#1 |
The futures orange
Location: Fife Scotland Car: MGF VVC 75th ANNIVERSARY & TF LE500
How to remove your instrument panel
I needed to remove my instrument panel tonight to fix a crack in the dashboard surround so thought it best to take some photos of how to remove the instruments - handy if you want to replace any dash bulbs or install chrome dial rings etc.
First thing to do is disconnect the battery, negative first followed by the positive connection then wait 10 minutes. This discharges the airbag circuit and prevents it from being activated. Next open the fuse box cover under the steering column and remove the 3 screws from the steering column cover. ![]() Next unclip the 2 halves of the column cover and remove. ![]() Now remove the 2 bottom screws and 2 top screws that hold the instrument suround panel in place ![]() ![]() ![]() lift the surround away after disconnecting the instrument light dimmer, later models will have the door mirror adjust switch to disconnect as well - ![]() Now remove the 4 screws that hold the instrument cluster in place ![]() On Mk 1 models, disconnect the cable speedometer drive, I found it best to put my arm up from the fuse box area as shown below. ![]() to release the cable, press on the plastic peg as shown and pull the cable out of the housing. ![]() Before removing the cluster, you need to unplug the various connectors shown, later models will have an additional electronic speedo connection. ![]() Now remove the instrument cluster, I found it easiest to remove from the right as shown. Be carefull that it does not catch on the electrical connections on top of the steering wheel column. ![]() Now you can replace the bulbs by twisting the bulb holders out of the cluster as numbered (1) If you want to gain access to the front of the dials, proceed to unclip the wire from the lighting pod at points (2) then unscrew to remove clips (3) and lift the lighting pod (4) away. To remove the instrument 'glass' unclip the 2 clips (5) ![]() Then turn the instruments over to release a further 2 clips (5), the glass now lifts off. ![]() As usual, reverse procedure to refit. The speedo drive cable needs to be lined up properly to click in place, just turn the cable with your fingers or pliers to get it in alignment with the square drive on the back of the speedo. |
#2 |
regained interest
excellent post
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#3 |
is trying...
Couldn't agree more Pete. Brilliant post with great pics
![]() And very handy timing too seeing as i should be getting my dash rings soon
__________________
#4 |
Very intresting read, this should be moved to "how to"
Stu |
#5 |
is trying...
But don't move it yet!! Let a few more F/TF-ers read it first as many don't look outside of this forum and it would a real shame to 'lose' it to "how to" just yet!!
__________________
#6 |
#7 |
is trying...
Yes i think that might be best
__________________
#8 |
Car: MGF
Instrument panel lights MGF
Can anyone tell me how the instrument panel, including the clock, oil guage and heater controls are actually lit? All my panel lights have suddenly failed yet the exterior lights and courtesy lights are fine. I'm guessing this is both fiddly and expensive to remedy. Thank you from a new member needing help!
#9 | |
regained interest
__________________
#10 |
Car: City Rover
anyone know if the white fascia on the instrument panel is replaceable as mine has a slight discolouration to it no idea why been like that since i bought car
cheers bowser |
#11 | |
Werder Supporter
Very nice write-up MGFmad
![]() Quote:
![]() xxx
__________________
Stephan Hebert MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling |
#12 |
The futures orange
You can get the instruments out of the housing but you would need to remove the needles to get the printed fascias out - I don't know how easy this would be. Second hand instruments are often for sale on ebay for reasonable money, if you have an electronic speedo with the digital readout, I would guess that someone who does diagnostics would be able to set the mileage on the replacement to what yours is currently at (but check first) if like me you have the analogue speedo, a replacement would always show incorrect mileage - not ideal when you come to sell, even with a genuine explaination.
#13 |
Car: City Rover
cheers ive seen some on fleabay but wasnt aware you could re calibrate them
bowser |
#14 |
I want to change my clock for one that works is it easy to get it out? i'll have a go at most things that aren't oily
#15 |
MG!
Looks great glad someone has done this! However you dont need to remove all the housing arround the stearing wheel to get to the dials, i just did this yesterday to fit a low fuel warning light from 'Technozen' (member on the forum lives on the 200/25/ZR side) just remove the 4 screews on the dial surround and then lift out, remove 4 more screews and undo the 3 plugs and your away....
Plus if anyone is interested Technozen also does a replacement resistor kit to solve any fan issues. I fitted this also yesterday and now speed one works again! I'll take a pic of the fuel warning light when i start running low of fuel.
__________________
#16 |
Agreed, it's tighter with the steering column cowl in place, but still possible.
Top posting though. Got all nostalgic for the last time i did a write up on this.
__________________
Andrew Phillips MGF Register Committee - Archivist & Registrar MGF 'Scarlet Fever' MG ZT260 'old #27' |
#17 | |
#19 |
is it neccesary to disconnect the airbag before removing the cowling to get too the bulbs?
#20 |
Werder Supporter
Not mandatory but I'd recommend to disconnect your battery and leave it for about 10 - 20 mins to get the systems discharged.
__________________
| Bookmarks |
| Thread Tools | |
| instrument panel lights | mblakeley | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 20 | 15-08-2008 17:11 |
| Upgrading the instrument panel | Musketeer | MG ZT / Rover 75 | 22 | 05-08-2008 19:56 |
| instrument panel | daz.p | Others | 2 | 08-12-2004 21:33 |
| 45 instrument panel | James Riley | MG/R Modification & Tuning | 1 | 20-08-2004 18:27 |
| Instrument Panel | johnnys149 | Others | 8 | 24-07-2002 20:36 |
