Old 19-03-2008, 23:23   #1
CJJ
Mudslinger extraordinaire
CJJ's Avatar
Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1
How to remove your centre console - TF
As per my other post, I removed my centre console to fit one that I had colour coded.
This was on a TF and there may be differences on Fs.
I followed Tonys post http://www.apttony.co.uk/Servicing/CentreConsole.html but felt it didn't have the CJJ standard of 100 photos
First thing to do is remove your radio/head unit. this all depends on the type you have. It could be the wire type tools, keys or screws. Make sure if it is a coded unit, that you have the codes, otherwise you are stuffed once you disconnect the power. Mine just forgets half it's settings, which is annoying enough.
I then removed the top air vent to give me more room to work. This is held in by 2 plastic lugs at the top and 2 at the bottom. Carefully lever the 2 bottom lugs out and the unit should pivot out on the top 2. Be carefull what you use to do this as you can end up marking the vent or dash if you use too much force or a sharp object.
The centre console is held in by 5 spring clips and one plastic locator at the base.
This is what the clips look like. The circled bit is the bit that you need to push with a screwdriver to release the clip.
Start with the top 3 clips. Put your hand in where the radio was (watch out for sharp edges) and gently pull until you create enough of a gap to expose the clips.
You then want to use a long narrow implement, such as a screwdriver, and push the release lug on the spring clip. If you do this correctly the clip should release while you are pulling on the console. You shouldn't need to lever the console out. In the picture the screwdriver is pushing on the centre of the clip and NOT levering the console.
Next you should remove the gear knob and gaitor. The knob simply unscrews (unless you have an aftermarket one). The gaitor should just lever out as the silver plastic ring is only held in place by 4 plastic lugs. Again take care not to mark or damage the console.
You can now lever the very bottom of the console (circle 1) so that the plastic lug comes free. Once this is out you can slide the bottom of the console towards you, releasing the 2 spring clips as you did for the top 3.
Put the gear lever into 4th to give a bit of clearance and move the console carefully towards you until you have enough clearance to access the electrical connections.
Carefully unclip and remove the 3 plugs from the top.
Small White = Oil Temp Gauge
Small Black = Clock
Large White = hazard switch
Now carefully remove the plugs from the window switches, fog light switches etc
2 large White plugs = windows (can't really mix them up)
Green plug = Front fogs
Blue plug = Rear fogs
Black plug = Not used on mine. Possibly rear window or A/C
They are keyed, so you shouldn't be able to mix them up.
__________________
CJJ is online now   Reply With Quote
Old 19-03-2008, 23:48   #2
CJJ
CJJ's Avatar
As with the upper plugs, you should unclip the plugs before removing them. You can see the lever that unclips on the side of these plugs. Just press these and pull the plug out. Pulling on the plug or wires without uncliping can damage the connections.
You can now remove the console. The picture shows the 2 lower clips and plastic lug. You can also see where they are normally located.
If you are replacing the console, like I did, or even swapping the gauge and clock over which is a popular mod as well, you will need to undo these 4 crosshead screws on the rear top of the console. This module holds the 3 upper clips and the gauge/clock.
You will also need to remove the radio/head unit cage from the old console and fit it in the new one. Normally it is just a case of unbending and bending some metal lugs.
If you are fitting a new console you will need to attach the Oil Gauge/Clock module, remove any switches and blanks from the old console and fit them into the new console. The switches simply push out from the back of the console and are fitted by pushing in from the front. The foglight switches etc are keyed and will only fit in their correct cutouts.
Now you are ready to refit the console.
Reconnect the plugs to the Oil Temp Gauge, Clock and Hazard switch at the top of the console.
Reconnect the window switches, fog light switches, and any other switches your car may have
Slide the bottom of the console in so that the 2 lower spring clips and the bottom plastic lug are correctly located. Then push the top of the console in until the 3 top clips locate.
Place the Gaitor back in place. I found it easiest to locate the top and left lugs in place and push the right and bottom lugs in place from underneath with a screwdriver.
Refit the radio/head unit and screw the gear knob back on.
And that should be it.
While the console was off I took the chance to move the fog light switches to the 2 nearest blanks to the drivers seat.
As mentioned before, the switches themselves are keyed
And will only locate into the correct space
This is overcome by removing the "key". I did this with a Stanley knife. The picture shows me cutting towards my hand, this is bad practice as if you slip you will cut yourself. This was the only way I could hold it and take a picture. Your hands, your choice.
So, get them consoles off and get them painted. No excuses now.
__________________
Old 20-03-2008, 04:58   #3
Baracus
Car: MGTF 180 Sprint
Baracus is a glorious beacon of lightBaracus is a glorious beacon of lightBaracus is a glorious beacon of lightBaracus is a glorious beacon of lightBaracus is a glorious beacon of light
Send a message via MSN to Baracus
Nice 1 Cjj
Baracus is offline   Reply With Quote
Old 20-03-2008, 05:03   #4
smokie999
Car: MG TF
smokie999 is just really nice. Awwsmokie999 is just really nice. Awwsmokie999 is just really nice. Awwsmokie999 is just really nice. Aww
brilliant thread only wish it had been there last week when i did mine lol
smokie999 is offline   Reply With Quote
Old 20-03-2008, 05:16   #5
Lee121
Now with added Orange
Lee121's Avatar
Car: TF135 and Skoda Octavia (surprisingly good!!)
