Clicking Noise From the Back Of the Car - MG-Rover.org Forums
Old 14-02-2008, 22:24   #1
Jalipero
Car: Rover 75
Send a message via MSN to Jalipero
Unhappy Clicking Noise From the Back Of the Car
Hi All
You may have seen my previous threads relating to my poor car. Has some erratic idle problems(sometimes), won't start for no reason(sometimes), and now it has starting making a clicking noise from somewhere under back seat/near rear wheel area.
At first I thought it was my son kicking something, and when the noise didn't stop even after me telling him, I stopped the car and got out to do a Homer and strangle him. To mt eternal dismay, I found out I could hear the noise from outside too. Oh and it wasn't him. Bugger.
It only seems to happen when I have just started the car, more especially if it has been sitting a while. Happens for about 30 seconds or so then stops.
Would I be right in assuming that, along with the other problems, it is more likely to be the pump in the tank that I have been reading all the horror stories about?
Car has just turned 100K, and I mean just, think the stuff on these cars are set to break around then from what I read.
Jalipero is offline   Reply With Quote Quick reply to this message
Old 15-02-2008, 07:45   #2
baxlin
Car: Rover 75 CDT Conn SE and JZR three wheeler
If it's a diesel it could be to do with the return fuel system, mine "ticks" from behind the O/S rear wheel, but I'm sure a guru will be along soon to confirm
baxlin is offline   Reply With Quote Quick reply to this message
Old 15-02-2008, 23:31   #3
Moonstone
Car: Rover 75 Tourer
NSR may also be the location of a pump for the fuel-burning heater, if you have one fitted. Does it only happen when the outside temperature is low?
Moonstone is offline   Reply With Quote Quick reply to this message
Old 16-02-2008, 19:17   #4
Jalipero
Car: Rover 75
Actually now that you mention it, there is like a radiator type thing under tha back , and the last week or so is the first time since I have had it that it has been below freezing temperature, to fuel burner might be right enough. However does the clicking indicate it is igniting the fuel burner then, or that it isn't?
Old 16-02-2008, 19:31   #5
Cyril
Car: MG ZTT
I blame the kids!
Cyril is offline   Reply With Quote Quick reply to this message
Old 17-02-2008, 16:55   #6
Moonstone
The radiator is on the off-side. That's for cooling unused diesel returning to the tank.
Don't know enough about the FBH, but if the pump (near-side) had a faulty solenoid, it might just click on and off. Just a wild guess, though.
If it's the off-side, the primary fuel pump is under the passenger seat. That would be more consistent with the other symptoms. There are lots of threads on this pump - if not replaced soon after going faulty, it will cause excess wear and premature failure of the secondary pump as well.
Old 17-02-2008, 18:46   #7
Jalipero
Car: Rover 75
When I went out this morning hoping to double check which side the clicking was coming from. But it wasn't cold and it didnt click.
Should I assume then that it was the fuel burner? I will double check again which side of the car it was on should it happen again. Might change the pump anyway, but I was hoping to not to as my air con has a leak from somewhere, and I wanted to get that fixed.
I put it back into the garage i bought it from to get fixed as it was overheating and leaking, but it sounds as though all they have done is bodged the fan motor to the air con switch, and it is running at constant speed whenever the air con is turned on. They said they couldnt find a leak, and yet 6 weeks later its empty again.
*****. I'll never by a car from Broadwood Car Stadium in Cumbernauld again that's for sure. Who said Dick Turpin was dead?
Old 24-02-2008, 23:32   #8
Bazman01
Car: Rover 75 Tourer / MGF
Hi All
The clicking noise is most likely the fbh solenoid diesel pump.It is situated on the drivers side in front of the rear wheel.The clicking noise means that it is working!
Bazman01 is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Grinding noise to back of car Kryt MG ZS / Rover 45 & 400 2 12-01-2008 21:39
Noise from the back of the car?? Tallgeese MG ZS / Rover 45 & 400 6 11-11-2007 19:43
need help car back firing and no power also my tank make noise soooperspeed MG ZR / Rover 25, 200 & Streetwise 6 12-06-2007 16:23
clicking noise jbomb MGF and MGTF (Sponsored by MGFnTFBITZ) 4 22-10-2006 17:11
strange Clicking Noise when car is warm Bobdope2002 Others 3 30-01-2005 21:42
