Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > How Do I - Answers To Common Problems.
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 29-04-2008, 10:02   #1
1955diesel
Car: Other Manufacturer
1955diesel has reached their true position at number 11955diesel has reached their true position at number 11955diesel has reached their true position at number 11955diesel has reached their true position at number 11955diesel has reached their true position at number 11955diesel has reached their true position at number 11955diesel has reached their true position at number 11955diesel has reached their true position at number 11955diesel has reached their true position at number 11955diesel has reached their true position at number 11955diesel has reached their true position at number 1
How To.... Diagnose a K Series Head Gasket Failure
The K Series engine has gained itself a bad reputation for head gasket failure and not without some justification. However, this has become something of a vicious circle with gasket failure often being diagnosed simply because “Rovers have gasket failure”.
The symptoms that do not usually, on their own, indicate failure –
Coolant Loss – almost always just a common coolant leak. If it is leaking past the head gasket, it will show up running down the side of the block, in the oil or in the cylinders (more on this later).
Oil Loss – probably due to leaks or oil burning. If due to the head gasket, it will show in the coolant as mayonnaise, but hardly ever as an external leak.
Overheating – mainly due to cooling system problems such as non functional fans, coolant leaks, sticking thermostats etc. but it could be caused indirectly by the gasket. If coolant is leaking past the gasket fire rings into the cylinders, then combustion gas will be leaking back the other way. In most Rover installations, this will quickly result in gas pockets forming in the heater/by-pass circuit causing the heater to go cold and the engine to boil up.
Loss of Performance – could be almost any combustion related fault, but almost certainly nothing to do with the head gasket. For a gasket problem to affect performance, it would have to be losing so much compression or consuming so much coolant that a major problem would be apparent. The exception here is when a head gasket leak has caused the system to boil up (see Overheating above). If this is not detected, the engine can become so hot that it begins to lose performance. This is a fairly terminal stage!
Mayonnaise under the Oil Cap or on the Dipstick – a very pale deposit of oil emulsion is common in winter and in engines where the oil never gets fully hot. Of course, it could also be the very early signs of gasket failure if associated with coolant loss, but let's not jump to conclusions just yet.
Steam from the Exhaust – Rovers tend to be steamy in winter. May also be made worse by an inlet manifold coolant leak.
Discoloured Coolant – if it looks like dirty water or there are solid deposits in the header tank, this is probably due to old coolant and system corrosion.
The symptoms that indicate a strong possibility of head gasket failure –
Mayonnaise in the Coolant Header Tank – a thick, creamy scum collecting on the tank walls and in the coolant. However, this could also be residue from an earlier failure as it is hard to clean it all from the system.
Emulsification of the Oil – not to be confused with light mayonnaise deposits, in this case, the oil itself will turn to the consistency of chocolate milkshake and there will be heavy mayo deposits (creamy sludge) under the filler cap. There will also be associated coolant loss. However, it can be a difficult call because minor mayo deposits may first show before they increase to this terminal state.
System Boiling due to “air locks” in the heater/by-pass – Rover cooling systems are poor at getting rid of gas. Air locks can result from running low on coolant and are usually first indicated by the heater blowing cold air instead of hot. If they keep coming back despite bleeding, it may be due to combustion gas escaping past the gasket into the system. This may occur due to low liner heights or softening and subsequent indentation of the head face. These will cause low clamping pressure on the gasket's fire ring and leaking of combustion gas past it into the coolant. Problems can also be caused by porosity of the head casting. These voids in the casting can be uncovered during skimming of the head face and it is recommended that the fire ring area is lightly peened to compact the surface before machining.
Coolant Leak running down the block – often from beneath the exhaust manifold this could be from the head gasket, but is sometimes from the inlet manifold gasket as it runs around the head joint before showing itself.
Are there any tests to confirm head gasket failure?
I’m afraid not or at least none that are 100% reliable. There are three commonly used tests, but none will give a definite answer.
Sniff Test – detects combustion gas in coolant. As mentioned above, Rover’s cooling systems generally become air locked and boil up at the first sign of combustion gas leaking past the head gasket. The test is also not that reliable in my experience giving both false +ve and –ve results on occasions.
Compression Test – measures pressure in the cylinder during cranking. If the gasket fire ring is leaking sufficiently for it to show on a compression test, you will already be experiencing persistent air locks in the cooling system.
Cooling System Pressure Test – may detect a head gasket leak, but the coolant loss will have already shown itself in the oil or externally.
So Where is my Coolant Going?
