MGF Steptronic Gearbox Problem or that it seems - MG-Rover.org Forums
Old 25-01-2008, 19:09   #1
ALPHABAR
Car: MGF
Send a message via MSN to ALPHABAR Send a message via Skype™ to ALPHABAR
Hi I have an MGF year 2000 1.8 Steptronic, had the car in Venezuela for a long time now with no luck at all in getting it going.
So far changed many sensors with no luck what so ever, the car seems stuck in 3rd gear, it can get up to 50 mph on 3rd gear or that it seems, have changed the output shaft sensor, speed sensor, gearbox ecu and still no joy.
Shaf very kindly send me some info on checking for electric faults ,, they all seem to be fine, all the electrics I mean....
Have spoken to several garages whom tells me that it has to be the gear box, I would like a debate on this if possible with as much as positive information.
Have even spoken to an especialist who states the same, but some other mechanics assure me that it has to be an electrical fault.
kind Regards
ALPHABAR is offline   Reply With Quote Quick reply to this message
Old 25-01-2008, 21:02   #2
Stafainn
Car: MGF and MGZR
As far as I know it is the same (or very similar) gearbox that is in the BMW MINI. Why don't you try a BMW garage to see if they can help?
Stafainn is offline   Reply With Quote Quick reply to this message
Old 27-01-2008, 22:10   #3
mgadel
Car: MGF
Steptronic problems
Have a close look at the switches in the selector at the base of the stick.
I fixed one that was going into limp home mode simply by careful adjustment.
Adrian
mgadel is offline   Reply With Quote Quick reply to this message
Old 28-01-2008, 14:24   #4
ALPHABAR
Car: MGF
tHANKS
Excuse my ignorance ,, but when you say stick ,, do you refer to the stick as the gearbox stick ,, or as the tick which is on the gearbox it self... cheers ,,, really excuse my ignoranse
Old 28-01-2008, 17:01   #5
Neil Courtney
Car: Trophy Yellow MG TF120, '75 Jubilee MGB GT
Adrian probably means the gear stick itself, on the console inside the car. It may be hard to get at the switches.
And welcome Adrian. Please introduce yourself in a separate thread... :-)
Neil Courtney is offline   Reply With Quote Quick reply to this message
Old 06-02-2008, 17:01   #6
Shaf
Car: MGF
Hi Alphabar,
I thought you had sorted it out because I didn't hear from you for a while.
I think you need to explain all the syptoms again.
How does it feel when you accelerate from rest.
What engien speed does it give.
Are htere any warning lights on.
What happens if you use the manual shifting.
I remember it really sounded electronic before.
The basics of how the box works.
There is a belt between two sets of cones. At rest or with no clamping pressure the belt will be in lowest ratio. It will always start from this ratio, it physically cannot start from any other ratio due to the way the pressures work.
There is a small valve in the gearbox called a compensating valve. On one side is a hydraulic pressure proportional to engine rpm, on the other is a spring pressed by a stepper motor.
If the pressure on the first side of the valve is higher than the force on the other side the valve will move. So if the engien speed rises, the valve moves and allows oil to flow to change the ratio. If you want the engien speed to rise (in manual mode) then you have to actually move the stepper to change the force on the spring balancing out the change of the hydraulic signal.
So for it to be Stuck in 3rd gear, the ECU would actually have to control the stepper motor. This is not one of the limp home strategies.
More likely the stepper motor has moved to a certain position and is fixed there. I think this is a limp home strategy.
If this is the case then the car will start from rest normally but once the engien speed reaches a certain point it will hold that speed no matter what.
Shaf
Shaf is offline   Reply With Quote Quick reply to this message
Old 03-03-2008, 00:30   #7
ALPHABAR
Car: MGF
HI SHAF
THANKS EVER SO MUCH FOR YOUR RESPONSE,,, FINALLY I FOUND A MECHANICAL ENGINEER AND WE SAT FOR HOURS TRANSLATING ALL YOUR EMAILS ... YOU HAVE BEEN VERY KIND INDEED ,, I WROTE THIS ON A NEW THREAD ,, BUT WOULD LIKE TO PLACE IT HERE FOR YOUR OPINION,,, AND THANKS EVER SO MUCH FOR EVERYONES REPLY TO MY THREAT:
Hi ,, My Mgf Steptronic Year 2000, Has Gone Into Limp Home Mode And Iam In Venezuela (south America) ,, I Took It Our With An Engineer (mechanical) Bmw And He Is Reuqesting A Giagnostic Troubleshoot For The Following:
The Car Can Be Driven It Seems To Be On 3rd Gear It Picks Up Speed It Gets To About 50 Mph And Can Do More, But Iam On A City, When Changed Onto Sport Mode Neither The Gear Atick Nor The Wheel Controls Change The Cars Gear.
About 2 Miles And The Cars Tempature Starts Going Up And The Yellow Light On The Panel Comes On.
I Am Waiting For A New Giu Gear Interface Unit ---
And We Will Be Ion The Process Of Checking All The Wires As Per Shaf ,, Whom Very Kindly Gave Me Some Information A While Ago.
Any Ideas On The Troubleshoot Guide, Book Or Cd
It Has Not Been Easy To Find A Reliable Mecanic Here ---
Any Suggestion Will Be Apreciated.
Max
PS WHEN I SAY 3RD GEAR THAT IS WHAT IT SEEMS..
Old 03-03-2008, 00:33   #8
ALPHABAR
Car: MGF
[quote=Shaf;2400940]Hi Alphabar,
I thought you had sorted it out because I didn't hear from you for a while. not found a good mecanic down here
How does it feel when you accelerate from rest. SLUGGISH
What engien speed does it give. CAN REACH 55MPH
Are htere any warning lights on. AFTER 2 MILES THE YELLOW TRANSMISSION LIGHT COMES ON AND CARS TEMPERATURE GOES UP
What happens if you use the manual shifting. [B]DO NOT WORK AT ALL[/B
IN REPONSE TO YOU SHAF ,, CHEERS ONCE AGAIN
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Rover 25 steptronic gearbox problem suggie MG ZR / Rover 25, 200 & Streetwise 9 15-05-2011 17:01
MGF Steptronic problem 3dpony MGF and MGTF (Sponsored by MGFnTFBITZ) 3 04-10-2008 21:23
MGF Steptronic Gearbox Help!!! sarahjayne MGF and MGTF (Sponsored by MGFnTFBITZ) 13 21-09-2008 15:13
Mgf Steptronic Gearbox Refurbishment ALPHABAR MGF and MGTF (Sponsored by MGFnTFBITZ) 2 24-01-2008 19:18
steptronic gearbox problem? sssammm Others 1 07-08-2005 08:12
