Worried? - MG-Rover.org Forums
Old 10-03-2008, 09:14   #1
eddiesolo
Car: MAZDA BONGO!
Worried?
Hi Guys,
Got in my car this morning, turned the key and the car fired up-but...it normally is a bit tappety until it warms up-this morning was the same yet the engine seemed to be wanting to throw itself out of the bonnet! The vibration through the steering wheel was unbelievable. I turned the engine off and then started it again, same problem-seemed to be hunting. I left it a few minutes (as I normally do) to warm up and then I gingerly moved away and the engine management light came on and then went off. It has stayed off and the engine seems to be running fine-it ran perfect yesterday when I went up to slickman's house and back. Never had this problem before-will be going out when it stops raining to check on fluids etc.
Have you guys any ideas, or had this kind of problem?
Si:-)
I DRIVE A...
eddiesolo is offline   Reply With Quote
Old 10-03-2008, 09:34   #2
ashy
Car: Silver Stormer ZR turbo.
Ignition related, seems like it's misfiring.
ashy is offline   Reply With Quote
Old 10-03-2008, 09:37   #3
simon.guna
Car: Rover 200Vi
As Ashy said. Probably it is running on 3 cylinders or less.
simon.guna is offline   Reply With Quote
Old 10-03-2008, 09:44   #4
eddiesolo
Car: MAZDA BONGO!
Yeah, thanks guys-this was my thought but just wanted a bit of feedback before tackling the problem.
IIRC the car had a problem when I went to see it-engine management light on-no pick at higher revs. They sorted the plugs and it seemed to cure the problem-like I said had no worries in the months I have had it. It's MOT time at the end of April- may service it early and see if I can sort this problem.
Si:-)
I DRIVE A...
Old 13-03-2008, 07:08   #5
eddiesolo
Car: MAZDA BONGO!
*UPDATE*
Got the motor sorted...YEAH! Damp was causing problem-all sorted-had a full service-all new filters through out and a pre-MOT as it's due at the end of April. Looks like it should *fingers and everything else crossed* sail through.
Glad it wasn't something really expensive.
Si:-)
I DRIVE A...
Old 13-03-2008, 08:07   #6
Dr.Buck
Car: Peugeot 207 1.4hdi
I had a similar thing yesterday morning, must be due to the immense wind and accompanying rain we've had recently.
I changed my plugs yesterday anyway, as it was needed to cure a hot-starting problem.
Dr.Buck is offline   Reply With Quote
You may not post replies
Should I be worried???! David M MGF and MGTF (Sponsored by MGF Mania) 4 05-03-2008 13:10
OK, now I'm worried.. GavinG MGF and MGTF (Sponsored by MGF Mania) 8 08-06-2007 20:56
A little worried...... nebburns MG ZR / Rover 25, 200 & Streetwise 9 21-09-2006 11:20
Please help, really worried nebburns Others 40 31-07-2005 21:09
