car: Rover 200 Coupe
crank timing
to get all the pistons in line half way up the bores which position should the crank be in. IS IT pointing to tdc on the bottom cam cover OR pointing at 12 oclock.
sexycoupe is offline   Reply With Quote
Old 16-08-2007, 09:18   #2
Dan Coupe
Dan Coupe's Avatar
Car: MG F (Mk II) & Rover Streetwise
I "think" its at 12 o'clock. However, I remove the pulley that drives the PS pump and alternator belt and use the cam-belt crank pulley instead. It has two dots punched on it - line these up with the mark on the engine.
Dan Coupe is offline   Reply With Quote
Old 16-08-2007, 17:25   #3
E_T_V
Car: Maestros, 200, 600, ZTT
Which engine?
E_T_V is offline   Reply With Quote
Old 17-08-2007, 19:31   #4
rover220
Car: 95 220 SEi Turbo
Send a message via MSN to rover220
Originally Posted by E_T_V View Post
Which engine?
i think we are expected to guess
rover220 is offline   Reply With Quote
Old 18-08-2007, 16:03   #5
sexycoupe
SORRY its a k-series anyway dont worrie about that as i now know this question BUT i do have another one for you lot.
My cylinder head on the car has no casting number it just says LDF however the one i have to go on the car has a casting number witch is
LDF 10233 34mm 1.6/1.8K high port
so the question is why does the one on there not have one.
it is stamped with 2.2 and a big M JUST WONDERED WHAT THIS WAS
You may not post replies
crank sensor ti charlie Rover 600 6 06-06-2008 08:10
Can I crank it? Dave 2000 MG ZS / Rover 45 & 400 4 19-12-2007 15:25
What is a crank sensor??? readieboy6943 MG ZR / Rover 25, 200 & Streetwise 3 10-10-2006 20:34
1.8 crank into 1.6 K Tricky MG/R Modification & Tuning 2 19-03-2006 18:53
