Old 01-03-2008, 22:01   #1
STEVEN_NORFIELD
Car: SLKR171, Alfa Gt, 260Z
STEVEN_NORFIELD is one of our most respected members on hereSTEVEN_NORFIELD is one of our most respected members on hereSTEVEN_NORFIELD is one of our most respected members on hereSTEVEN_NORFIELD is one of our most respected members on hereSTEVEN_NORFIELD is one of our most respected members on hereSTEVEN_NORFIELD is one of our most respected members on hereSTEVEN_NORFIELD is one of our most respected members on hereSTEVEN_NORFIELD is one of our most respected members on hereSTEVEN_NORFIELD is one of our most respected members on hereSTEVEN_NORFIELD is one of our most respected members on hereSTEVEN_NORFIELD is one of our most respected members on here
MGF Refurb Part 2 - Cup Alloys Refurb!
Right then! The biggest job of all that I have on the cards for sorting the F out was the wheels, as you can see from the following pics, they were well and truly corroded.
I must get an award for the amount of wheel weights on this one.....
First, I gave all the wheels a good wash and scrub with Autoglyms machine cleaner, which got rid of the bulk of the dirt. Upon inspection, I could see that the paint on the inner face of the rim was pretty none existent. What little paint there was there flaked off when prodded with a fingernail.
I used a drill fitted with a wire rotary bit and numerous grades of sandpaper. What I'll say at this point is that if your wheels are corroded as badly as mine, take it to a pro and pay £40 a wheel as when they're in this kind of state you'll spend hours bent double grinding and sanding away. I ached for days after this! If you have a multi-tool like a dremel, it makes the detail parts a whole lot easier, particularly if you've got the proper mini sanding drums.
If you are a total mug and you carry on doing it, an easy way to mask up is to drop the wheels in a bin bag, then cut a circle out and mask up around the alloy, it saves no end of time. Don't forget to mask the rear face of the wheel where it mates to the hub. You don't want this surface to have paint on it.
I used a small tube of P38 filler to take out the worst of the defects and blemishes, and then sanded it back down. Three coats of high build primer and they begin to look like championship white alloys you'd find on a type-r......
Then came two coats of Plastikote's super bright Argent Silver paint. I'm pretty sure you'll agree that the finish is amazing considering it came from a can.
But trouble was around the corner, you cannot laquer this paint. I left it for three days to dry but when I went to laquer, it it just mottled and reacted like I'd poured sulphuric acid on it!!! So, totally gutted and irritated I just used up a can of Ford Moondust Silver I had lying about in the garage. This laquered up with no problems and the wheels looked just like a new set, but nowhere near the shine that I'd managed with the original plastikote spray.
Then applied some Ø50mm badges I'd got from ebay as the ones in the centres were knackered and bubbled...
And added some shiny valve caps (ebay - £1.99). As an aside, drop some copperslip on these type of caps, as ali and steel will meld and if you don't take the caps off for six months then you'll find yourself having to cut them off. Bitter personal experience there. There's some patches on the rear inner face of the rim that really aren't up to stratch. This is why I think that if your alloys are really bad, get a pro to do it as you just can't see the damage until it's sprayed and finished.
And here's the finished article. For the princely sum of £28 I'm rather pleased! To be honest theres some damage that I missed and my sanding of the filler leaves a bit to be desired by a pro, but on the face of it, they're ten times better than before. I'm just gutted that I couldn't make the bright finish stick.
STEVEN_NORFIELD is online now   Reply With Quote
Old 01-03-2008, 22:07   #2
Baracus
Car: MGTF 180 Sprint
Baracus is a glorious beacon of lightBaracus is a glorious beacon of lightBaracus is a glorious beacon of lightBaracus is a glorious beacon of lightBaracus is a glorious beacon of light
Send a message via MSN to Baracus
good job mate
I used plasticote on my calipers and they laquered without any problems.
for the wheels though i used the original Sparkle silver and Laquer.
hard work job mate but definatly worth doing
Baracus is offline   Reply With Quote
Old 01-03-2008, 22:09   #3
STEVEN_NORFIELD
Just to add some more pics, heres what the bright finish looks like compared to the other regular alloys, how gutted am I
Old 01-03-2008, 22:11   #4
STEVEN_NORFIELD
I found out it's something to do with the finish, regular silver colours are fine, I've done them several times before, but this stuff has some sort of special finish to it, and if you read all the way down the small print it says "not for automotive use"!!!! That'll teach me!