Coolant leaks can often be difficult to trace because they leave far less evidence than people are expecting. It is not often that they drip on the floor so that you can see where it is coming from.
The common leak points are -
Water Pump - you need to remove the cam belt cover to look for staining under the pump. They often dry before showing on the outside and can be intermittent.
Inlet Manifold Gasket - in addition to the obvious external leaks, they can leak internally directly into the engine intake ports. This can not be detected from the outside and replacement is the only real test. It may result in a start up misfire and extra exhaust steam. This is mainly a problem associated with the plastic manifolds. Metal ones such as VVC tend not to suffer, but are probably not immune.
Radiator / Hoses / Plumbing - most of the evidence will blow away in the wind or dry up so you are only looking for traces of staining and dried antifreeze deposits. There are common corrosion problems with the metal pipe running to the thermostat and also the under body pipes on MGF ect. The radiators on the MG seem to suffer badly too.
Coolant Filler Cap - a leaking cap can lead to unexpected boiling, but the venting of vapour can also show as a slow coolant loss.
See also -
http://forums.mg-rover.org/showthread.php?t=335685
I expect there will now be lots of posts about odd symptoms that were cured by replacing the gasket, but I suspect that many of these cures will be due to other changes made during the head gasket work. Eg. Inlet manifold gasket. Most of the symptoms are also subjective and hard to interpret without being there and having had past experience and there are always exceptions to the rules.
1955diesel is offline   Reply With Quote
Old 29-04-2008, 10:12   #2
slickman
slickman's Avatar
Car: betty and the BEAST
slickman is becoming God like round these partsslickman is becoming God like round these partsslickman is becoming God like round these partsslickman is becoming God like round these partsslickman is becoming God like round these partsslickman is becoming God like round these partsslickman is becoming God like round these partsslickman is becoming God like round these partsslickman is becoming God like round these partsslickman is becoming God like round these partsslickman is becoming God like round these parts
should be made a sticky, instead of the same question 3 times a day lol, "have i got HGF"
nice one deisel.
slickman is offline   Reply With Quote
Old 29-04-2008, 10:22   #3
MyMgCar.com
(Formally YTL2000)
MyMgCar.com's Avatar
Car: R2h1zZle Vvf0sh1Zzle!!
MyMgCar.com has a brilliant futureMyMgCar.com has a brilliant futureMyMgCar.com has a brilliant futureMyMgCar.com has a brilliant futureMyMgCar.com has a brilliant futureMyMgCar.com has a brilliant futureMyMgCar.com has a brilliant futureMyMgCar.com has a brilliant futureMyMgCar.com has a brilliant futureMyMgCar.com has a brilliant futureMyMgCar.com has a brilliant future
Send a message via MSN to MyMgCar.com Send a message via Skype™ to MyMgCar.com
Thats a lot of effort writing that, definitely should be a sticky mate
__________________
Click here for MyMgCar.com homepage or find us on ebay
Please PM or email enquiries to info@MyMgCar.com
MyMgCar.com is offline   Reply With Quote
Old 29-04-2008, 18:09   #4
1955diesel
For the uninitiated, emulsified coolant/oil looks like this -
although this shows oil contaminated with coolant, the coolant/oil mix you might find in the header tank looks similar.
(image borrowed from another post on this forum - not sure who to credit for it)
Edit: posted by MGFNorway. Thanks.
Old 29-04-2008, 18:11   #5
gotenks1321
is on the up!
gotenks1321's Avatar
Car: BRG MGF VVC & Charcoal MGF VVC
gotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant future
Send a message via MSN to gotenks1321
I think that's Broon's but might be wrong
__________________
Enclosed K&N, 52mm TB, Miltek, AP fast road clutch, WON Streetblaster 150i kit, Additional brake servo bracket, MS front 280mm brakes (Black Diamond drilled & grooved discs, Predator pads), 280mm rear brakes (Greenstuff pads), SS Braided brake hoses, TF solid subframe mounts, Polybushed, Lowering pins, Gaz adjustable shocks, MS bell crank, SEAT Leon front splitter, Alpine ICE, MKII center console, Colour coded interior
Has hydragas pump - will travel
gotenks1321 is offline   Reply With Quote
Old 29-04-2008, 18:57   #6
Swalesy
Swalesy is starting to get known about hereSwalesy is starting to get known about hereSwalesy is starting to get known about here
Brilliant mate Good job
As Slickman said this should hopefully stop the question being asked 3 times a day
Has this been made a sticky yet?
