#1 |
Mudslinger extraordinaire
Location: Ashington, Northumberland Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
Sticking Handbrake Sorted
After fixing the exhaust yesterday I went to move the car and found that the rear offside brake was sticking.
This has hppened before but usually releases with a clunk when the car ismoved. Not this time though. Took the car for a test drive to check the exhaust and came home with smoke and burning brake smell trailing behind. Also noticed that the handbrake wasn't returning fully down and was bouncing a bit, causing the handbrake light to flash when going over bumps. So, I could buy a new calliper or attempt to fix the problem. I decided to strip the brake and see if I could see what the problem was. For those who want to strip the brake caliper down, you may want to have a look at this how to, which describes the process http://forums.mg-rover.org/showthread.php?t=199027 After stripping down to the calliper I concentrated on the handbrake mechanism. This is a common problem on the TF. I did try disconnecting the cable, but gave up afer about an hour of trying to get the pin out. I managed to remove the retaining clip from behind, but could not remove the acual pin. I assume it screws out, but I just couldn't get it to budge so I settled for spraying it and freeing up the linkage. The mechanism itself seemed a bit sticky, so I chocked the front wheels, released the handbrake and stripped the calliper down, removing the pads etc. I then sprayed the mech with WD40 and worked it backwards and forwards. If you do this be warned that everytime you do it the piston moves out a bit more due to the adjusting mechanism, so you have to stop every now and again to wind the piston back into place (see the link above on how to do this). The mechanism still wasn't returning fully so I watched it while operating. It seemed that the plate that has the end stop on was rubbing against the stop/spring attachment post (the mushroom shaped object) which was causing it to stick. I held the mechanism fully on and filed the plate a little and cleaned any corrosion and brake dust off it and the post. I then sprayed lithium grease on the mechanism to lubricate it. Moved it around a bit to free it up and all seemed well in the world I then refitted the spring and tried the mechanism. It now returns fully of it's own accord. Sorted. Another spray of Lithium grease over the spring and workings and it was ready to put the car back together. Replaced the wheel and stamped on the brakes and operated the handbrake a few times to allow the adjuster to take up the slack. Spun the wheel by hand and it moved freely Took the car for another test drive and it was superb. I felt as though I had gained 20bhp. Sorted.
__________________
#2 |
Werder Supporter
You're busy boy actually aren't you CJJ ? Glad you got it sorted, I had to change the whole caliper
![]() Well done mate, fantastic pics, work and write-up
__________________
Stephan Hebert MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling |
#3 |
I was thinking of changing the calipers, but, you know me, I had to tinker first. Saved a bit of money.
__________________
#4 |
regained interest
thats brillinat CJJJJJJ, top marks and rep if I can
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#5 |
regained interest
__________________
#6 |
Yey, I've become an acrowhotsit. Does life get any better?
I'd like to thank everyone who made this possible, My mam, my dad, my psychiatrist, all of my other personalities..................................
__________________
#7 |
Moderator
A word of warning, I then Luffield did something like this last year and it worked for about 50 miles and then it seized in a big way taking the disc and pads with it. Worth keeping an eye on.
The N/S caliper has gone so after some debate I am going to put a new one on although that should leave me with the old one to play with.
__________________
Proud Member of the HD-HU-CGAF Club. North Leicester MG Club: www.northleicester-mg.org.uk |
#8 | |
regained interest
__________________
#9 | |
How much you paying for a new caliper?
__________________
#10 |
Moderator
Just over £100 in VAT from Xpart, but it doesn't sound like they are that readily available.
__________________
#11 | |
is trying...
I got both of my new calipers from this ebay shop http://stores.ebay.co.uk/PARTS-CENTRE-UK - I think they were £75 each incl postage As far as I'm aware they were brand new - they are listed as new and certainly didn't look like re-furbs
__________________
#12 | ||
regained interest
__________________
#13 |
is trying...
I must have been blinded by the shinyness of them - I didn't realise they were indeed re-furbs
![]() And I would probably never have known if you hadn't said...
__________________
#14 | |
regained interest
__________________
#15 |
is trying...
No point in deleting, i'm quite used to being a bit of a pillock and at least now I won't be telling everyone I bought brand spanking new ones for £65
__________________
#16 |
Location: Zeist, The Netherlands Car: MG TF 135 Trophy Blue RHD Originally on 03 plate
Very good right up as always CJJ!
Is it just me or am I missing axle stands....
#17 | |
You are correct. And I don't condone it, but my new jack is quite safe and I stuck the wheel under a load bearing point so that if it did fail it would only drop an inch before resting on the wheel. I would always recommend axle stands though.
__________________
#18 |
Mmmm, sorry to be a spoilsport
, but I've got my hands on FastJan's old units to play with and it's not that simple.The "seizing" that people experience is not normally in the hydraulic bit, but in the mechanical linkage. The pistons on Jan's old units were near enough perfect, however the linkage that uses a wedge to push the piston out was very, very stiff. I managed to get the stuff out of the interior of the piston with circlip pliers, but the mechanism in the casting is held in by another circlip which is deeply recessed, and I can't get at it - yet The bit on the outside with the return spring is easily clened off, but the shaft comes out from inside the casting, when presumeably all the rest of the bits fall out as well!! Hmmm, a new circlip plier thingie is called for
#19 |
Ah, but mine is fixed (for the moment). Might have just be a different problem. Just have to wait and see how long it lasts.
__________________
#20 | |
is trying...
__________________
| Bookmarks |
| Thread Tools | |
| ZT Handbrake sticking on curb side | mbradley82 | MG ZT / Rover 75 | 6 | 07-02-2010 12:23 |
| Handbrake sticking | Phil | MG ZT / Rover 75 | 3 | 22-12-2007 16:53 |
| sorted ! | pumamc | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 7 | 13-08-2005 23:01 |
