What should the ideal "idle" rev be on my 214 Bubble 1997? - MG-Rover.org Forums
Old 02-12-2007, 20:04   #1
vjohn82
As the title suggests...
Mine is running at roughly 1500 after changing the throttle body (admittedly to a used plastic one that I suspect has the same problem as the one I had before - i.e. sticky) - I am getting an alloy one from a guy on here but wondered if I had found another problem.
vjohn82 is offline   Reply With Quote
Old 02-12-2007, 20:08   #2
afro_joe_97
Car: Currently Carless =[
iirc its between 750-900
thats what mine settles to after several minutes anyway
afro_joe_97 is offline   Reply With Quote
Old 02-12-2007, 20:10   #3
davy800
Car: Rover 211 1998
its something like 850 revs
davy800 is offline   Reply With Quote
Old 02-12-2007, 20:23   #4
ashmicro
Car: 2011 S350CDi LWB
850 RPM is what the literature says
ashmicro is offline   Reply With Quote
Old 02-12-2007, 21:29   #5
ashy
Car: Silver Stormer ZR turbo.
875 rpm +/- 50 rpm
You need to reset the stepper after fitting a new TB. Key to position 2, push fully and release accelerator 5 times, turn off then start engine.
ashy is offline   Reply With Quote
You may not post replies
1997 Rover 220 turbo diesel "someone please help me" joe584 MG ZR / Rover 25, 200 & Streetwise 7 26-02-2008 10:53
1997 Vi with "blind" Alarm simon.guna MG ZR / Rover 25, 200 & Streetwise 6 29-08-2007 11:31
Wheel Trim for 214 1997 15" compldc72 Wanted 2 01-08-2005 11:25
"Two Problems" (97 8v 214) & (92 16v spi 214) < KEVIN > Others 9 03-02-2005 22:12
1997 Rover 620 "L" series diesel Harry Flatman Rover 600 5 15-09-2003 20:04
