Stebel Air Horn - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Shopping Related > Archived Forums > Product Reviews
Old 08-01-2008, 17:07   #1
nigel207
Car: 2004 Rover 75 Tourer CDTi
Stebel Air Horn
A year or so ago I bought a red Stebel Air Horn from the Online Shop.
Part Number XPT000005ACA, currently listed at £20.56.
I'd had a 1999 75 which had twin horns, and was appalled to find the pathetic single horn fitted to my 2004 version, hence the purchase. However, despite being fitted out of harm's way (behind the front nearside corner - as dry as possible), the thing has been a pain. I have regularly had to dismantle it to free the compressor vanes, and despite testing it every time I drive the car, and keeping it lubricated, it's been to no avail. Apart from legalities, I'm thinking of reverting to the original and obtaining a second "standard" horn instead.
Italian electrics at their best I think. Beware.
nigel207 is offline
Old 18-01-2008, 11:45   #2
James C
The Goderator
Car: MG ZT 260 SE V8
I have the horn in my TF and it's been fine. Never had to do anything to it. Have you got the correct relay in place, and the horn connected round the right way?
James C is offline
Old 20-01-2008, 15:11   #3
nigel207
Air Horn
Yes, and yes.
nigel207 is offline
Old 22-01-2008, 12:34   #4
MyMgCar.com
Car: R2h1zZle Vvf0sh1Zzle!!
Send a message via MSN to MyMgCar.com Send a message via Skype™ to MyMgCar.com
it may be time to swap it for an air horn off a lorry
MyMgCar.com is offline
Old 22-01-2008, 12:42   #5
Windy
Car: MG ZS120(2005) ■■■■■□□□□□□
I've had one in my ZS for 2 years with no problems, it's directly in front of the radiator so in one of the least protected locations!
Have you got it the right way up? - the horn must face downwards.
Windy is offline
Old 24-01-2008, 10:57   #6
nigel207
Air Horn
Yes it is mounted correctly. It seems that I have been the unlucky one, but you can only take as you find.
nigel207 is offline
Old 28-01-2008, 22:59   #7
cjmillsnun
Car: MGF Trophy 160 in Trophy Yellow
Send a message via MSN to cjmillsnun
Never had a problem with either mine (on my F, mounted on its side but in a protected location) or Helen's, mounted correctly on her ZT (in probably the same place as yours)
cjmillsnun is offline
Old 31-01-2008, 09:14   #8
MyMgCar.com
How loud is it?
Old 01-02-2008, 18:29   #9
cjmillsnun
Originally Posted by YTL2000 View Post
How loud is it?
You would need to be on 18+ for me to accurately describe how loud it is....
But the clean version is very loud.
Old 02-02-2008, 08:33   #10
BlueAgave
Car: MG ZR 160 in Trophy Blue
You mean it's fargin' loud then! How did you wire it into the F?
BlueAgave is offline
Old 03-02-2008, 21:37   #11
cjmillsnun
With the F having a relay feed to the horns anyway, I spliced in a couple of spade connectors to one of the existing horn cables. Removed both of the old horns (one was broken anyway) and connected up... Works a treat.
Old 08-02-2008, 08:39   #12
BlueAgave
Thanks - now done!
Old 06-03-2008, 09:34   #13
warwickswinger
warwickswinger's Avatar
Car: MG ZS 120+ & Suzuki TL-1000R
I've got a Nautilus on my bike... I love it
I wired in a switch as well so I can put it back to standard at MOT time... Just in case Clicky.
Will get one for the car when finances permit.
warwickswinger is offline
Old 24-03-2008, 23:33   #14
Carl
One off a full set
Carl's Avatar
Car: MG ZS 180 MG ZT CDTi 135+ ,MGF 75th Anniversary, MG ZT 120+
Send a message via MSN to Carl Send a message via Skype™ to Carl
will the zs need a relay or is the feed high enough power ? hadone in garage for 2 years and never fitted it
also any sugestions on mounting location as there is not a lot of room
Carl is offline
Old 04-02-2009, 00:19   #15
cyberglass
Car: Rover 25
Have had one my bike for years Passes MOTs no probs. its currently on my dl650 which is used for green laneing and gets real muddy often and it still works fine.
A couple of other people i know have had problems after installing the horn on an angle and sideways it must be mounted UPRIGHT as it states in the instructions.
Have a twin pipe airhorn from ebay on the 25 running with the stock horn via a relay. Good for making small children cry and older folk **** there knickers
cyberglass is offline
Old 04-02-2009, 01:18   #16
cyberglass
Car: Rover 25
CARL
Id use a relay just to be safe its really easy to do though my cb500 horn switch died when i rigged it directly to the horn.
Unsure about where you could mount it on a zs is there any space infront of the battery??
just try to keep it upright and out of direct rain and it will be fine
Old 18-02-2009, 17:29   #17
Road_Rebel
Car: Rover 25
Send a message via MSN to Road_Rebel
youtube vid of it?
Road_Rebel is offline
Old 19-02-2009, 13:34   #18
cyberglass
Car: Rover 25
http://www.youtube.com/watch?v=Do7mczZYHE8
Old 22-02-2009, 16:56   #19
Stu C
Ex mod
Car: MG ZT 260SE & Rover 25 iL Derv
Send a message via MSN to Stu C
You need these babies on the car
http://www.youtube.com/watch?v=XvdjOsvBXFU
http://www.youtube.com/watch?v=BGYcnYLK_50
Stu C is offline
You may not post replies
stebel air horn les. millar MG ZS / Rover 45 & 400 3 10-03-2007 22:27
Stebel Air Horn Nor MG ZS / Rover 45 & 400 14 03-03-2007 18:45
Stebel Air Horn Nor MG ZS / Rover 45 & 400 5 14-02-2007 19:03
air horn GREENERZ MG/R Modification & Tuning 3 07-01-2007 17:58
Stebel Air Horn fitting enquiry firefly MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 11-07-2006 17:01