Old 01-03-2008, 22:13   #5
Baracus
hmmm, i didn't read the small print on my red plasticote can, i just liked the colour and it was a harder based paint than normal spray paint which is why i got it as it was for the ap calipers, laquer wasn't a problem. maybe it's different on the tougher spray paints they do then and maybe just on the silver as you say
Old 01-03-2008, 22:27   #6
Fast Jan
is trying...
Fast Jan's Avatar
Car: TF 160
Fast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these parts
I don't actually like the super bright silver paint, it looks cheap, and well, plastic
The moondust silver looks better imo.
Job well done and good pics and write up
__________________
Experience is a journey, not a destination
For Sale: **17" wheels & Toyo tyres**
Fast Jan is offline   Reply With Quote
Old 02-03-2008, 07:04   #7
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
excellent write up Steven, one for my site methinks
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 02-03-2008, 07:19   #8
Tim.
MGs on Track
Tim.'s Avatar
Car: MGF Trophy 160, MG ZS180
Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.Tim. has a reputation beyond repute. Respect.
Great job Steven. I've got a set round the back waiting for similar treatment but waiting for warmer weather. I think the colour looks OK but if you don't like it you can go over them with something else. You've done all the hard work. Do a test area round the back first though in case its not compatible.
Tim. is offline   Reply With Quote
Old 02-03-2008, 07:31   #9
Herbie
Werder Supporter
Herbie's Avatar
Car: MGF 1.8i & MGTF 1:18
Herbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these parts
Send a message via MSN to Herbie Send a message via Skype™ to Herbie
That's great Steven
I'm no painter but what about topping it up with 1 or 2 coats of clear lacquer ?
__________________
Stephan Hebert
MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ
Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling
Herbie is offline   Reply With Quote
Old 02-03-2008, 07:35   #10
STEVEN_NORFIELD
Cheers! Look out for the next instalment...........
Originally Posted by Tim. View Post
Great job Steven. I've got ...... the back first though in case its not compatible.
I'm waiting for a response from Plastikote as to what I should have done with them, as it was plastikote's own laquer that snarled them up which seems pretty unusual.
Old 02-03-2008, 07:37   #11
STEVEN_NORFIELD
Originally Posted by Herbie View Post
That's great Steven
I did 3 Coats of Plastikote's own after the moondust silver. Would've been a total waste with no laquer as the brake dust would chew through paint in no time at all.
Old 02-03-2008, 07:56   #12
Herbie
Werder Supporter
Herbie's Avatar
Ahh sorry, didn't know what Plastikote's is
__________________
Stephan Hebert
Old 02-03-2008, 15:49   #13
STEVEN_NORFIELD
Plastikote's just a name brand. Normally associated with more DIY approach stuff, whereas the car paint you normally get from motor stores (i think) it either CarPlan or Tetrosyl.
Old 02-03-2008, 16:06   #14
Lee121
Now with added Orange
Lee121's Avatar
Car: TF135 and Skoda Octavia (surprisingly good!!)
Lee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant future
Great job Steven ...have some rep too
__________________
Lee
Dee....R.I.P. Sadly gone, never forgotten
MG.....draining motorist's wallets dry since 1924
I can supply stripes and '85th' style door graphics in any colour, PM me for details. NB, It isn't a business, just a hobby!!!
Lee121 is offline   Reply With Quote
Old 02-03-2008, 16:20   #15
empsburna
Trader Supporter
Car: Other Manufacturer
empsburna has disabled reputation
when you had finished sanding the wheels did you clean them afterwards with any panel wipe/tack rag?
