Old 26-09-2007, 20:28   #1
CJJ
Mudslinger extraordinaire
CJJ's Avatar
Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1
Repairing the central locking mechanism how to
Some of you may remember at the begining of the year I changed the passenger side door locking mechanism as it was doing the grindy, whirry thing.
I did an autopsy on it and found that a small plastic shaft had snapped off from the main housing, allowing a pawl to float free and not engage properly.
I had threatened at the time to repair it, but never really got around to it.
Well, I did an autopsy on the drivers side when I removed it yesterday and found exactly the same fault. While I was in the mood I decided to fix this one (will fix the passenger one at a later date).
The plan was to fit a new shaft to replace the snapped one. Obviously gluing the old one back in place would not last 2 minutes. I toyed with the idea of drilling though the case and fitting a rivet of the correct size, but this had its problems (could damage the plastic, would expand when rivetted in place and be too wide for the pawl). So I decided to narrow the plain shank of a screw and cut to size (8mm in length - 5mm of old shaft + 3mm depth of case). To give extra support and strength I welded a square of metal to one end.
I then drilled out the location of where the shaft used to be
I then pushed the new shaft though the casing and Araldited it to the outside of the case.
With the new shaft in place
I could refit the pawl
Reassemble the mechanism and mechanically test the levers.
All seems OK, but I will have to wait until I need a lock change again to try it out fully.
This may not be the same as all failures experienced by F/TF owners, but I have had 2 now and both have been the same. As you can see, a little hobbying and you can save yourself around £40 on ebay.
__________________
CJJ is online now   Reply With Quote
Old 26-09-2007, 20:38   #2
MGFmad
The futures orange
MGFmad's Avatar
Car: MGF VVC 75th ANNIVERSARY & TF LE500
MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.
Send a message via MSN to MGFmad
Excellent work.
__________________
TF LE500 No 27 of 500 & 75th Anniversary No 452 of 2000
MGF & TF Facebook Group
MGFmad is offline   Reply With Quote
Old 26-09-2007, 20:48   #3
Mark.L
Car: Honda S2000
Mark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant future
Good work CJJ...
Why not offer a repair on a 'Exchange' basis??.. could make you a few ££'s given the amount of 'Project Dive' solenoid failures...
Mark.L is offline   Reply With Quote
Old 26-09-2007, 20:53   #4
adamelphick
Meg is a nightfire babe!
adamelphick's Avatar
Car: 1998 MGF 1.8i Nightfire with TF Front & 1996 Amaranth F called Fleur!
adamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud of
Send a message via MSN to adamelphick
Excellent! I have to check Megs drivers side again - makes a funny noise when double locked once more! I had it apart a year ago, greased it and stuff and it was ok, maybe something else has happened now!
adamelphick is offline   Reply With Quote
Old 26-09-2007, 20:54   #5
CJJ
CJJ's Avatar
Too busy working, playing or fiddling with my toys Mark.
__________________
Old 26-09-2007, 20:58   #6
CJJ
CJJ's Avatar
If you take it apart, check that pawl. It looks OK but it is only when you "wiggle" it that you realise that it is loose and the shaft has come adrift. As I said, this may not be the same as everybodies problem, I think some people have reported stripped cogs. It is worth a check though.
__________________
Old 26-09-2007, 20:59   #7
adamelphick
will do. last time the grease had turned to hard lumps so i thought that was it, cleaned and refilled it and seemed ok, but maybe as i filled it quite full the grease just held the pawl in place maybe for a while? I'll check it tomorrow or friday i think...
Old 27-09-2007, 07:43   #8
pete l
Car: MG ZR and MG TF
pete l is a name known to allpete l is a name known to allpete l is a name known to allpete l is a name known to allpete l is a name known to allpete l is a name known to all
This is a common fault on the deadlocking door locks, probably the only fault on them. Like you say, catch it early and deal with it and you won't get stuck.
Over on the 25/ZR forum, lots of locks have failed. I've rrepaired quite a few but not quite the same way as you did. What worries me about yours is you used araldite glue, I can't see that lasting very long, not on a hot summers day anyway.
I used a round long headed bolt, M3 if I'm not mistaken, I had to drill the plastic lever slightly so the head bolt would fit, drilled the plastic casing and held the bolt in place with a locking nut on the outside of the case, loctited as well just in case.
pete l is offline   Reply With Quote
Old 27-09-2007, 18:38   #9
CJJ
CJJ's Avatar
You could be right, but the glue doesn't do anything structural, it just stops the pin sliding out. Time will tell. I did consider a bolt or screw but was worried about cracking the casing and having the pawl sitting on a threaded portion. But then again, yours is probably tested. Mine isn't.