Lee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant futureLee121 has a brilliant future
Nice one CJJ, looks fab
Pete, I think this deserves going on your website
CJJ why didn't you swap the clock and oil temp round......a really useful simple mod
__________________
Lee
Dee....R.I.P. Sadly gone, never forgotten
MG.....draining motorist's wallets dry since 1924
I can supply stripes and '85th' style door graphics in any colour, PM me for details. NB, It isn't a business, just a hobby!!!
Lee121 is offline   Reply With Quote
Old 20-03-2008, 05:26   #6
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
nice one CJJ
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 20-03-2008, 06:21   #7
Herbie
Werder Supporter
Herbie's Avatar
Car: MGF 1.8i & MGTF 1:18
Herbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these parts
Send a message via MSN to Herbie Send a message via Skype™ to Herbie
Very good CJJ. I hope you have checked the gearchange mech nuts and gave that area a good grease (moving parts) ?
__________________
Stephan Hebert
MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ
Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling
Herbie is offline   Reply With Quote
Old 20-03-2008, 07:42   #8
CJJ
CJJ's Avatar
Nah. To be honest it has never bothered me. My eyesight is good enough to see the gauge where it is.
To be honest, the fog light switches bugged me more. Why have blank switches next to the driver and live switches furthest away?
__________________
Old 20-03-2008, 07:43   #9
Bromsgrove man
just call me Chris.
Bromsgrove man's Avatar
Car: MGF VVC 75th Anniversary LE
Bromsgrove man has much to be proud ofBromsgrove man has much to be proud ofBromsgrove man has much to be proud ofBromsgrove man has much to be proud ofBromsgrove man has much to be proud ofBromsgrove man has much to be proud ofBromsgrove man has much to be proud ofBromsgrove man has much to be proud ofBromsgrove man has much to be proud of
Top guide
Bromsgrove man is offline   Reply With Quote
Old 20-03-2008, 08:08   #10
Fast Jan
is trying...
Fast Jan's Avatar
Car: TF 160
Fast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these parts
You make everything look so easy Me and Baracus had soooo much trouble getting the console and clocks out of the TFwhen we fitted the SSK even though we knew what we were doing!
__________________
Experience is a journey, not a destination
For Sale: **17" wheels & Toyo tyres**
Fast Jan is offline   Reply With Quote
Old 20-03-2008, 11:09   #11
Baracus
didnt we just lol.
those bloody clips drove us nuts lol
Old 20-03-2008, 11:14   #12
CJJ
CJJ's Avatar
Did you try levering them out instead of releasing them?
__________________
Old 20-03-2008, 11:26   #13
Baracus
tried releasing them but they wouldnt release for some reason. we managed it in the end though but it was quite alot of tuggin nice to practice on jans car 1st though before i ever have to do mine
Old 20-03-2008, 11:28   #14
CJJ
CJJ's Avatar
Yep, always good to practice on someone elses.
__________________
Old 20-03-2008, 11:29   #15
AutomanUK
Proud Owner
AutomanUK's Avatar
Car: MG TF160 Sunstorm
AutomanUK will become famous soon enoughAutomanUK will become famous soon enough
Excellent guide with super clear pics, thanks for taking the time and effort it will make life so much easier for those that follow
__________________
There's lots of things to think about, but nothing to worry about. UPDATED CAR PICS
AutomanUK is offline   Reply With Quote
Old 20-03-2008, 12:01   #16
mdenton
Car: Golf GTi
mdenton is up and running. Hey we all have to start somewhere.
Wink
great descriptions and pics. particularly the 'rings' showing exactly where these plastic clips etc are. i suspect there are plenty of console fronts with a clip or two missing
no excuse now though
mdenton is offline   Reply With Quote
Old 20-03-2008, 16:00   #17
Petevick
regained interest
Petevick's Avatar
now added to the How To - Interior section of my web site
__________________
Old 20-03-2008, 16:19   #18
MyRomeo
Car: Corolla T Sport 190 (Ex TF160)
MyRomeo is a glorious beacon of lightMyRomeo is a glorious beacon of lightMyRomeo is a glorious beacon of lightMyRomeo is a glorious beacon of lightMyRomeo is a glorious beacon of lightMyRomeo is a glorious beacon of light
Send a message via MSN to MyRomeo
a lot more professional than my method, remove gear stick thing, ram screwdriver in bottom clip, lever out. yank the whole thing off thinking its gonna snap any second...
nice writeup once again and the blue is looking tidy!
MyRomeo is offline   Reply With Quote
Old 20-03-2008, 16:41   #19
Fast Jan
is trying...
Fast Jan's Avatar
Car: TF 160
That was our method in the end too
__________________
Old 21-03-2008, 10:40   #20
jimlowe
Car: mgtf 160 citroen c5 2.2vtr diesel, harley v rod
jimlowe is up and running. Hey we all have to start somewhere.
hi i am a new member and have just bought a replacement centre console,and was wary of fitting it it but your how to is excellant.one point i'm not sure of though are the clips attached to the car or should they come the console. my new console has no clips attached.would have posted a pic but not sure how to.
jimlowe is offline   Reply With Quote
Tags
f/tf how to
You may not post replies
TF Centre Console in 25...can it be done? 25Exec MG/R Modification & Tuning 3 23-06-2008 16:53
tf centre console upgrade Yigit MGF and MGTF (Sponsored by MG Rover Parts Ltd) 1 21-02-2007 08:59
TF centre console jumpingjack MGF and MGTF (Sponsored by MG Rover Parts Ltd) 7 06-11-2006 22:45
Remove a Centre Console? lazy_dave Others 0 30-03-2006 17:54
Wanted - TF Centre Console andy@ukcars Wanted 4 05-05-2005 21:42
Terms and conditions of use