I had exactly the same problem with one wheel that I had not degreased correctly before painting and then adding the clear.
This is the wheel I had to repaint (in Vaxuhall Metallic Silver - as close as anything to rovers own but half the price per can)
and what it looked like close up after repainting
empsburna is offline   Reply With Quote
Old 02-03-2008, 19:49   #16
STEVEN_NORFIELD
Why thank you my good man!!! Cheers!
I kinda did, I went over the wheels with an isopropyl cleaner that I had lying about. I thought that would be sufficient. It was quite cold in the garage so even after 3 days it may not have sealed up properly I guess. The damage was massively worse than what you experienced judging by the photo's. Even the slightest dust over of laquer made the paint bubble and react like I was spraying on Nitromors! I've never seen paint react like that, I can only guess it's something to do with the mechanics of the finish. I've done numerous little things like mirros and door handles, so I'm no pro but I know roughly what process I should be doing and what to expect.
If anyone gets the bright finish to work it'd be good to see how.
Old 02-03-2008, 22:18   #17
FreddieS
FreddieS's Avatar
Car: Too many!
FreddieS is a splendid one to beholdFreddieS is a splendid one to beholdFreddieS is a splendid one to beholdFreddieS is a splendid one to beholdFreddieS is a splendid one to beholdFreddieS is a splendid one to beholdFreddieS is a splendid one to behold
Send a message via MSN to FreddieS
Oww my Steven!
Those wheels look STUNNING, both times round!
I think i shall be going for a lighter + shinier silver when i spray my 200's wheels, because damn they look gooood!
__________________
'69 MG Midget | '78 Yamaha FS1e | '89 MG Metro | '09 Suzuki Bandit
'FDH' Rover 220 Turbo Coupe
FreddieS is offline   Reply With Quote
Old 02-03-2008, 22:23   #18
empsburna
Trader Supporter
Hmm. Thats very strange then - mine went bitty, like someone had thrown grit over it before it was painted (if that makes sense!)
Old 02-03-2008, 22:31   #19
zedler
Car: MG ZR
zedler has a spectacular aura aboutzedler has a spectacular aura about
i think im going to get mine done by a pro, 30 quid per wheel shot blasted and baked proffesionally,i think if i did it myself i'd be doing them again in the next 12 months tbh,seems like too much hard work for an ok finish thats not gauranteed to flake and peel,mg alloys were done half cocked by the manufacturer anyway so doing a d.i.y job just seems like a waste of time.
zedler is offline   Reply With Quote
Old 02-03-2008, 22:39   #20
FreddieS
FreddieS's Avatar
Car: Too many!
I had my TD cosmo's acid dipped, shotblasted and powdercoated, finish was nice, but you must take into account that youve got to have your tires taken off (usually not inc the £30 per wheel price) and then have them refitted. This and the fact that you wont get as shinier a finish with powdercoat (unless they laquer it afterwards, which imho is cheating)
All mg/rover alloys were done half cocked, the paint doesnt stand up to heat at all and is pretty much crap, but then you look at aftermarket wheels and its the same, a freinds KN vectors powdercoat was literally non existant! it had all just flaked off the inside of the wheel, and then spread to the outside.
A DIY job, dont to a high standard will last just as long as powdercoat. and the fact that it costs £30-40 to do 4 wheels, and you can do it in a weekend, its kind of an awesome win/win to me!
__________________
You may not post replies
Refurb or Buy New Alloys????? also New Rubber Question Jonny H MG ZT / Rover 75 12 26-04-2008 18:27
MGF refurb part 1! Steering wheel! STEVEN_NORFIELD MGF and MGTF (Sponsored by MG Rover Parts Ltd) 4 15-02-2008 16:42
Alloys in need off refurb Em.Tee Wanted 2 16-11-2007 06:45
refurb alloys sav-mg MG ZS / Rover 45 & 400 15 02-11-2007 12:18
alloys refurb dazz105 Wales 5 10-11-2006 11:22
Terms and conditions of use
