#1 |
is back - in black
Location: North Cumbria Car: MGF mk2 Freestyle 1.8mpi 16" wheels
FREE! Heated windscreen washers
Hi again,
While I had the washer bottle moved during my radiator change, I noticed how long the washer feed pipe is and it gave me an idea. ![]() If I lengthened the pipe sufficiently to be able to coil it around the radiator inlet hose, I would have a heat exchanger. In theory, when the inlet coolant heated up, it would pass heat to the washer fluid as it passed through my makeshift heat exchanger. So, I spliced in about two feet extra and formed about ten coils around the coolant hose. I had some pipe insulation the right bore to enclose the washer pipe from the exchanger to the jets, and I covered the 'exchanger' in insulating tape, and here it is. ![]() I know, Heath Robinson lives! Thing is, it works! David ps My washer bottle had nasty filamentous black gunge growing in it, Urgh! So I took the opportunity to give it a good clean out as well. |
#3 |
is back - in black
Update,
It may be a placebo effect but the warmer washer fluid seems to clear the flies and bird**** more easily. David Last edited by Aiketgate; 20-09-2008 at 20:02. |
#4 |
regained interest
I was going to wait until this was tested in frosty weather before adding a link to my site, but with the added advantage, I may add it any way
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#5 | |
is back - in black
It did do the job on cold, frosty days back then, when cold was really cold, not like nowadays with this global warming. Youth of today don't know what cold is! I remember walking to school through snow in 1963, week in/week out. It was so bitterly cold, my nose fell off, but tell the young'uns and do they believe you? No! No namby-pamby central heating or double glazing in them days. Mam had to burn three of my brothers just to keep the rest of us warm. ![]() Err Sorry........ Got sidetracked there for a minute! David |
#6 |
I think there might be a one way valve nearer the "T" piece?
If there is, why not remove it in the winter - 2 advantages, less to freeze up and when it does come through, it might be warm (when the engine is warmed up!!) |
#7 |
Noone ever reads this bit
Thats bloody impressive! Absolutely no use to me whatsoever, but impressive nonetheless
__________________
1998 MGF 1.8i - Solar Red ![]() Stainless roll hoops & nipples, alloy knobage, 52mm alloy throttle body, lowered to 300mm, Viper Induction, Toyo R1R's, MS Slick Shift, shift light, TT Mk4, stainless decat. Member of MG Car Club of Queensland http://www.artxdesign.com.au/hillclimb.gif |
#8 | |
is back - in black
AFAIAC, the disadvantage with removing it is that with all that extra piping it could be a while before the fluid gets to the jets, plus you wouldn't have any fluid in the exchanger getting nice and warm. David |
#9 | |
is back - in black
But I thought you had a lot of flies Down-under. Could help clearing the squashed bits off the screen, or do you have a row of corks across your windscreen? Only joshing!
#10 | |
regained interest
__________________
#11 | |
is back - in black
Think about it. David |
#12 | |
regained interest
__________________
#13 | |
regained interest
however, having thought about it, I still think it'd better without the valve, you'd still have water sitting in the exchanger as its lower than the water bottle (isn't it), so this water would be hot, and there would be no frozen water above it
__________________
#14 |
regained interest
I did this today, and just for anyone else who wants to do it, the inlet hose is the one on the left as your looking down into the wheel well.
__________________
#15 | |
is back - in black
Doesn't that depend on whether you have the PRT or not? I think without that, the inlet is the bottom (n/s) hose. ![]() David |
#16 | |
regained interest
I've know idea, I suppose its best to do what I did and run the engine till a pipe gets warm ![]() love the simely tho, better than
__________________
#17 | |
is back - in black
Smiley - care of Firefox smiley sidebar. |
#18 |
regained interest
I have that but never come across the dunno one
__________________
#19 |
I think that's fantastic! If I ever have any reason to strip from the front down as far as that i'll definately do it, well done!
#20 |
regained interest
ermmm, no need to get that excited Jon
__________________
| Bookmarks |
| Thread Tools | |
| Heated Washers? | frog218 | MG ZR / Rover 25, 200 & Streetwise | 3 | 01-12-2007 15:14 |
| Windscreen washers | Tenesmus | Rover 800 | 2 | 13-09-2006 16:42 |
| Heated washers | Carl | New XPart Online Shop Questions | 0 | 15-08-2006 12:00 |
| windscreen washers | icjoinery | MG ZT / Rover 75 | 2 | 30-05-2006 19:50 |
| Heated windscreen washers! | Chris T | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 20 | 04-10-2005 10:27 |
