| View Poll Results: After installing the upgraded LAND ROVER Head gasket have you suffered a HGF again? | |||
| NO - the car is fine until now. |
248 | 75.38% |
| YES - I did suffer an HGF on my LAND ROVER gasket. |
81 | 24.62% |
| Voters: 329. You may not vote on this poll | |||
#1 |
Head Gasket Failure after Land Rover Gasket Fitted?
It would be interesting to see how many of us that have used the upgraded Land Rover head gasket after suffering an HGF had again the same problem. Just to see whether it is really an improvement or not.
Also please state your mileage/kilometers done after the Land Rover gasket fitted. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Fitted LR Gasket myself after 3 days of ownership about 20 moths ago i reckon now. that was on 19k miles, now done 60k so that's about 40k miles on the new LR gasket with no problems at all
and the head was not skimmedall i have done since is make sure my oil is up to the right temp before i nail it but the car does get a fair amount of abuse once warmed up |
#3 |
Myself used to be sooo careful about not reving umore than 3,000 when the car was below 90 C temp and I suffred the HG. Now with the LR gasket and after 30,000 km or 20,000 miles I really care less and abuse the car more. Not because I feel safe with the LR gaket but because my extreme care before did not prevent anything....
#4 | |
#5 |
I want to say I've not had a problem....but we all know what happens when you say something is working fine....
#6 | |
#7 |
Car: Other Manufacturer
I will say that still far to early to tell
#8 |
Since July 2006, 14k miles and counting on the original oil rail, with original stretch bolts in a 1.8 Freelander (MEMS 1.9)
There are a couple of reports of failures from MG-Rover.org and Landyzone.co.uk, although its likely that the liners and head face were not checked in accordance with LR tech bulletin 0036, Ref L8935bu, Date 18.06.04 Surprisingly, there are also reports from a LR technician on Landyzone.co.uk of the new gasket removing any discrepancies in the head face. Last edited by D.R.; 29-12-2007 at 16:39. |
#9 |
Never forgotten
To early for me to report yet - replaced my HG at 98K in June 2007 with a Landrover Gasket, fitted new stretch bolts but retained the original oil rail - I suspect my original gasket failure was because of the very loose fitting plastic dowels.
I have now covered 5.5K......fingers crossed
__________________
Former LE500 owner Last edited by MGFmad; 29-12-2007 at 17:11. Reason: typo |
#10 |
I did not change the oil rail either.
#11 |
#12 | |
#14 |
#15 |
Administrator
__________________
#16 |
So far, the ratio does not look that good does it.
#17 |
Car: FJ1100 STREET FIGHTER
#18 |
Administrator
Poor quality repair work (ie not checking liner heights etc) will always skew the figures.
Done properly, this part is more than fit for purpose.
__________________
#19 |
Ive seen so may bad repairs as regards to Rover head gaskets where some people have even re-used the old type dowels and not replaced them with the new steel type then blamed the repair on the gasket. Like any repair the finished product is only be as good as the person that did the job, meticulous attention to the parts being fitted including rectification of any problems is the key, don't refit a warped head, check liner heights, make sure everything is clean and grease/oil free i always use new bolts but that's no strictly necessary if they measure up OK and make sure once the head is on that you bleed the system properly if these things are followed then you wont have a problem
| Bookmarks |
| Tags |
| head gasket failure, hgf, land rover head gasket |
| Thread Tools | |
| Land Rover Freelander - V6 head gasket failure | The Mad Hat Man | Land Rover | 33 | 22-01-2012 12:21 |
| Inlet Manifold Gasket or Head Gasket Failure? | will-rover | MG ZR / Rover 25, 200 & Streetwise | 15 | 05-11-2010 16:42 |
| Land rover head gasket. | benbmx | MG ZR / Rover 25, 200 & Streetwise | 25 | 05-01-2008 13:51 |
| land rover head gasket | jimmysutt | MGF and MGTF (Sponsored by MGF Mania) | 42 | 08-02-2007 14:00 |
| Land Rover Head Gasket | mgf36 | MGF and MGTF (Sponsored by MGF Mania) | 10 | 08-09-2006 12:45 |
