Cannot Change gear. - MG-Rover.org Forums
Old 12-09-2008, 12:02   #1
dab06
Car: MGF
Send a message via Yahoo to dab06 Send a message via Skype™ to dab06
Cannot Change gear.
Hi i have looked back a few pages but couldn't see any thing relevant.
I have a Zt 120 1.8i about 18k on the clock. last night I noticed that I couldn't select 1st or Reverse without switching the engine off. Once the engine was off I could select first, then once got going I could select 2nd and third but at a struggle.
Any ideas what could be causing this as when the Engine is off and the clutch is depressed it will select the required gear.
Don
dab06 is offline   Reply With Quote
Old 12-09-2008, 12:28   #2
marley
Car: 75 Conn. S.E. CDTI
As the clutch is alll hydraulics it sounds like a master or slave cylinder (or maybe both!).I s thr carpet footwell (under clutch pedal) wet?. If so probably yor master cylinder!
marley is offline   Reply With Quote
Old 12-09-2008, 13:20   #3
dab06
Car: MGF
marley Thanks. Ill have a look tonight. Thanks for the prompt response.
Old 12-09-2008, 19:39   #4
drunker50
Car: Rover 75
gearbox problem
Help!!! i have a r75 2.5 v6 auto with 46k on it, today it broke down, it's a gearbox problem, i cannot get any gears, if i put it in drive nothing happens it just revs has if it in neutral and the same happens with reverse 2,3,4 gears.
drunker50 is offline   Reply With Quote
Old 12-09-2008, 20:30   #5
kev25v6
Car: 1.4il 2001
Look down next to your battery tray, towards the gearbox (its a small gap). You will see a coolant pipe, make sure this is fastened to the battery box. If not, it drops onto the gear selector and wont let you select gears. Tie the hose back up and the gears will be sorted.
kev25v6 is offline   Reply With Quote
Old 12-09-2008, 20:49   #6
Martyn P
Never forgotten
Car: Rover 75 2001 2.5V6 Connie SE Tourer
Hi Dab06
Very low mileage for clutch problem, assume from your moniker car is 06 model
You should always be able to select any gear when engine is not running
Fact that you are having trouble with engine running indicates that clutch plate is not fully being freed off from flywheel when clutch depressed.
Question is why
Defect in hydraulics, clutch slave or master cylinder, question, does clutch pedal start to release clutch long before pedal is fully depressed as it should, if clutch only starts to operate halfway down or more, suspect system short of hydraulic fluid.
Defective clutch diaphram plate, fingers overheated & lost their tension due to driving with foot always resting on clutch pedal, so clutch overheats & friction plate rapidly wears out.
perhaps others can think of possible reasons for early clutch failure.
Gearchange linkage problem?
M
Martyn P is offline   Reply With Quote
Old 12-09-2008, 21:13   #7
drunker50
Car: Rover 75
Hi kev and many thanks for your quick response, i don't have a problem putting it into gear, the gear stick moves fine but when it's in the drive position it just revs similar to how a manual would with a completely worn out clutch.
Old 12-09-2008, 21:20   #8
T-Cut
Originally Posted by drunker50 View Post
- - - it just revs similar to how a manual would with a completely worn out clutch.
Sounds like a hydraulics problem to me. Have you checked/replaced the autobox fluid? Is it the specified grade?
TC
T-Cut is online now   Reply With Quote
Old 12-09-2008, 21:35   #9
drunker50
Car: Rover 75
TC
Hi tc, i have had the car about 2 mnths and have not touched the gear oil altho the car came with a full service history, there was a line of oil behind and leading upto my car on the road which could be gearoil but but by the time i got the car home it was dark so could'nt check
Old 12-09-2008, 21:38   #10
Martyn P
Never forgotten
Hi,
Loathe to come in early as years since had an auto.
Tcuts response is exactly what I thought
"Cooked" an auto box oil seals in heavy summer traffic due to overheating fluid years ago, g/box had to be stripped & rebuilt
M
Old 12-09-2008, 21:52   #11
drunker50
Car: Rover 75
Originally Posted by Martyn Procter View Post
Hi,
M
mp, thanks for your response, i had driven the car about 1/2 mile then the prob occured.
Old 12-09-2008, 22:13   #12
David3807
Car: R75 Conn Se 2.5l Auto 2001 and R75 2.5 Conn SE Tourer Auto 2002
Hose to the auto fluid cooler has been known to split thus dropping all the fluid.
With a bit of luck replace hose and fluid and you might be ok if you havent driven very far.
When refilling important to use the right fluid and have it at the correct temp.
David3807 is offline   Reply With Quote
Old 12-09-2008, 22:34   #13
drunker50
Car: Rover 75
Many thanks dave, i will have a look tomorrow now, you don't know how much i apreciate your feedback guys, the gearbox was working wonderfully so i don't think it's anything mechanical, i will post back tomorrow.
Old 13-09-2008, 08:35   #14
drunker50
Car: Rover 75
David, T-cut, just had a look underneath the car and you guys were spot on, the hose has come of at the flange into the cooler and dumped all my gearoil, the problem occured when i went from drive to neutral and i only traveled about 1/2 mile before that went so hopefully there is no gearbox damage.
Old 15-09-2008, 19:48   #15
Dr Dave
Administrator
Dr Dave's Avatar
Car: 2006 330d M Sport
Wonderful result - hopefully with a cheap fix!
__________________
Dr Dave is offline   Reply With Quote
You may not post replies
Second Gear Change Mingkei MGF and MGTF (Sponsored by MGF Mania) 13 22-04-2008 21:39
Gear Change SCFC_Messiah MG ZR / Rover 25, 200 & Streetwise 2 16-03-2008 01:37
Gear Change Isn't Right! Deejay Allman MG ZR / Rover 25, 200 & Streetwise 6 04-05-2007 14:40
Rover 620Si - Gear and clutch oil change + spark plugs change dibun Rover 600 24 01-11-2006 21:24
Clonking when changing gear and sometimes difficult gear change 416 Others 2 28-06-2004 22:59
