#1 |
3rd Stop Light Transplant
As some of you remember my 3rd stop was almost off! only 1 led was working as you can see in the video I uplaoded today. So tonight my car electrician friend did a transplant. I got a 3rd stop that was working but cracked, so we trasnplanted my cover on that. Mission was a sucess but you should see why my old stop seized working......RUST!!!!!!!!!
#2 |
Car: MG TF
Hi Perry,
I notice you have a TF, there has been several threads on wether it is possible to remove the reflector on the high level brake light on a TF, you seem to have succeeded, was it difficult. My h/l brake light has some of the led's not working, I am hoping to replace them if it is possible to get at them without destroying the reflector. Bob |
#3 |
Hello bobt! in order to remove the 3rd brake light on the TF:
GOOD LUCK!!!! Last edited by PERRY-MGTF; 07-12-2007 at 20:03. |
#4 |
Hi Perry
I have the same problem with this brake light and intend to attack it as you describe...thanks. However you didn't say what you did to make them work! Was it just the rust that prevented them working and a little wd40 was the cure...... or did you have to replace the whole set? If replacement was made where did you purchace them? Thanks Mark |
#5 |
Hello Mark! And welcome to the forum!
I did get from a friend another working 3rd stop light but it was cracked! So I had to fit the uncracked cover from my stop light to the other one. |
#6 | |
I wonder if it is possible to clean up the faulty fitment to make it work. Must give it a try. Mark |
#7 |
#8 |
ive got a problem with my boot mounted stop-light too, basically it doesn't work at all but if i open the boot as i close the boot the light briefly illuminates so i'm thinking loose connection?
#9 |
regained interest
that will be the loom as it comes off the left (near side) hinge and enters the main loom, there WILL be a broken wire or two in there somewhere.
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#10 |
Top notch Perry!
Had some trouble pushing the black retaining clip through, even with a torch and finding it first with my finger it was almost impossible! Replacement now fitted! Thanks very much. |
| Bookmarks |
| Thread Tools | |
| 3rd brake light/ Tail Light for mgzr/25 spoiler | gordy_b | Wanted | 0 | 15-09-2008 21:40 |
| 3rd brake light | mossie | MG ZR / Rover 25, 200 & Streetwise | 7 | 03-08-2008 16:00 |
| 3rd brake light woes.... | skrib | MG ZR / Rover 25, 200 & Streetwise | 8 | 05-07-2008 09:38 |
| coupe - 3rd brake light | adamgroves | 'R8' Rovers (aka Wedges!!) | 6 | 19-10-2003 09:39 |
| 3rd stop light | fizz | Others | 1 | 05-04-2002 11:32 |