Swalesy is offline   Reply With Quote
Old 29-04-2008, 19:13   #7
Dr.Buck
Car: '03 MG ZR 105
Dr.Buck has reached their true position at number 1Dr.Buck has reached their true position at number 1Dr.Buck has reached their true position at number 1Dr.Buck has reached their true position at number 1Dr.Buck has reached their true position at number 1Dr.Buck has reached their true position at number 1Dr.Buck has reached their true position at number 1Dr.Buck has reached their true position at number 1Dr.Buck has reached their true position at number 1Dr.Buck has reached their true position at number 1Dr.Buck has reached their true position at number 1
Send a message via MSN to Dr.Buck
Thumbs up
Cracking little note there, diesel!
Point 5 under 'symptoms that do not usually, on their own, indicate failure' is helping with a bit of paranoia I keep getting (a thin layer of what looks like vaseline, rather than mayo, inside the oil cap every now and then, it comes and goes on it's own!)
+1 for sticky status!
Dr.Buck is offline   Reply With Quote
Old 03-05-2008, 08:22   #8
robchester
robchester is up and running. Hey we all have to start somewhere.
So is HGF common in all K-Series engines? I know that the 1.8 had a particular problem with the cooling system not being big enough but do the 1.4's and 1.6's suffer just as badly?
I had a 218iS a few years back (kinda miss it) and now im returning to cheaper motoring, i fancy picking up a very affordable 25 but avoiding the 1.8 as mine too suffered HGF
robchester is offline   Reply With Quote
Old 03-05-2008, 08:48   #9
1955diesel
Yes, they all suffer apart from the earlier wet liner engines. The reasons are multiple and the occurrence almost random.
Old 03-05-2008, 09:00   #10
Rovernut
Two Tourers and a Cabby!
Rovernut's Avatar
Car: 75 and 416 Tourers, Cabby 1.6
Rovernut has a spectacular aura aboutRovernut has a spectacular aura about
With my experience of owning three k series cars which have all had gaskets replaced, I would like to humbly suggest another clue.
When you start it up in the morning and it seems to run on 3 cyls for a few seconds, I reckon that'e due to a gasket leaking coolant into that cylinder.
Anyone else experience that?
Chris
__________________
Rovernut is offline   Reply With Quote
Old 03-05-2008, 10:15   #11
skrib
Stop buying cars Skrib!
skrib's Avatar
Car: 25 gti & Bora TDI S
skrib has much to be proud ofskrib has much to be proud ofskrib has much to be proud ofskrib has much to be proud ofskrib has much to be proud ofskrib has much to be proud ofskrib has much to be proud ofskrib has much to be proud ofskrib has much to be proud of
Send a message via MSN to skrib
my cars silver does it have hgf?
__________________
Please check out my ebay listings - HERE
skrib is offline   Reply With Quote
Old 03-05-2008, 10:16   #12
skrib
skrib's Avatar
Chris
just out of interest cos i dont think ive ever experienced this......how woudl u know ur runngin on 3 cylinders.?
__________________
Old 03-05-2008, 10:17   #13
1955diesel
Sounds more like inlet manifold gasket if there are no other symptoms.
However, there are always exceptions with engines. After working with them all my life, they can still catch me out.
Old 03-05-2008, 10:26   #14
skrib
skrib's Avatar
where on the engine would u be able to see this leaking?
__________________
Old 03-05-2008, 11:08   #15
MGJohn
MGJohn's Avatar
Car: MG Montego Turbo + R620ti & MGZS
MGJohn has reached their true position at number 1MGJohn has reached their true position at number 1MGJohn has reached their true position at number 1MGJohn has reached their true position at number 1MGJohn has reached their true position at number 1MGJohn has reached their true position at number 1MGJohn has reached their true position at number 1MGJohn has reached their true position at number 1MGJohn has reached their true position at number 1MGJohn has reached their true position at number 1MGJohn has reached their true position at number 1
A friend had her R25's cylinder head gasket replaced along with a replacement cylinder head recently. Within a few miles of having the job done, the car boiled over and had to be recovered by trailer.
I looked at the car and offered to replace the cylinder head gasket again with the multi layer type and its head saver shim. Actual replacement of the cylinder head gasket was a doddle. Cleaning all the oil-coolant mix from the engine and the whole of the coolant system wasn't ~ it was a lot of work.
