Not to sure where to put this - How to use Bradex easy start? - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > General Motoring Chat > MG / Rover Related Chat - up to 2005
Old 19-11-2007, 23:28   #1
old-boy-young
Car: Rover 100
Anyone used this before? The instructions on the back read "Spay into air intake" well what goods that going to do? also do I take off the air filter and spray up there or do I just waft it up the pipe near the head light? How does this magic stuff supposed to make the car start when the problem is the engine is to cold and damp?!
old-boy-young is offline   Reply With Quote Quick reply to this message
Old 19-11-2007, 23:31   #2
mickh
Car: Punto/saxo,others.
Send a message via MSN to mickh
No ,take the filter off first.It "primes" the engine.
mickh is offline   Reply With Quote Quick reply to this message
Old 19-11-2007, 23:43   #3
BIGGUNS
Car: FJ1100 STREET FIGHTER
As said, undo the air-box and give it a 5 second burst up the air-intake, put the can to one side and immediately attempt to start the engine, before it evaporates out of the system. Do not use while someone else is cranking the engine as a blow back could ignite the can. I use butane which is equally potentially dangerous.
Why would it work?....... when the ignition system is damp, the spark is often weak, this mixture catches easier, it's as simple as that. Then as the starter motor is no longer cranking, more current goes to the ignition system and it's able to ignite with the normal petrol/air mixture.
BIGGUNS is offline   Reply With Quote Quick reply to this message
Old 20-11-2007, 23:20   #4
Man in the Car
Car: 06 MG ZR+120
"How to use Bradex easy start?" Basically; Don't, except in dire emergencies. It is simply ether which ignites very easily, but has the drawback of drying out the cylinder liner if used frequently. With constant use, engines become addicted to it and won't start without it. Further continued use can lead to extreme difficulty in getting it started at all. Best advice is to rectify the reason for poor starting in the first place - replace the battery/get the engine tuned etc.
Man in the Car is online now   Reply With Quote Quick reply to this message
Old 20-11-2007, 23:42   #5
BIGGUNS
It's only intended for emergency use.................
MG ZT CDTi won't start without Easy Start gaznav MG ZT / Rover 75 (Sponsored by Rimmer Bros) 31 20-08-2008 22:22
420 dt will start will not start davvy1978 Diesel Forum! 3 01-04-2008 13:35
wont start easy on first start up,smoke gligur MG ZR / Rover 25, 200 & Streetwise 2 31-07-2006 09:25
indoor fan start running after several minutes after engine start vervoorm MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 24-07-2006 07:28
hundreds of illegal programs in RUN and start up? an easy way to delete? SDI200 PC Gen Chat & Help 11 25-08-2005 22:50
