how do I Programming replacement key for 2004 model Rover 75 TOURER - MG-Rover.org Forums
Old 27-06-2008, 07:05   #1
scuba06
Car: Rover 75
I've just received my new replacement spare key for my 2004 Rover 75 CDTI Tourer (I only got one key when I bought the vehicle recently). But ı dont have barcode number for the key and EKA for my car. I was asking the rover service in my country but they told me needs at least EKA four digits number for my car but I am the second user for this car and the first user lost the card of EKA. anybody help me if I tell chase number for my rover75?
my chase number is: *removed for security reasons*
I'm sure I've seen how to do this somewhere, but for the life of me can't find instructions now, and a search of this site didn't produce the goods. Can someone tell me step by step what to do?
thankss
scuba06 is offline   Reply With Quote Quick reply to this message
Old 27-06-2008, 08:43   #2
cjmillsnun
Car: MGF Trophy 160 in Trophy Yellow
Send a message via MSN to cjmillsnun
thankss
Are you sure this was a new key? They come with barcode attached and cut for the car. If you bought a second hand key from eBay then you are scuppered as it is useless. You may as well just throw it in the bin.
There is no EKA on the Rover 75 or MG ZT the system uses the BMW EWSIII which only works from the transponder chip in the key. The transponder chip is pre programmed for the car by BMW before the key is sent to the Rover agent with the barcode for the remote part to be coded to the BCU of the car.
cjmillsnun is offline   Reply With Quote Quick reply to this message
Old 27-06-2008, 17:09   #3
scuba06
Car: Rover 75
Thanks cjmillsnun
yes you are right my key is not brand new it is my less english foult, I took that key from my brother he has 2 more rover 75 and more enough key for them and I take it one of it and try to use for my car, as an result ı can understant your writing if ı dont have an barcode for the key I dont have an chance to use it for my car isnt it, than I need to find key with barcode on ebay, I hope it will solve my problem
many thankss
Old 27-06-2008, 17:33   #4
cjmillsnun
Thanks cjmillsnun
many thankss
No you need to order a new key!
otherwise the key can only be used with the remote fob to unlock and lock the car. To use the key to start the car you need a key that is specific to your car.
Old 27-06-2008, 17:36   #5
NickTL
Car: Range Rover Sport
The transponder chip in the key is a pretty standard type made my philips I believe. Most high street key cutting/coding shops should be able to read your ignition key then programme the imformation to your new key and cut it using your own key as a pattern for about 20.00. Will be OK to start your car and open the doors using the key but you won't be able to use remote.
Nick.
NickTL is offline   Reply With Quote Quick reply to this message
Programming replacement key for Rover 75 KV6 Rowland Ward MG ZT / Rover 75 (Sponsored by Rimmer Bros) 11 14-11-2011 21:28
Vibration on Tourer late 2004 Model northstand MG ZT / Rover 75 (Sponsored by Rimmer Bros) 5 27-10-2007 21:41
98 rover 75, key fob programming azza125 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 12-02-2007 20:09
Rover 75, key programming prob,.? Mobilemick MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 05-03-2005 05:44
Rover 75 - 2004 Model Year Revisions Ian MG ZT / Rover 75 (Sponsored by Rimmer Bros) 21 13-11-2003 21:35
