fitting mgf light, wont come on with interior light - MG-Rover.org Forums
Old 24-04-2008, 14:22   #1
DavesRover214
Car: Rover 200 1999 1.4 16v 'Bubble Shape'
Starting a new thread rather than keeping hijacking old ones, I have searched but can't find an answer on the forum
Wired it up in accordance too the rovertech thread..
http://www.rovertech.net/forum/viewt...254506b2985c24
purple to purple / red
Green to purple wire
black to black
I can switch on the lights with the switches on the mirror but the lights wont come on via the door switch. I have checked both purple and green are receiving 12volts
Any one any ideas?
Thanks in advance
DavesRover214 is offline   Reply With Quote
Old 24-04-2008, 14:52   #2
MyMgCar.com
Car: R2h1zZle Vvf0sh1Zzle!!
Send a message via MSN to MyMgCar.com Send a message via Skype™ to MyMgCar.com
If you got it set up right, speak to Skrib as he has one in his car. He might be able to advise you better
MyMgCar.com is offline   Reply With Quote
Old 24-04-2008, 14:55   #3
DavesRover214
High, thanks for the input, I'll have a word
Regards
Dave
Old 24-04-2008, 16:22   #4
MyMgCar.com
No problem. Here's the link to his thread:
http://forums.mg-rover.org/showthread.php?t=237658
Old 24-04-2008, 22:37   #5
DavesRover214
Thanks again
Regards
Dave
Old 24-04-2008, 23:40   #6
DavesRover214
Forgot to say, I also have a green wire in the 'a' pillar, anyone know what this is for?
Old 24-04-2008, 23:47   #7
MyMgCar.com
just checked the guide on the zr forum and no mention of the wire just black, purple, red/purple. It says there is a green whit wire in the mgf mirror that connects to the purple wire in the a pillar
Old 24-04-2008, 23:58   #8
DavesRover214
black to black
Any one any ideas?
Thanks in advance
Cheers mate, looks like I'm correctly wired up according to the guides but it still wont come on with the interior light, dispite both the green and the purple receiving 12v. Does it say on the guide what the wires should be getting?
Old 25-04-2008, 10:08   #9
dR0Og
Car: MG ZR PTP R140 + Alfa Giulietta Veloce 170
The purple wire is a permanent 12V feed from the battery (this is so you can manually turn the lights on and off regardless of ignition switch position).
The purple/red wire is connected to the MFU (multifunction unit) and this is what does the dimming.
In normal use if you put a multimeter across this red/purple wire, it will show 12V line to earth but the light wont be on as it is the MFU that puts this red/purple wire to earth when it is triggered by the door pins (the doors pins are just earths to tell the MFU when a door is opened).
When a door is opened, the MFU then pits the red/purple wire to earth completeinig the circuit and puting the interior light on. To dim the light, the MFU begins to increase the resistance on the wire, reducing the volatge and dimming the light until the resistance on the red/purple wire is effectively so high that it reads as open circuit.
If you are sure you have got the wiring to the TF mirror correct, I would suggest swapping the connections to the purple and red/purple wires around to see if that makes a difference.
dR0Og is offline   Reply With Quote
Old 25-04-2008, 13:51   #10
DavesRover214
Thanks for the input, I'll have a go when I get the chance. Any idea what the green wire up the drivers 'A' pillar is for?
Dave
Old 26-04-2008, 11:35   #11
Dave
Car: MGZSTD - 150+bhp
Send a message via MSN to Dave Send a message via Skype™ to Dave
Dave
Came to do this today and have a problem
Wires in the MGF mirror
Purple
Purple/Red tracer
Solid black wire
Wires in the door pillar
Thick black with the interior light wires inside
Green wire
Black wire
I have connected the mirror as follows
purple to purple
purple/red to purple/red
I have a black wire in the mirror, and a green wire in the A pillar. Can i connect these together, so i can have the lights in the mirror switched on/off when i want them?
