Old 30-06-2008, 14:59   #1
CJJ
Mudslinger extraordinaire
CJJ's Avatar
Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1
Finaly replaced disc locating screw
While I had the rear offside brake stripped to sort out the stick handbrake, I decided to drill out the broken disc retaining screw.
I bought 8 stainless screws off e-bay before christmas, and they have been sitting in the garage since.
After removing the disc (see here for further details http://forums.mg-rover.org/showthread.php?t=199027 or here fro the front discs http://forums.mg-rover.org/showthread.php?t=197579) it revealed the broken screw.
A nice heavy blow with a centre punch will provide the start for the drill and may even free the threads up a little.
The next step was to drill down the centre of the screw
to allow access for the screww extracor. For those of you who have never used one of these, it is a bit like a big self tapping screw with the opposite thread to that which you are trying to remove. You tighten it into the hole, screwing it the opposite way to tightening the screw, and the theory is that it bites in and undoes the remains of the screw. That is the theory, but it very rarely works, unless the screw is fairly loose in the first place.
So, that didn't work. Don't apply too much force as the extractors are hardened and brittle. If they snap in the hole and cannot be removed you are stuffed as you cannot drill these.
The next step was to use a bgger (5mm) drill)
and tap a 6mm thread which is the normal thread of these bolts. This could work, or could end up a mess as you are tapping a 6mm thread into an existing 6mm thread and could just end up stripping out the existing thread. It is worth a go, as the next step would be drilling a larger hole and tapping and fitting a larger, non standard, screw.
Well, the operation was a success. I now have 2 nice new stainless screws in the rear offside disc.
Now that just leaves the other 3 discs.
__________________
CJJ is online now   Reply With Quote
Old 30-06-2008, 15:08   #2
Herbie
Werder Supporter
Herbie's Avatar
Car: MGF 1.8i & MGTF 1:18
Herbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these parts
Send a message via MSN to Herbie Send a message via Skype™ to Herbie
Quick, hide the
WD40
before Chris / Pete spot the tin
Nice work, bet you feel a bit better now ...
__________________
Stephan Hebert
MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ
Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling
Herbie is offline   Reply With Quote
Old 30-06-2008, 15:10   #3
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
blimey, you've been a busy boy
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 30-06-2008, 15:20   #4
shonky-25TD
Car: Rover 25
shonky-25TD is up and running. Hey we all have to start somewhere.
HMMMM i had recently posted another thread about a similar screw but on the drums. I certainly didnt realise you could simply re-thread the hole the same size, as per your post i thought it would just disintergrate. Now i no you can im not so fussed that i may have to drill out the screw.
Thanks for this post, it has helped loads.
shonky-25TD is offline   Reply With Quote
Old 30-06-2008, 16:18   #5
Chris T
Moderator
Chris T's Avatar
Car: MG TF 135 Platinum Silver
Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1
Great how to, must do the screws for the O/S front disc.
__________________
Proud Member of the HD-HU-CGAF Club.
North Leicester MG Club: www.northleicester-mg.org.uk
Chris T is online now   Reply With Quote
Old 30-06-2008, 16:48   #6
Petevick
regained interest
Petevick's Avatar
Originally Posted by Chris T View Post
.....must do the screws for the O/S front disc.
we could have screw removal day, both my rears need doing
__________________
Old 30-06-2008, 17:33   #7
rossocorsa
Car: TF135 CELESTIAL BLUE, 03 MG ZT CDTi 'the grey whale', LANCIA BETA VOLUMEX COUPÉ
rossocorsa has much to be proud ofrossocorsa has much to be proud ofrossocorsa has much to be proud ofrossocorsa has much to be proud ofrossocorsa has much to be proud ofrossocorsa has much to be proud ofrossocorsa has much to be proud ofrossocorsa has much to be proud of
did my front discs and pads (APs)last week got two screws out no problem with air impact other two decided to sheer off half way out, drilled tehm out and retapped threads as per above was absolutely fine in the end! Pins in the calipers were another issue lots of cussing and swearing anyway a tip on these get some wet and dry and sand the pins whilst in situ to remove as much rust and crap as possible otherwise they come partly out and then get stubbornly stuck as i found to my cost! got it all done in the end though !!!!
rossocorsa is offline   Reply With Quote
You may not post replies
Brake Disc Screw andymitton MG ZR / Rover 25, 200 & Streetwise 19 12-02-2008 21:13
Replacing discs and pads.. pads done... disc screw... oops ChrisTromans MGF and MGTF (Sponsored by MG Rover Parts Ltd) 20 12-03-2007 12:00
R220 262mm brake disc query - Strange cut on lip of 1 disc. G13SJC 'R8' Rovers (aka Wedges!!) 21 11-03-2006 21:19
Terms and conditions of use
