heater fan not working on 1 and 2 - MG-Rover.org Forums
Old 19-01-2008, 20:49   #1
tazman1711
Car: Rover 45
Hi all
I have a 2000 45 1.8 and the blower is not working on 1 and 2 ...is this the actual control or the fan unit
also can you replace bulb in the clock
ta
dave
tazman1711 is offline   Reply With Quote Quick reply to this message
Old 19-01-2008, 20:52   #2
Black Pearl
Car: Civic 1.8VTi VTEC DOHC
search for blower your result will be a cheap and easy fix
Black Pearl is offline   Reply With Quote Quick reply to this message
Old 19-01-2008, 20:55   #3
tazman1711
Car: Rover 45
Smile
do you mean the complete unit behind the dash...does a 400 one match
cheers for reply
Old 19-01-2008, 20:57   #4
Black Pearl
here ya go
http://forums.mg-rover.org/showthrea...ghlight=blower
Old 19-01-2008, 20:58   #5
tazman1711
Car: Rover 45
Question
the unit works on 3 and 4 so would it be the actual dial????
Old 19-01-2008, 21:00   #6
Black Pearl
read the whole thread!!!!
Old 19-01-2008, 21:04   #7
tazman1711
Car: Rover 45
Wink
sorry replied before i got it....will the 400 one fit the 45??
seems i have a bit of a scrapper trip on in the rain but it bugs the life outta me when things go wrong and cant leave it cause it niggles like hell
Old 19-01-2008, 22:32   #8
slickman
Car: mk5 astra xp pack
400 one should fit fine mate, i think there the same across the range.
slickman is offline   Reply With Quote Quick reply to this message
Old 19-01-2008, 23:44   #9
Steve_R
Car: Rover 45
Both the blower and clock backlight seem to be common faults judging by posts on this forum.
If you fancy your chances with a bit of very simple soldering, it's worth considering replacing the resistors as per the thread rather than getting a replacement pack from the scrappies - you'll have to find one that works and hope that it lasts a while. The original coil resistors don't appear to be all that robust.
Unless you have small fingers and can reach/remove the clock backlight just by taking out the head unit, you're stuck with having to remove the centre console. There's a thread/'how to' here -
http://forums.mg-rover.org/showthrea...=138072&page=2
Out of interest, do the heating elements in your mirrors work ok?
Steve_R is offline   Reply With Quote Quick reply to this message
Old 20-01-2008, 09:29   #10
jackdaw
Car: Rover 75
Loads of ebay items listed to recify the 1&2 blower speed problem, some offer repair, others offer upgraded coils. I am worried; that anything other than the original resistors may cause other problems to this troubled wiring nightmare !!! They have variable life spans; guess it depends on how often you use the different settings on the dial. 2 is the favourite; not too noisy !
jackdaw is offline   Reply With Quote Quick reply to this message
Old 20-01-2008, 12:35   #11
tazman1711
Car: Rover 45
cheers for all the replies guys...
may nip to maplins to get the resistors or see how much genuine rover ones are.
the blower on 3 gets a little too much so agree that 2 is best.
will let you know
cheers
Old 20-01-2008, 13:25   #12
forestred
Car: Rover 400 (95-99)
Dont bother with the rover ones (if you can get them even), nip to Maplins, the one(s) you want are P/No H1R & they are 40p each. Did mine a month ago took about 1/2 hour & it's a doddle, just make sure the terminals are clean before you solder! Clock bulbs can only be got from Rover spares stockists (unless someone knows different) P/No, XDG100040 approx 3.80!! Bugger to fit as you have to remove the console to get the clock out.
forestred is offline   Reply With Quote Quick reply to this message
Old 20-01-2008, 14:15   #13
tazman1711
Car: Rover 45
Smile
ok will nip to maplins tomorrow cheers.
i have a 22 yr old nissan silvia as well as my rover and if anything goes wrong it pecks my head till i have to fix it....dashboard out and all at times so the clock will be an easy one bud
Old 20-01-2008, 14:16   #14
R.Fensome
Car: Rover 45 Impression S TD
Afraid I have to take issue with you on that forestred,
1/ the clock bulb on mine went, went into local Wilco carmasters shop, and was told it was a standard over the counter bulb and was 79p (but take old one to show them).
2/ Maybe then my 51 45 is differant to everyone else's. Took head unit out and by reaching up behind clock got bulb out, but gave up after half an hour of fiddleing and swearing trying to get new one in. So, I looked closer and saw clock unit is clipped into console unit, so released the two bottom clips with small screwdriver and the clock came out in my hand, replaced bulb, and clipped back in, done, 30 secs.
R.Fensome is offline   Reply With Quote Quick reply to this message
Old 20-01-2008, 16:40   #15
Black Pearl
same clock as the civic, bulb from local sparky shop 54p
Old 21-01-2008, 12:48   #16
forestred
No need to take issue Mr Fensome my friend!!!!
My car is a 400 so it must be different to the 45, I wrongly assumed the clocks were the same . On the 400 the clock is held in place with 2 nuts & unless your hands are 1" wide with extra joints on your fingers is virtualy impossible to remove without taking out the centre console (my experience only, please don't take issue if there is an easier way!! )The 2 bulbs in the 400 clock are set into a plastic holder & I couldnt see how to separate them, took them to various dealers & was told they had to be obtained from a Rover stockist. If the bulbs can indeed be separated from their holder then please enlighten me!
Old 21-01-2008, 20:46   #17
ricky.d
two resistors from maplins do the trick for the heater and if you can take your radio out you can just get to the back of the clock with a dumpy screwdriver to take it out to replce the bulb most good car spares shop sell them
ricky.d is offline   Reply With Quote Quick reply to this message
Old 21-01-2008, 22:03   #18
ThreeDee
Car: 420SDi
Radio code guy ?
#Edit# Damn, wrong thread. Move along, nothing to see...
ThreeDee is offline   Reply With Quote Quick reply to this message
Old 22-01-2008, 11:34   #19
jackdaw
Car: Rover 75
Open the glove box up this morning to expose the RESISTORS,, yes they are broken on the thin coil. Tried to link the 2 ends together, to see if the slow speeds would work but only got a burning smell. Will buy a recon. item off ebay. The slow speeds worked momentarily but a final fix is needed
Heater fan 1 and 2 not working lorry MG ZR / Rover 25, 200 & Streetwise 5 01-06-2008 00:18
Heater fan only working on 3,4 steve's F MGF and MGTF (Sponsored by MGFnTFBITZ) 5 28-08-2007 22:01
heater fan not working? Steve220sd MG ZR / Rover 25, 200 & Streetwise 2 06-08-2006 21:09
Heater Fan Not Working!!! PERRY-MGTF MGF and MGTF (Sponsored by MGFnTFBITZ) 28 08-12-2005 22:27
heater fan not working deputy10 MGF and MGTF (Sponsored by MGFnTFBITZ) 5 02-08-2005 17:58
