loss of coolant leak check - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > MGF and MGTF (Sponsored by MGF Mania)
Old 17-12-2007, 08:16   #1
Deano
Car: Lexus IS 220d
Send a message via MSN to Deano
didnt go to plan.... we opened her up, jacked her up and found no evidence to explain losing a inch a week of coolant... so will be replacing teh cap today as a matter of peace of mind..so i'll see what happens once thats been swapped.
Deano is offline   Reply With Quote
Old 17-12-2007, 09:45   #2
Broon
Car: MGF MK2 1.8i,BMW 330i
Did you look at pump (i.e. remove cambelt covers) and also did you remove the bumper and look at whole radiator for leaks/damaged areas. I had a leak at the bottom of radiator, but the coolant just collected in part of the subframe and also the bumper so never made it outside to "tell me" it was leaking.
Do you ever get a sweet hot coolant smell?
Broon is offline   Reply With Quote
Old 17-12-2007, 09:48   #3
Deano
Car: Lexus IS 220d
had a look around the water pump and surrounding area.... there are a couple of marks on the driveway, which arent oil, but am assuming its coolant as it isnt freezing... so tended to keep checks to the rear... but had a quick look at underfloor pipes and radiator and tehy all look fine.
Old 17-12-2007, 10:05   #4
pacunnin
Car: MG TF
hi, what does the sweet hot coolanty smell mean? i am losing coolant and get this smell sometimes....( hoping u iant gonna sat HGF)
pacunnin is offline   Reply With Quote
Old 17-12-2007, 10:08   #5
Broon
Probably just means it is leaking somehwere and getting burnt on the block or somehting. Maybe water pump leak, or small leak in a hose.?
I get the smell a lot when my car is acting up, especially after full throttle, but bizarrely, I am not losing coolant, well , not to any worrying level anyway
Old 17-12-2007, 10:10   #6
pacunnin
Car: MG TF
thanks, i think my water pump may be on the way out...need to get her checked..thanks
Old 17-12-2007, 10:16   #7
Broon
Doesnt mean its not HGF of course. Any coolant leak should be treated with priority
Old 17-12-2007, 11:01   #8
in1052
Car: Classic Rover
Had exactly that problem! About an inch a week. Had it completely pressure tested with no success, but found that the oil was getting very creamy. Turned out the head gasket had gone - no a very pleasant situation - quite expensive unless you want to do it yourself, including skimming.
in1052 is offline   Reply With Quote
Old 17-12-2007, 20:39   #9
MGFmad
Never forgotten
MGFmad's Avatar
Car: Astra CDX auto, Freelander TD4 & Freelander 1.8, Mini One
Send a message via MSN to MGFmad
I could smell the coolant when my hose developed a small cut last week - glad I was able to smell it as it gave a good early warning.
Just fixed it tonight - cannot get the smell of anti-freeze off my hands
__________________
Former LE500 owner
MGFmad is offline   Reply With Quote
Old 18-12-2007, 05:44   #10
Petevick
Originally Posted by MGFmad View Post
.....Just fixed it tonight - cannot get the smell of anti-freeze off my hands
thats why you should wear these -
Petevick is offline   Reply With Quote
Old 18-12-2007, 08:09   #11
Deano
Car: Lexus IS 220d
checked my oil last weekend and it looked fine.. it had the HG changed for a LR one a couple of years ago.... new cap is on, i'll keep an eye on coolant levels for the next few days with fingers tightly crossed.
Old 18-12-2007, 14:09   #12
MGFmad
Never forgotten
MGFmad's Avatar
You are right, I should, I even have a box of them just like that in the garage but usually only remember about them when my hands are dirty
__________________
Former LE500 owner
Old 18-12-2007, 23:58   #13
Broon
Get the bumper off and did you look RIGHT into the water pump?
Old 19-12-2007, 07:13   #14
Deano
Car: Lexus IS 220d
my coolant is still dropping...
there is now a big massive wet mark on the driveway, around just inside the drivers side rear wheel... it doesnt evaporate nor does it freeze over... which i am can only assume is either oil or coolant... but when i leave, its pitch black and also the same when i get home, so am unable to get a good idea what it is.
it could also potentially be a red herring..i think come the new year, it will be booked in for a pressure test.
Old 19-12-2007, 07:29   #15
Petevick
that sounds like water pump leakage to me Deano
Old 19-12-2007, 07:31   #16
Sprinter
Car: MG Motor 2011 TF135
Send a message via MSN to Sprinter
Headlights should be good enough (first thing in morning) to allow you to stick a finger in the wet patch for a sniff test. Oil & Antifreeze have quite distinctive smells.
Could be the start of a Blue Ice Incident ?
btw my sudden coolant drop hasn't been repeated yet.
Sprinter is offline   Reply With Quote
Old 19-12-2007, 08:43   #17
Deano
Car: Lexus IS 220d
i have atually searched your site petey, and can find no how to on water pump replacement... how big a job is it?
Old 19-12-2007, 08:50   #18
James C
Car: MG ZT 260 SE V8
Mine did exactly the same thing the other day, coolant dropped about half a CM or so, I topped it up and wrapped a paper towel around the cap to check and no leaks there and it's stayed up since
Could the fairly sudden drop in temperature recently have something to do with it?
James C is offline   Reply With Quote
Old 19-12-2007, 08:51   #19
James C
Cambelt off job. So fairly major.
Old 19-12-2007, 09:05   #20
Deano
Car: Lexus IS 220d
balls.... has anyone on here done it themselves or is it off to techspeed job?
You may not post replies
Coolant leak - rad or coolant pipes dressur MGF and MGTF (Sponsored by MGF Mania) 17 15-10-2008 17:13
water leak and loss of power? Porsche91188 Metro / Rover 100 0 03-04-2008 18:01
oil leak coolant leak and mis-fire - great! mtm81 MGF and MGTF (Sponsored by MGF Mania) 7 18-04-2006 08:46
214Si '92 Coolant hose leak - any coolant refilling tips? Lord Minty 'R8' Rovers (aka Wedges!!) 3 12-10-2004 20:01
If you think MG-R's £111m loss is bad, check this out! king arthur MG / Rover Related Chat - up to 2005 16 18-11-2003 21:31
