advice needed water pump leak RAD WELD - MG-Rover.org Forums
Old 08-02-2008, 14:03   #1
DJMARK
Car: MGF
Send a message via MSN to DJMARK
my water pump has a leak could I add rad weld to help as a precautionary measure or does the cambelt & pump need to be done
just need to save some cash so a radweld it for a while might help
DJMARK is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 14:04   #2
James C
Car: MG ZT 260 SE V8
Only put RadWeld in if you want to bugger your car up completly.
DON'T USE RADWELD IN THE K SERIES ENGINES!
James C is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 14:10   #3
DJMARK
Car: MGF
You The Man!!
Old 14-02-2008, 15:19   #4
Kenny P
Car: Other Manufacturer
Yeah get the leak fixed correctly! Radweld is a k series killer.
Kenny P is offline   Reply With Quote Quick reply to this message
Old 14-02-2008, 15:25   #5
MGMUSKY
Car: MG TF
wot he said
MGMUSKY is offline   Reply With Quote Quick reply to this message
Old 14-02-2008, 16:34   #6
silvershadowmgf
Car: MGF
so should he use it or not? lol
silvershadowmgf is offline   Reply With Quote Quick reply to this message
Old 14-02-2008, 16:51   #7
Kenny P
I think James was advising against it lol.
Old 14-02-2008, 17:04   #8
Tim.
Tim.'s Avatar
Car: MGF Trophy 160, MG ZS180
Radweld won't work on rotating joints anyway.
Tim. is offline   Reply With Quote Quick reply to this message
Old 14-02-2008, 19:16   #9
MGFmad
Never forgotten
Car: Astra CDX auto, Freelander TD4 & Freelander 1.8, Mini One
Send a message via MSN to MGFmad
Exactly
but in other locations it will work as a get you home measure. Not sure what all the fuss is about with Radweld - the only engine you cannot use it on is the Rover 827.
MGFmad is offline   Reply With Quote Quick reply to this message
Old 14-02-2008, 19:29   #10
Petevick
Originally Posted by MGFmad View Post
.....Not sure what all the fuss is about with Radweld.......
that would be the narrow water ways in the engine, just waiting for a coagulating agent
Petevick is offline   Reply With Quote Quick reply to this message
Old 14-02-2008, 19:41   #11
billo
Car: MG ZS
Send a message via MSN to billo
Exactly
well said my friend , i used rad weld cause i spotted a small leak on my radiator and NEVER had a problem since apart from kenny putting the ****ters up me , so i had it checked out by 3 different garages and they all said my coolant systm was fine SO
billo is offline   Reply With Quote Quick reply to this message
Old 14-02-2008, 19:43   #12
Kenny P
Yup nasty stuff. Just address the leak correctly if it needs a new rad get one on.
Old 14-02-2008, 19:55   #13
Kenny P
All you need to no about radweld is here.
Old 14-02-2008, 20:07   #14
billo
Car: MG ZS
use radweld its fab !!!!!!!!!!!!
Old 14-02-2008, 20:09   #15
MGFmad
Never forgotten
I don't have any Radweld in the MGF as I have renewed most of the cooling system. But have used it on a couple of other cars with no side effects -
First was a long while back on a Pug 106 diesel that had very slight coolant loss but no sign of a leak, put some radweld in and it stopped the coolant loss - had this car for quite a while after with no problems.
In July 2005, our Discovery TD5 developed a slight coolant leak from the radiator while we were on holiday, I put some radweld in and it stopped the leak and kept a close eye on the temperature while driving home. In the following months I forgot about the radiator so never changed it and it nevr lost of drop of coolant - traded in last month.
I believe radweld works by expanding to fill a hole on contact with air so its not going to cause a problem inside the engines waterways.
It does have its place as a temporary fix and I would not advise doing what I did with the Disco as a long term solution, but its not the curse of the devil either!
Old 14-02-2008, 20:10   #16
MGFmad
Never forgotten
Excellent - we could be the founder members of the Radweld appreciation society
Old 14-02-2008, 20:14   #17
billo
Car: MG ZS
Talking
YEAH LETS START A CLUB
Old 14-02-2008, 20:15   #18
Petevick
.....but its not the curse of the devil either!
OOOOO yes it is
Old 14-02-2008, 20:19   #19
Herbie
Car: MGF 1.8i, MGF & MGTF 1:18
Send a message via Skype™ to Herbie
I see another crew comin' up: Hardcore Radweld Crew (HCRC)
Good luck guys hehehe
Herbie is offline   Reply With Quote Quick reply to this message
Old 14-02-2008, 20:20   #20
billo
Car: MG ZS
Red face
MAYBE ITS JUST CRAP ON TF'S !!!!!!!!!!!!!!!!!!!!!!
Leak from water pump lozz MG ZR / Rover 25, 200 & Streetwise 5 02-11-2008 17:15
Water Pump Leak 214 no 1 MG ZR / Rover 25, 200 & Streetwise 18 25-02-2008 20:10
Water pump leak. Rov420i MG ZS / Rover 45 & 400 4 18-07-2007 14:38
Water pump area leak???? Robs 2001 mgf MGF and MGTF (Sponsored by MGFnTFBITZ) 5 11-01-2007 23:36
Rad Weld ???? zaffa Others 7 09-06-2003 20:12