With how i have connected them at the moment, the lights come on with the doors open, and dim/turn off etc.
Where am i going wrong??
Idiots guide for install please!!!
Dave
__________________
Dave is offline   Reply With Quote
Old 26-04-2008, 15:49   #12
technozen
Mmmm....Rover..
technozen's Avatar
Car: 200vi & Freelander XEDi
Far, far easier to wire the mirror straight back to the courtesy light.
Use a straightened wire coat hanger to pull the mirror wiring through the headlining to the courtesy light
The light fitting should have two wires, a Purple and a Purple/Red, these connect to the same colours from the mirror.
The courtesy light is grounded via one of it's fixing bolts, the Black wire from the mirror needs to be grounded by the same fixing.
Job done.
The Green and Black wires in the A pillar are part of the sunroof circuit.
__________________
I offer FREE engine/alarm diagnostics and fob coding (incl. Pektron fobs) to mg-rover.org Supporters - details here.
Fob not working? Common faults and fixes here.
Pektron BCU/SCU Faulty? This may be of some help. Full SCU programming and repair services available.
Discounted SCU/BCU Full Relay Replacement Service - only for Supporters - details here
Replacement relays for the Pektron SCU available - .org Supporters buy 4, 5th is free - PM for details.
technozen is offline   Reply With Quote
Old 26-04-2008, 20:07   #13
Dave
Many thanks mate, worked a treat
So to sumerise:
Connect the purple wires to the corresponding colour wire within the courtesy light, and screw the black wire to the bodywork
Here are a few pics:
Wires in the 'A' pillar
Close up
Wire from mirror into headlining
Hope this helps.
Dave
__________________
Old 26-04-2008, 20:34   #14
ironeagleuk
ironeagleuk's Avatar
Car: Rover 25 1.4iXL
Thanks for the info guys....I may well tackle this tomorrow if I get bored sorting me foglights out
ironeagleuk is offline   Reply With Quote
Old 27-04-2008, 07:34   #15
DavesRover214
Job done.
So to sumerise:
Close up
Hope this helps.
Dave
Sounds good to me, sounds like I need to earth the black to the roof, I'll see how I get on....
Regards
Dave
Old 27-04-2008, 09:25   #16
Severance
You're up at 07:30 hrs on a Sunday morning doing this? That's commitment. Personally I'm mostly hanging over! Good luck
Sev
Severance is offline   Reply With Quote
Old 27-04-2008, 14:52   #17
DavesRover214
Sev
No mate, I had just finished night shift as a night porter at 7am and have just got home, checked messages and was just about to go to bed!!
Old 28-04-2008, 08:09   #18
Severance
Night shifts suck, I feel your pain.
Sev
Old 29-04-2008, 18:07   #19
DavesRover214
Well tackled this this afternoon and I'm still no further on, 1 question should I be getting 12v on both purple and the purple/red wires, if so that may be what my problem is.
Tried earthing the black direct to the roof and got the lights on permanently, I then tried swapping the wires over and that took me back to square one
Trying to do this in the rain so all answers welcome....
Old 29-04-2008, 19:43   #20
voodood
Car: MG ZT CDTI 135+
any chance of a pic of this all finished please
voodood is offline   Reply With Quote
You may not post replies
Interior light wont come on! Craig MGR 'R8' Rovers (aka Wedges!!) 40 17-09-2007 17:49
Interior Light MGF CuteMLC MGF and MGTF (Sponsored by MGF Mania) 3 03-06-2006 13:35
Boot lid interior light fitting montytheMG MGF and MGTF (Sponsored by MGF Mania) 10 23-09-2005 14:33
fitting new interior #2, srs light. dippy MGF and MGTF (Sponsored by MGF Mania) 2 19-05-2005 08:16
Fitting rear brake light on MGF percy4 MGF and MGTF (Sponsored by MGF Mania) 0 12-05-2005 07:31