What I found was during the previous repair, the essential dowel which not only locates the cylinder head correctly to the block, but also encloses the essential oil supply to the over head camshafts .... was missing! This allowed the engine oil being sent at high oil pump pressure to the Over head cams to be diverted into and around the cylinder head and its gasket. This in turn meant it was sent into the cooling passageways and the rest of the cooling system at oil pump pressure. I fitted two new steel dowells in place of the nylon ones which very positively located the cylinder head and, more importantly, enclosed that oil supply.
To the inexperienced, at first this would appear to be yet another misleading "They all do that ~ repeat HGFs are common ~ well known fact" scenario.
WRONG >>>>!!!!
This is yet another example of incompetent repair workmanship. Apart from that one little (BIG!) omission, they had done an excellent job. Since I repaired the engine, the car has done in excess of 1000 miles including several long motorway speed runs so far without further incident. The odd trace of oil has appeared in the coolant bottle ~ I suspect that is remnants from the previous failure which no matter how carefully and thoroughly you clear out the old much from the previous 'failure', a few globs of the stuff still lurk in the corners of the cooling system. This is what the stuff looked liked when I flushed the totally blocked core of the radiator:
This is what I saw when i first lifted the bonnet:
and on removing some cooling pipes and radiator:
The stuff was everywhere and took several hours of cleaning to get rid of most of it from engine and cooling system.
The full story can be found on this thread:
http://forums.mg-rover.org/showthread.php?t=234493
This is one of the worst cases of incompetent repairs I've ever seen on a car and I've seen many such over the years I've been driving. In conclusion, please remember this:
THEY DO NOT ALL DO THAT!
Only some.....Unfortunately, due to incessant K-Series media negativity overkill ~ that is a LITTLE known fact.
__________________
Some people think it's all Rover .. BMW ......... It is now!
MGJohn is offline   Reply With Quote
Old 03-05-2008, 11:26   #16
1955diesel
(inlet manifold gasket)
They often leak coolant internally into the inlet port. The only way to tell if this is happening is to replace the gasket. New ones have a different profile and material (green colour). This is usually done when the head gasket is changed so the symptoms stop even though the head gasket was not the cause.
Old 03-05-2008, 11:31   #17
skrib
skrib's Avatar
sounds like peopel could cash in on this...
__________________
Old 22-05-2008, 01:12   #18
ronaldbegg
Location: Ocean Grove, Australia, near the Great Ocean Road
Car: MGF
ronaldbegg is starting to get known about hereronaldbegg is starting to get known about hereronaldbegg is starting to get known about hereronaldbegg is starting to get known about here
Send a message via Skype™ to ronaldbegg
Great thread
I will book mark this thread for future reference.
ronaldbegg is offline   Reply With Quote
Old 22-05-2008, 09:35   #19
SnapdragonGT
Car: Rover 25, Maestro 16v trackcar (currently having a Volvo T5 transplant).
SnapdragonGT is a splendid one to beholdSnapdragonGT is a splendid one to beholdSnapdragonGT is a splendid one to beholdSnapdragonGT is a splendid one to beholdSnapdragonGT is a splendid one to beholdSnapdragonGT is a splendid one to beholdSnapdragonGT is a splendid one to beholdSnapdragonGT is a splendid one to behold
As several others have said, this should be made into a sticky, well done for the write up 1955diesel, and also for your contributions, John.
I'll contact admin and see if they can do it, as having a quick ref guide like this would potentially save a lot of worried owners from having to post threads with their concerns.
Excellent!
SnapdragonGT is offline   Reply With Quote
Old 24-05-2008, 08:07   #20
atoms
Car: MGF 1.8 VVC Mk2 Tahiti Blue
atoms is up and running. Hey we all have to start somewhere.
Excellent, clearly laid out description of the HGF symptoms, I would also like to see this as a sticky.
A similiar one on VVC camshaft failure symptoms in a similiar vein would also be good. I guess the belt failre symptoms are clear enough
Thanks 1955 Diesel
Alan
atoms is offline   Reply With Quote
You may not post replies
Head Gasket Failure after Land Rover Gasket Fitted? PERRY-MGTF MGF and MGTF (Sponsored by MG Rover Parts Ltd) 149 07-10-2009 14:48
What makes the k series so soft to head gasket failure? Dugie 214 MG ZR / Rover 25, 200 & Streetwise 6 08-02-2008 13:28
L series head gasket failure? Benny Dub Diesel Forum! 17 19-08-2007 10:07
216 (K Series) head gasket failure ( I guess) Ian Senior Others 0 14-03-2005 08:00
Terms and conditions of use
