rover 45 turbo diesel? - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > Diesel Forum!
Old 16-07-2008, 17:13   #1
benno220
Car: ZR TD,ZS FACELIFT TD
Send a message via MSN to benno220
HI ppl
Thinking of buying a X reg 2000 rover 45 turbo diesel,just wanted to know did they upgrade the engine from the old sdi one that was in the 420 and 220sdi?
benno220 is offline   Reply With Quote Quick reply to this message
Old 16-07-2008, 17:16   #2
mooey65
Car: 306 Hdi
Originally Posted by benno220 View Post
HI ppl
Nop just the way it is fueled.
mooey65 is offline   Reply With Quote Quick reply to this message
Old 16-07-2008, 17:20   #3
E_T_V
Car: Maestros, 200, 600, ZTT
Fuel system is "upgraded" to give more torque but the actual engine is the same apart from the cambelt tensioners which are manual rather than automatic and so the belt intervals are halved on the newer engine.
E_T_V is offline   Reply With Quote Quick reply to this message
Old 16-07-2008, 17:20   #4
benno220
so its still the same bhp as the old sdi?
Old 16-07-2008, 17:22   #5
mooey65
Car: 306 Hdi
200/400 = 103/105bhp
45/25 =99/115bhp Can be remapped for a good gain. SDi injectors fitted ect ect
Old 16-07-2008, 17:36   #6
benno220
so being a X plate 45 it would be the standard 103bhp?
Old 16-07-2008, 17:39   #7
mooey65
Car: 306 Hdi
Some thing about a flag on the rear wing means its a 115 but don't quote me on that am not sure at all sorry.
Old 16-07-2008, 17:42   #8
mooey65
Car: 306 Hdi
45's can both be mapped the same its only the map that's different the 99bhp model and the 115bhp model.
I can't be any more help as i drive a sdi sorry.
Old 16-07-2008, 17:48   #9
p_b82
Car: ZS+ 170TD
if it came out the factory on the higher map it will have a 83KW sticker on the passenger door pillar...
also if it has rear drums it may be the lower power, but not always....
from my memory of driving both before i got mine, the 101 model did not feel like the turbo spooled up until 2K where as the 115 is going at 1800ish....
also stick your reg plate in a insurance website and see what is returned....
As mentioned you can get either remapped to the same level afterwards if you do have 101 and it is too low power for you
HTH
Pete
p_b82 is offline   Reply With Quote Quick reply to this message
Old 16-07-2008, 17:54   #10
benno220
Thanks guys for your advice
will let you know how i get on,GOING TO BUY IT ANYWAY
X reg ROVER 45 td 116k FSH cambelt just done, 800
Old 16-07-2008, 17:57   #11
mooey65
Car: 306 Hdi
One Word...........
Bargain
Old 16-07-2008, 17:59   #12
benno220
YEP
thats what i thought,ive got the sdi 220 1998,but need more luxury and space
definatley worth a few power mods if the 45 looks ok
Old 16-07-2008, 18:15   #13
mad
Car: mg zr t16 mk2, mad r25 td, anni golf tdi, mondeo st tdci
Send a message via MSN to mad
thats a real bargian, wish i lived in england sometimes
mad is offline   Reply With Quote Quick reply to this message
Old 18-07-2008, 14:29   #14
benno220
Got the rover 45,great car,very sluggish and noticed the actuator on the turbo has loads of adjustment,so i think i will give it a little more boost and fit my k&n for now and see what happens.
Old 18-07-2008, 20:05   #15
SDI_Tim
Car: MG ZS+ TD135+
K&N's don't filter very well. You could get a Green, ITG or BMC for decent filtration, some might be better than others. Even paper filters flow okay.
SDI_Tim is offline   Reply With Quote Quick reply to this message
Old 19-07-2008, 17:59   #16
benno220
fitted the K&N sounds nice but the car has no guts reallychecked intercooler pipes for splits etc,so decided to turnthe boost up on actuator and runs a bit better more responsive in 4 and 5th gear
think a tu1 box may be next.
Old 19-07-2008, 18:04   #17
Dakta
Diesel Tuning Dude
Dakta's Avatar
Car: 75 Tourer Conn SE & 45 TDi VNT
Send a message via MSN to Dakta
TU1 isn't for the 45. You'l want a good old fashioned remap.
__________________
Dakta is offline   Reply With Quote Quick reply to this message
Old 19-07-2008, 18:20   #18
benno220
is the tu1 box not for the 45 then,as i have a sdi 220 1998 and its the same engine mate.
my 45's is gutless under the 2500 mark,just been reading about the mafs in stickys section
Old 19-07-2008, 18:28   #19
Dakta
Diesel Tuning Dude
Dakta's Avatar
as said, the fuelling setup is different on the 200/400 to the 45.
The setup from 400 to 45 is different in the way SD to SDi isn't the same, same block, big differences to tunability.
For example the vp30 has its map stored on pump if I recall correctly, where on the sdi's it's in the ecu. Also the sdi's use the MAP sensor to asses air before deciding on the fuelling where the 45's would use the MAF sensor.
As you can see therefore plugging a tu1 into the map sensor would not increase performance as the ecu wouldn't adjust the fuelling due to adjusted map figures.
__________________
Old 19-07-2008, 19:09   #20
benno220
i think i will have a chat to pocketbikeuk then see what he can do
whats your running at the moment?
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Rover 45 Turbo Diesel georgiansoccer MG ZS / Rover 45 & 400 2 11-04-2008 21:35
Rover 45 turbo diesel saloon model samwilson1 Wanted 4 10-10-2007 21:58
Rover 45 2.0 Turbo Diesel Loss Of Power owenwesco MG ZS / Rover 45 & 400 4 08-04-2006 17:23
Rover 45 2.0 turbo diesel marcmc MG ZS / Rover 45 & 400 11 16-08-2005 21:36
rover 45 turbo diesel engine problem 45diesel MG ZS / Rover 45 & 400 3 28-06-2005 06:00
