#1 |
Grade A mentalist
HOW TO: Change your coolant temperature sensor
Most Fs , this will be the brown sensor, in later Fs and Tfs it is black.
The ECM uses engine temperature to calculate fuelling and ignition timing parameters during start up. It is also used to provide a temperature correction for fuelling and ignition timing when the engine is warming up, running normally or overheating. The ECT signal is used by the ECM to control the engine cooling fans. If the sensor fails or becomes disconnected, the ECM will use a default value which is based on values from the engine oil temperature sensor. The driver may not notice that a fault is present although a fault code will be stored in the ECM which can be retrieved using TestBook. The default value will also include operation of the cooling fans in fast mode when the engine is running. REMEMBER: DONT DO THIS WHEN COOLANT IS HOT!! 1. First, you need to remove the engine access panel (I have not covered that here). Then locate the sensor. Looking from above the engine bay, over the cylinder block, notice the coolant pipes at the rear (LHS on the photo). 2. Here is a close look. You can now easily see the sensor (black), and its even more obvious if you have a brown one 3. Remove the multiplug from the sensor. Easy on the later ones, just press the middle of the clip and then pull. I have heard the older ones are a bit more tricky? AT THIS POINT you can now check if your radiator fan works. With multiplug disconnected, start engine. Rad fan should come on immediatley if it is working OK. 4. When you remove the sensor, you WILL lose some coolant, so best to install some tissue/towels etc undserneath the sensor to catch spilled coolant 5. Now start to remove the sensor. I dont know the exact size, only that none of my sockets would fit over the connector block part, so I used an adjustable wrench. 6. Loosen the sensor A LITTLE BIT. Coolant will start to leak soon, and you need to be ready with the new sensor and a spare thumb to block the flow. Remove the sensor by hand and once clear of the hole, plug with thumb. 7. There should be a little black gasket which goes round the sensor. KEEP this and repalce over the new sensor (mine has disappeared for some reason so I need to get a new one). Simply screw in new sensor and tighten. Replace multiplug. Remove tissue/rags and then replace engine bay access cover.
__________________
![]() My MGF Site..Keys/Hydragas..HCHDC site I am not liable for any injury or damage to goods or person in response to following any advice that I may give, or recommend. Last edited by Broon; 15-06-2009 at 21:08. |
#2 |
regained interest
been busy today then Broon
......more links for me to add........
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#3 |
Grade A mentalist
I could have added , how to test your cooalnt sensor is working, and how to test your TPS etc. BUt i never took photos
__________________
![]() My MGF Site..Keys/Hydragas..HCHDC site I am not liable for any injury or damage to goods or person in response to following any advice that I may give, or recommend. |
#4 | |
Moderator
__________________
Proud Member of the HD-HU-CGAF Club. North Leicester MG Club: www.northleicester-mg.org.uk |
#5 |
Grade A mentalist
![]() I also could have added, how to poke your fingers into your water pump area to see if its leaking. Now I DID take pictures of that ![]() And it is
__________________
#6 |
Werder Supporter
Another great how-to (must spread around first Broon
)Don't be toooooooooo worried, I think changing your waterpump, cambelt etc. will sort it. Keep an eye to your expansion tank level. It's not loosing that much I guess. Thanks for the finger, luckily I just finished my chili con carne
__________________
Stephan Hebert MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling |
#7 | |
Grade A mentalist
Clearer than the Ukrainian Football Bosses next pay cheque ![]() Amazing how shiny yhe engione block can be with a bit of degresatna nd a wire brush. Now there's a challenge for a rainly day
__________________
#8 |
Werder Supporter
Yeah very shiny and deffo a good starting point to watch
![]() Mind you, I'll never clean my engine like that as no one can see it and it will be dirty again I promise
__________________
#9 |
Grade A mentalist
If I had the facilities, I am now tempted to remove the engine and clean all the alloy
__________________
#10 | |
Werder Supporter
![]() Drive, drive, drive, drive, drive, drive ...... phew I'm exhausted now ![]() But tbh I really know what you mean, once starting you can't get enough
__________________
#11 |
Grade A mentalist
:lo:
But surely a clean engine will be a healthy engine. I am getting through my "Operation NO rusty bolts". Slowly replacing all bolts/nutes etc with spanking new OEM ones whenever I replace a part. ONe day , if I keep it long enough, mycar will be all new
__________________
#12 |
Werder Supporter
That sounds good, all for the long-term maintenance of value.
I'll be doing the same: failed original parts will be swapped to better built ones (e.g. cat, zorst etc. etc.) I think you are on the right way mate, Maggie will be thankful one day, e.g. when going toplesse throught the first December rain
__________________
#13 | |
Grade A mentalist
__________________
| Bookmarks |
| Thread Tools | |
| Coolant Temperature Sensor | geodark | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 9 | 17-07-2008 09:16 |
| coolant temperature sensor | goblin | MG ZR / Rover 25, 200 & Streetwise | 2 | 23-05-2007 16:08 |
| Coolant Temperature Sensor | d.e.hill | MG ZR / Rover 25, 200 & Streetwise | 6 | 03-05-2007 23:24 |
| Coolant temperature sensor | lbroto | Rover 600 | 0 | 02-10-2006 12:52 |
| Inlet Air Temperature Sensor and Engine Coolant Temperature Sensor | matt_waterskier | General MG or Rover Related Chat | 0 | 23-05-2006 09:03 |
