No heat inside cabin of mg tf - MG-Rover.org Forums
Old 26-09-2008, 10:48   #1
Oafious
Car: MG TF
Hey there all, Wondered if anyone could help with a little temperature problem, as in, there is no heat whatsoever in the cabin of my tf160. Car also overheated for the first time the other day after standing in none moving traffic for over half an hour, I know I should have turned the negine off, but my little lad was watching a dvd at the time, and as all you parents on here will know, if they are quite leave them quite! lol. Well anyway, thanks in advance for any help.
Oafious is offline   Reply With Quote Quick reply to this message
Old 26-09-2008, 11:13   #2
D6 VYJ
Car: MG NO MORE !!!
Oooooooo check you have water in the expansion tank. Possible HGF. Your DVD may have been a very costly experience.
D6 VYJ is offline   Reply With Quote Quick reply to this message
Old 26-09-2008, 11:50   #3
Aiketgate
Car: MGF mk2 Freestyle 1.8mpi 16" wheels
Shouldn't have overheated, no matter how long it sits ticking over. Check that your radiator fan is working. Check the fuse hasn't blown, it's in the underbonnet fuse box. If it's 15amp, change it to a 20 amp.
David
No heat in the cabin suggests an air lock in the heater pipes, you'll need to bleed the coolant system.
Hopefully you haven't done any damage.
And
Aiketgate is offline   Reply With Quote Quick reply to this message
Old 26-09-2008, 14:54   #4
Oafious
Car: MG TF
Fan working, when I said the car had overheated, I was a little vague, the temperature gauge was on half, but steam was coming out of the engine bay, upon investigation, the expansion tank had nearly boiled down to nothing, the radiator fan had come on numerous times. I never realised a problem until it started to steam. as the temp gauge was reading half. Stupid car! lol. So how do I go about bleeding the coolant system? Big job?
Old 26-09-2008, 15:36   #5
1955diesel
Never forgotten
Car: Other Manufacturer. Previously - more Rovers than I care to remember.
Unless it has caused further damage, it sounds like you need a new filler cap. Yours is losing pressure and allowing the system to boil.
To bleed the system, read this - http://www.mgfcar.de/bleed/index.htm
What ever you do, don't drive it if the heater will not blow hot. You'll kill it!
1955diesel is offline   Reply With Quote Quick reply to this message
Old 26-09-2008, 16:18   #6
Tim.
Tim.'s Avatar
Car: MGF Trophy 160, MG ZS180
Wise words.
Tim. is offline   Reply With Quote Quick reply to this message
Old 26-09-2008, 18:48   #7
Oafious
Car: MG TF
Cheers folks! will attempt to blled tomo, haven't been driving it since, as was worried about the dreaded hgf! Cheers again.
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Noise inside cabin ZS120+ Any Ideas? daviddenise24 MG ZS / Rover 45 & 400 0 29-09-2008 10:42
exhaust smell inside cabin Mick S MG ZT / Rover 75 (Sponsored by Rimmer Bros) 10 21-02-2008 23:03
MG TF prototype inside Longbridge GazSuttonUK MGF and MGTF (Sponsored by MGFnTFBITZ) 37 09-03-2007 22:12
TF - running power from battery into cabin gazman99 MGF and MGTF (Sponsored by MGFnTFBITZ) 5 02-02-2006 14:24
Could a gear box cause heat damage inside a car? Mike12345 Others 5 02-04-2005 22:03
