#1 |
Grade A mentalist
FAO those with loud ticking
Symptoms
- loud ticking on startup - speed with engine revs - disappears after a few minutes This can be tappets caused by oil after periods of standing, but mine would come back after 15 mins or so of engine being switched off. I did an extensive search on google and it seemd as though a leaking exhaust manifold would make the ticking noise (dont ask me how). I then realised I had replaced mine around the same time as the ticking started. Anyway, I went out and found one of the bolts was only torqued to 40nM, instead of 45!!!!! A whole 5 nM!! Tightened it up, and voila, engine is as quiet as a mouse!! Wortha check folks Just have to rmeove the manifold heatshield (one 13mm bolt and two 10mm screws), then you can access the manifold bolts. Jobe done. (I also discovered there seems to be a bolt missing!!!!, but this doesnt seem to affect the ticking. Will replace as soon as I can get one. MAybe this is elading to performance issue?)
__________________
![]() My MGF Site..Keys/Hydragas..HCHDC site I am not liable for any injury or damage to goods or person in response to following any advice that I may give, or recommend. |
#2 |
pi awe bi
Spookyness, by coincidence i just popped in to check my manaul as I'd only done 4 exhaust manifold nuts and couldn't fine the 5th one. Being nosey I checked on the forum to find yer thread. Mine is missing one too!!! Centre one at top of manifold. Spooky but helpful, cheers Broon
Anyone else noticed this? gaz
__________________
Why do today what you can leave til tomorrow. |
#3 |
Grade A mentalist
MIne was the one next to the coolant sensor (number 4 in workshop manual). I am sure there was 5 when I replaced it the other month?
![]() Mjust be a manifold bolt thief travelling the country
__________________
#4 |
pi awe bi
After travelling from Aberdeen to Harrogate he must be exhausted then.
Gets coat, again
__________________
#5 |
pi awe bi
Broon, any idea how to get to the bottom bolts on the inlet manifold? am a bit stuck on that one? I wasn't looking forward to the exhaust manifold but that turned out to be a doddle
Cheers Gaz
__________________
#6 |
Hey Broon - good job you didn't sell the car in desperation. More car problems are caused by poor maintenance than poor manufacture. But it's no wonder none of us suggested that as a cure - imagine your response if we said "it's all down to you".
NOW ENJOY THE CAR. |
#7 | |
Grade A mentalist
I agree. Exhasut manifold was a sinch (cinch?)
__________________
#8 |
Inlet manifold fixings - in the past I have just used a cheap 1/4" drive socket set. I think the trick lies in getting the right length extension.
#9 | |
The futures orange
Location: Fife Scotland Car: MGF VVC 75th ANNIVERSARY & TF LE500
#10 |
Ticking due to head gasket??
That's a new one. |
#11 |
Grade A mentalist
Its not the head gasket, its the exhaust manifold gasket
__________________
#12 |
Yes, I know. My comment was for MGFmad in the post above.
#13 |
well regards to this being the ticking on my car no way if you read my thread ticking plz help i have had it checked today and was told its the hydraulic tappets that has gone maybe 1 or more so its going in to get new ones fitted along with timing belt just deciding which garage to take it too
#14 |
Grade A mentalist
Scotland site on here is dead. smot of them oved over to the ZR site due to disagreements with mods
![]() . Try joining and posting on the mgzr.co.uk site, its more active and has a large scottish contingent
__________________
![]() My MGF Site..Keys/Hydragas..HCHDC site I am not liable for any injury or damage to goods or person in response to following any advice that I may give, or recommend. Last edited by Broon; 13-11-2007 at 21:26. |
#15 |
can you get to the bolts on manifold from below the car or do you have to take engine cover off
#16 |
Grade A mentalist
Cover job I am afraid. Then remeove heatshield. Not a big thing really.
__________________
#17 |
The futures orange
I better explain my theory!
I had the oil mixing with the coolant and some mayo in the dip stick for a few weeks but as there was such a slight water loss and no overheating, I used the car for a few weeks until I had the parts together and a free weekend to replace the gasket. As time went on the ticking started and I had the theory that as water was getting into the oil, it might have found its way to the tappets and caused the ticking ![]() Maybe so or not, but after the oil change when the gasket was replaced, the ticking stopped. |
#18 |
Grade A mentalist
OK, my ticking came back over time , big style, but then I had a missing bolt on my manifold.
Got new bolts yesterday and fitted today. Quiet as a mouse. I an confirm that the loud ticking , in time with revs, dieing off after a minute or two, msotly on load, as opposed to idle, was caused by a leaking exhaust manifold. I will post ups comparative sound files before and after from today, when I can be bothered shortenign them a bit Pic below -Mmmm, shiny ![]() Whislt looking at the pic though, what is the bracket for? And does it look like someone has been welding near my manifold? ![]() IN the second pic, this was bolt no 3, under the bracket. It was unable to be tightened properly. It seems to be shorter than the rest, or rather the smooth bit in the middle seems larger? ![]() . It is also blackened, suggesting it has been leaking. New one is nice and tight (45 Nm). Wonder if this has been causing any perofrmance issues? (although it would surely affect emissions but mine was fine
__________________
![]() My MGF Site..Keys/Hydragas..HCHDC site I am not liable for any injury or damage to goods or person in response to following any advice that I may give, or recommend. Last edited by Broon; 17-11-2007 at 15:13. |
#19 |
regained interest
isn't the bracket for the heat shield ??
that stud has deffo had exhaust gasses on it from a leaking gasket, which would be detrimental to your performance......and the cars ![]() good work detective Broon
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#20 | |
Grade A mentalist
__________________
| Bookmarks |
| Thread Tools | |
| loud ticking from engine | marritt79 | MG ZR / Rover 25, 200 & Streetwise | 15 | 04-10-2009 21:15 |
| Loud ticking noise !!!! | Jamie S | 'R8' Rovers (aka Wedges!!) | 17 | 09-10-2008 17:53 |
| loud ticking noise | tommy101c | MG ZT / Rover 75 | 5 | 25-08-2008 18:29 |
| loud ticking noise | cdti_88 | MG ZR / Rover 25, 200 & Streetwise | 2 | 03-10-2007 07:30 |
| Loud ticking over | Dunc32 | MG ZR / Rover 25, 200 & Streetwise | 11 | 20-02-2005 09:28 |