__________________
Old 02-04-2008, 13:41   #10
SCFC_Messiah
Car: X-Power Grey MG ZR 105+
SCFC_Messiah is up and running. Hey we all have to start somewhere.
Send a message via MSN to SCFC_Messiah
Has this fix cured the problem CJJ? Or has it re-occured since?
SCFC_Messiah is offline   Reply With Quote
Old 02-04-2008, 15:35   #11
CJJ
CJJ's Avatar
I haven't fitted that unit to be honest. It is sitting as a spare in the garage waiting for the failure of the one I fitted. No reason why it shouldn't work though.
__________________
Old 02-04-2008, 16:52   #12
SCFC_Messiah
Ah, ok!
Quick question- it only makes the clunking on deadlock for me- should I replace it (or fix it) or just stop using deadlock? As the normal lock works fine, maybe theres no point in going to the hassle of changing the locks? Or will the normal lock fail after time too?
Sorry for the questions!
Old 02-04-2008, 16:56   #13
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
Ah, ok!
Do NOT use dead locking until you have replaced the unit
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 02-04-2008, 17:04   #14
Craigie TF
MGTF X-Power
Craigie TF's Avatar
Car: MGTF Cool Blue S.E.
Craigie TF is a splendid one to beholdCraigie TF is a splendid one to beholdCraigie TF is a splendid one to beholdCraigie TF is a splendid one to beholdCraigie TF is a splendid one to beholdCraigie TF is a splendid one to beholdCraigie TF is a splendid one to behold
Yes it will! As petevick says dont use deadlocking until its been replaced or the door will be jammed shut! Available on ebay cheap.
__________________
Craigie TF is offline   Reply With Quote
Old 03-04-2008, 02:18   #15
SCFC_Messiah
Oky doky guys! I will get replacements (that hopefully haven't broken as well!!!!) and use CJJs fix on my current locks in case the new ones break in the future!
Craigie- I just had a search on eBay and could only find one for a rear door!
Sorry about this lol, but two more questions:
1. It only seems to be the drivers side at fault, but should I still replace both doors? (3dr car)
2. Do the boot locks break too?
Old 03-04-2008, 05:29   #16
Petevick
regained interest
Petevick's Avatar
......Craigie- I just had a search on eBay and could only find one for a rear door! ........
either you've done a mod to beat all mods, or you don't have an F/TF..........ahh, your lost aren't you, I think you should be in the ZR section buddy
__________________
Old 03-04-2008, 14:28   #17
SCFC_Messiah
Nooo, I know where I am lol! But I was lead to believe CJJs fix will also sort out the MG ZR locks!.... Hence me being here
I just checked eBay as Craigie suggested and the only ZR locks I could find were for the 5dr rear door! (does the TF use the same motor as the ZR actually?)
Sorry, I should have made it more clear I have a ZR!
Old 03-04-2008, 16:18   #18
Craigie TF
MGTF X-Power
Craigie TF's Avatar
Their plenty of TF ones on ebay!
And no the ZR locks are not the same as the TF. look similar but are different.
__________________
Old 03-04-2008, 17:57   #19
Petevick
regained interest
Petevick's Avatar
Originally Posted by Craigie TF View Post
....And no the ZR locks are not the same as the TF. look similar but are different.
pity really, otherwise we could have raided those tin toppers and nicked their locks
__________________
Old 03-04-2008, 17:59   #20
Craigie TF
MGTF X-Power
Craigie TF's Avatar
pity really, otherwise we could have raided those tin toppers and nicked there locks
Yes was a good
__________________
Tags
f/tf how to, how to
You may not post replies
Central locking mechanism replacement how to. CJJ MGF and MGTF (Sponsored by MG Rover Parts Ltd) 23 28-07-2009 16:53
Locking mechanism on it's way out... nk8 MGF and MGTF (Sponsored by MG Rover Parts Ltd) 11 25-04-2008 12:07
03 PLATE MGTF central locking mechanism will it fit 04 plate ZR acropad MGF and MGTF (Sponsored by MG Rover Parts Ltd) 3 19-01-2008 07:49
03 PLATE MGTF central locking mechanism will it fit 04 plate ZR acropad MG ZR / Rover 25, 200 & Streetwise 1 18-01-2008 21:10
Urgent Urgent Urgent Mgtf Drivers Door Central Locking Mechanism!! cjwburley Wanted 5 26-06-2006 08:41
Terms and conditions of use
