Fault code reader - MG-Rover.org Forums
Old 05-09-2008, 16:58   #1
daveperce
Car: 2000 2.5 V6 Conn
Fault code reader
Can anyone suggest where I can get hold of a fault code reader/diagnostic tool for my 1999/2000 75 2.5 V6 and how much I could expect to pay for it? Cheers.
daveperce is offline   Reply With Quote
Old 05-09-2008, 17:28   #2
veeeight
Car: MG ZS
That's slightly tricky, as you car doesn't fully comply with the 2001 OBDII/EOBD2 legislation - but having said that, it's quite possible/probably that you will be able to get a few sensor readings, fault codes etc. off it.
You need to decide if you want to go down the laptop/interface route, or the handheld route.
If laptop route, have a look at any ELM327 based systems, for example, from Gendan, or ElmScan5 (beware there are many many many ELM327 fakes on ebay).
If handheld route, something like the U581 device is ok.
The above will cost you less than 80 quid.
Thats assuming you don't want to go down the Omitec T4 route.....
veeeight is offline   Reply With Quote
Old 05-09-2008, 18:05   #3
daveperce
'Scuse my ignorance veeeight...but what are the dis/advantages of a laptop over a handheld and visa-versa
Old 05-09-2008, 18:56   #4
T-Cut
Have a read on Rover Ron's website: http://tuning-diesels.com/Eobd/eobd2.htm
His CR2 and CR2 code scanners are excellent value.
TC
T-Cut is offline   Reply With Quote
Old 05-09-2008, 19:31   #5
veeeight
Car: MG ZS
Personal preference, plus some limitations.
The geek in me likes the laptop screen to produce graphs etc., which a handheld would not be able to do, on it's small and limited LCD screen.
edit: RoverRon's CR2 is a U581 device
You may not post replies
Fault Code Reader dirtyharry MG ZS / Rover 45 & 400 2 22-08-2008 23:56
Fault Code reader rangerman77 Diesel Forum! 4 22-07-2008 13:36
fault code reader Petevick MGF and MGTF (Sponsored by MGF Mania) 21 05-08-2007 21:33
Fault code reader Rollover MG ZT / Rover 75 (Sponsored by Rimmer Bros) 17 20-03-2007 09:01
Fault code reader Mike T MG ZR / Rover 25, 200 & Streetwise 1 16-08-2006 21:14
