#1 | |
Grade A mentalist
How to: Replacing suspension bushes (rear) on MGF-the easy way
Needed to replace bushes on my shock absorbers (dampers). I know they ar enot polys, but for £1.60 each, if they last another 8 years, then I am not complaining
![]() Looked at excellent how to on Rob Bells site. This involved removing dampers. Not a problem...on paper. Couldnt get a good enough grip on top part of the shock to remove top bolt. So I thought...do I need to remove damper... No I didn't. Thought it was just easy cos my bush was so knackered, but on the other side, the bush was in better condition and I still did it without removing anything on car, just 1 bolt ![]() So , I will skip obvious stuff such as removing wheels and using axle stands for safety, as this is obvious. Here is the shock absorber with bush at bottom. This was easily moveable with my fingers...bad times.. ![]() This bolt is 17mm, not 14 as mentioned on Rob Bells site. However most sockets wont fit over the bolt, so you need a deep socket. I had a double ender I use to remove wheel nuts, 17 on one side, 19 on the other (19 for the wheel nuts), and this worked a treat. You need to hold the nut at the other side with a socket/wrench or an adjustable wrench. ![]() Caution though the bolt on the bush side was well rusted on and this happened to my first 13mm socket. Found a HF Pro one which is good quality and that did the job. You may also want to lube the end of the bolt with release oil for 5 mins or so as this is very rusty and its hard to get the nut off the last bit. ![]() Anyway, when nut comes off, remove the bolt, a spacer and 2 washers will fall out. The washer goes against bush, the spacer against suspension parts. ![]() The first bush just pushed out by hand, as did the central metal tube (can't think of a good name just now). The other side was in better nick though and in order to get metal tube out I had to use mole grips and a small socket with tapered end. Pushed the small end into tube then presses it through with moles grips. ![]() Next the bush, again much tighter this time. Used a screwdriver and it was easy enough to persuade out. ![]() Here is old bush (worn) and new one. Cost, £1.60 from Rimmers ![]() ![]() ![]() To replace, this is where a vice comes in handy. Not ideal if you are doing it on the car, but my vice was small enough to do the job, I reckon it would also be possible just using mole grips etc. ![]() Anyway lube up the rubber , I used white lithium grease, dunno if thats OK or not. I assume it wont perish the rubber though. The bush simply presses in by hand.I then used the vice to insert the metal tube into the bush. Finished it off using mole grips. Or another tip here Quote:
![]() Now, in true Haynes fashion, fit in reverse ![]() The nearside one had an extra bracket which attaches to a cable to the brakes. This remains attached though, so its difficult to not remember to connect it. ![]() Whilst wheel was off I changed my chavvy red rear calipers to silver, to match the front. Bit less "show off" than red, but better than rusty metal.
#2 |
Car: MGF
Hi Broon.Who is this Rimmers and where do I find him......
#3 |
Grade A mentalist
Rimmer Bros, sell nearly every single part for MGFs/TFs
Have a funky online catalogue too http://www.rimmerbros.co.uk/ |
#4 |
Meg is a nightfire babe!
Location: SE London Car: 1998 MGF 1.8i Nightfire with TF Front & 1996 Amaranth F called Fleur!
Blimey Broon I just fiddled with adding rubber washers on the bushes to sure them up a bit and now I find the bushes are only £1.60 - blast you now I want to do it all again! (although my washers did cost nowt as they were in my tool box!)
__________________
How-To's: Glass Rear Screen on a standard hood! Shorten your OEM windstop DIY Compliance Washers R25 Cubby into an F dash Pictures of Meg |
#5 |
Grade A mentalist
Yep, 1.57 includsive of VAT
#6 |
regained interest
nice work broony
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#7 |
Car: MGF
Cheers Broony.Appreciated mate.Just gotta ask yer.Why did yer change them besides the obvious of they looked crap.Was there a problem with suspension was a bit shaky or what.
#8 | |
Grade A mentalist
I already had to change the tie rod bar thingmy last year too, due to perished rubber. I dont think it helps that my suspension is needing pumped and has done for several years ![]() I went for a drive tonight and its quite a startling difference in ride quality!! Going for a decent windy road trip tomorrow should be able to confirm. |
#9 |
Car: MGF
Just changed the anti roll bar links as they were perished.Changed me wheels as they had a wobble on the front.Difficult to balance.Changed the brake caliper as was seized but still av a bit of a wobble somewheres.Seems to be a bit shaky everytime yer hit a slight bit of rough road.Whilst doin the roll bar links,had a look at the damper bush.Moves around quite a bit so guess it may be gone.Noticed that the offside disc may be slightly warped as well,so this may be the prob......
#10 | |
Grade A mentalist
![]() I guess a warped disk would give you wobble |
#11 |
Car: MGF
Contacted Rimmers today.They cant find these bushes anywheres.Can you get me a catalogue or ref number and I will ring em back....Cheers
#13 |
The futures orange
Location: Fife Scotland Car: MGF VVC 75th ANNIVERSARY & TF LE500
Nice idea getting the vice to put the bush on with
- these can be a real struggle to fit - they were on the Morris anyway - it took 2 of us to get the bushes in place
#14 | |
is back - in black
Location: North Cumbria Car: MGF mk2 Freestyle 1.8mpi 16" wheels
David Last edited by Aiketgate; 30-06-2008 at 23:23. |
#15 |
Car: MGF
Hi Aiketgate.Do you know if they differ from the rear ones.Sent for them yesterday and hopefully they will arrive tomoz.Not sure if the rear ones need doin so was goin to put em on front.If yer know,please enlighten me....Cheers
#16 |
Grade A mentalist
They must be different if they have different part nos I guess
#17 | |
is back - in black
I honestly don't know. Looking at them on the car, I assumed they were all the same, but seeing the different part numbers make you think. Having said that, Mike Satur sells a poly set and all four corners look identical; as do his shocker set. It looks as if you'll have to tell us when you get them! David |
#18 | |
Grade A mentalist
Looking forward to it
#19 |
Werder Supporter
Broon, did you tighten the lower bolt under full load at last ?
__________________
Stephan Hebert MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling |
| Bookmarks |
| Tags |
| mgf how to, rear suspension |
| Thread Tools | |
| Replacing Suspension rubber bushes on 414i | makoto | MG ZS / Rover 45 & 400 | 10 | 02-11-2008 15:09 |
| Rear Suspension Bushes | craigymusicman | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 8 | 27-01-2006 20:21 |
| Rear Suspension bushes | 220coupe | Others | 0 | 15-08-2005 11:49 |
| 620 rear suspension bushes | RobbyBoy | Rover 600 | 0 | 01-08-2003 21:14 |
