head gasket change advice, rover 45, HEAD GASKET NOT YET GONE, BUT OBV ON IT WAY OUT - MG-Rover.org Forums
Old 18-08-2008, 14:05   #1
rovermatt
Car: Rover 45
hey
i have a rover 45 1.4 03 plate 37k
its drinking loads of coolant and misfiring in cylinder 1 so im guesing this is where the water is going, its also brought up the engine management light detecting 'general catalyst failure' which we assume is due to water/steam passing over the 02 sensors and giving faulty readings
as the head gasket has not yet gone on the car we assume its on its way out so i have decided to change it tomorrow (as im going to scotland in 1 week with a car and trailer full) with the upgraded head gasket and with a rocker cover gasket too (ive already replaced the inlet manifold gasket with the green one)
is there any advice you guys have before i undertake the job tomorrow, i would like to get it done in one day regardless if im up all night as the car is heavily used therefore im lost without it
is there anything i should look out for?? anything that is normall forgotton or goes wrong when they are changed?? anything i should ensure i do when taking it apart to ensure a perfect rebuild and no odd bits left which ur sure came of the car about an hr ago haha
thankyou in advance
rovermatt is offline   Reply With Quote
Old 18-08-2008, 18:58   #2
ScottishRover
Car: MG ZS MKII 120+
Originally Posted by rovermatt View Post
hey
thankyou in advance
plenty of boxes with labels so you remember where each bolt and fitting came from.
tipex to mark things so you can remember where they came from.
plenty of patience, take your time, have plenty of breaks, try not get frustrated.
soak the exhaust manifold nuts in release oil tonight to make them a bit easier to remove if they are particularly rusty.
good luck.
ScottishRover is offline   Reply With Quote
Old 18-08-2008, 19:21   #3
1955diesel
Never forgotten
Car: Other Manufacturer. Previously - more Rovers than I care to remember.
How much coolant are you losing?
If it is leaking past the head gasket, it will show up in the oil or as an external leak. If it is leaking past the fire rings into the cylinders (as you seem to be suggesting) then combustion gas will also be coming back the other way into the cooling system. This shows itself on Rovers by causing air locks, lack of heater and rapid boiling. (see the diagnosis thread in the How Do I? section)
If the misfire is being caused by ingesting coolant, it may well still be caused by a leaking manifold gasket, even though you have changed it.
Perhaps more likely is a regular coolant leak (often very hard to trace) together with a misfire for another reason.
1955diesel is offline   Reply With Quote
Old 19-08-2008, 17:08   #4
rovermatt
Car: Rover 45
thanks for the replies
ive replaced the head gasket today with the 2 peice upgraded one and i checked the inlet manifold gasket when i took it of and all was clean
once i got the head back on i gave up for today as id been on it for about 7hrs
i do have to say, having air conditioning makes the job soo much harder as there are fliping air con pipes all over the place
i couldnt move the alternator at all either for some reason which made removing the heat shield a nightmare!
there maybe the possibility that the water is been lost from somewhere else but UltraVoilet liquid was added to the coolant and i could not see where (if so) it would be leaking from, either way, atleast the HG has now been changed, just need to replace the rocker cover gasket tomorow and fix the cover to the head and then attach all electronics and pipes back together
ive drained all the oil too which is draining overnight just incase any water got in when we removed the head etc to make sure its all clean
i was loosing about one tank every 4 days id estimate, there was no oil in the coolant tank yet but apart from being thirsty thers nothing showing the HG has yet gone so im hoping iv noticed it when its starting to go which has enabled me to change the HG before doing much damage
ohh and it gets hot much faster lately, after about 5 mins (if that) the temp is half way up the needle which is normal temp, however, it NEVER overheats
lets hope for the best
Old 20-08-2008, 09:40   #5
langleys
Car: MG TF
Your one sounds exactly like mine was. I was losing a whole tank of coolant every 20 miles or so. Mine also had a slight misfire. I changed the HG on mine but even now I dont think it was that. I still, to this day, think the inlet manifold gasket was at fault. I also added UV dye to the coolant and it did not show up anywhere and I suspect my water was coming out of the exhaust because when I changed a section of the exhaust there was a fair bit of water settled in there which did have UV dye in.
langleys is offline   Reply With Quote
Old 20-08-2008, 14:32   #6
rovermatt
Car: Rover 45
well thanks to you all for your replies
i finished the HG today and it fired up first time, couldnt have been happier
Old 20-08-2008, 14:34   #7
rovermatt
Car: Rover 45
the only prob i had was that the revs wernt settling down but this was due to me forgetting to connect the purge valve which was soon rectified
im just hoping that the water problem isnt still present
Old 24-08-2008, 11:50   #8
EHO681N
Car: Rover 45
Good job on the head gasket - please read my post of today 24/08/08 re need to initialise the throttle if the throttle position sensor is disturbed - maybe this is the cause of revs not settling down
EHO681N is offline   Reply With Quote
Old 24-08-2008, 16:19   #9
rovermatt
Car: Rover 45
thanks for the reply
the revs wernt settling down due to me forgetting to attach the purge valve hose by mistake, soon rectified this though
many thanks, matt
You may not post replies
Head Gasket Change. Need Advice V8Tuning Rover 800 4 18-01-2008 11:41
Head Gasket change need advice on timing? Ste MG ZR / Rover 25, 200 & Streetwise 14 30-11-2007 21:42
Rover 45 dead engine post Head Gasket Change TB3 MG ZS / Rover 45 & 400 11 05-11-2007 17:11
Big Problems post Head Gasket change on Rover 45 TB3 MG ZS / Rover 45 & 400 3 05-11-2007 13:33
head gasket change advice evil genius MG ZR / Rover 25, 200 & Streetwise 0 09-04-2007 19:09
