clio immobiliser bypass?? - MG-Rover.org Forums
Old 06-09-2008, 11:32   #1
farmerrob2000
hey, have a 1996 metal-winged clio here, when i connect the Positive lead to the battery the speakers "thump", then you get in and have to lock and unlock the doors to get the immobiliser deactivated to allow you to start the car. the battery drains in around 2 days and i believe something is live, is it possible to remove a fuse or something to bypass the immobiliser to rule this out??
help very much appreciated.
farmerrob2000 is offline   Reply With Quote
Old 06-09-2008, 16:07   #2
Mostin6556
Car: 03 MG ZR (for Sale) X-Power Grey51 MG ZT 190 Blue
Hmmm if it's the factory imboiliser then i doubt it's this (also only way of deactivating it is through you kind yet expensive friends at renault had a 19 16v that the alarm had to be deactivated with a code put through the throttle pedal and one of the stalks which renault won't give you and even charge for the phone call to france to get the code (not heard of e-mail yet the french).
when you say the spreakers thump do you mean the stereo speakers. If so then thats your clue. take the fuse to the stereo out. Do you have things like a sub and amp in there if so check these are being switched on by the stereo and not permently on.
Also is the battery topped up and in good condition? use a multi meter and check what current is being drained when the car is switched off.
Mostin6556 is offline   Reply With Quote
Old 06-09-2008, 16:08   #3
Dr Dave
Administrator
Dr Dave's Avatar
Car: 2006 330d M Sport
Code put in via the throttle pedal?
__________________
Dr Dave is offline   Reply With Quote
You may not post replies
Immobiliser bypass ? Liamspiers Others 26 17-04-2011 21:52
Immobiliser bypass bandit600 Diesel Forum! 22 01-12-2008 20:46
Immobiliser Bypass on the R8 Rovers? Falcon_II 'R8' Rovers (aka Wedges!!) 7 22-02-2007 21:34
Passion And Dynamism In The Second New Clio Campaign With “Clio Renaultsport 197" Ian Other Motoring Chat 7 16-11-2006 17:36
alarm/immobiliser bypass adamh Metro / Rover 100 2 13-07-2006 21:56
