Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-10-2008, 17:27   #1
CJJ
Mudslinger extraordinaire
CJJ's Avatar
Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1
Front Bumper Removal - How To
Well, as part of my hunt for coolant leaks I removed the front bumper to get access to the radiator etc.
As a few "How do I" type questions come up about bumper removal, I have taken a few photos.
The Front bumper is held in 4 main places.
Across the top of the grill (5 x Cross Head Screws)
Inside the wheel arch (2 x Cross Head Screws on each side)
Underneath the radiator (2 x Cross Headed Plastic Screws)
In the recesses each side of the number plate (2 x T50 Torx Screws)
I started by removing the 5 screws at the top.
Then I removed the front wheel arch liners. There are 2 metal cross head screws on the front edge of the arch and one on the rear edge.
and 3 pastic trim cross head screws at the back of the arch, holding the liner in place.
Once all of the liner screws are removed you can remove the liner. Start by peeling the liner from the front of the arch
Until the whole liner is released and it can be pulled out over the wheel.
Then remove the 4 cross headed screws (2 each side) holding the bumper to the wing.
If you have foglights, you can now disconnect the plugs to each light. Using thumb and forefinger squeeze (or push) the rear edges of the plug together to release it and pull towards you.
While you are under the car, there are 2 plastic trim screws that secure the underside of the bumper to a central strap. Remove these. You may need a right angled screwdriver or need to remove the plastic panel behind to gain access with a normal screwdriver.
Now lie something soft in front of the bumper in case it falls to prevent it getting scratched.
You can now remove the two Torx screws holding the bumper to the chassis.
__________________
CJJ is online now   Reply With Quote
Old 10-10-2008, 17:32   #2
CJJ
CJJ's Avatar
You can now carefully remove the bumper by pulling it towards you from the centre. Place the bumper somewhere where it cannot be damaged.
And that is the bumper removed.
Refitting will be the reverse, but do not tighten the bolts and screws untill you have fitted them all in place.
While the liners are out it is worth checking the inner wings. One point of concern is the rear lower part of the wing where it gets packed full of crud which will hold moisture in place and speed up corrosion in this area. Clean out and add waxoil or similar.
Hope this inspires you all to take your bumpers off.
Well worth doing just to check the state of your radiator and hoses.
I have since replaced the 2 screws that attach the bottom of the bumper to the strap with 2 bolts. The original plastic trim screws had pulled out and didn't seem up to the job.
__________________
Old 10-10-2008, 17:34   #3
Reaper
MG!
Reaper's Avatar
Car: MG ZT+ 135
Reaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud of
Brilliant Post; feed back given!
__________________
Reaper is offline   Reply With Quote
Old 10-10-2008, 17:36   #4
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
http://www.mgf-tf-central.co.uk/ht-e...tm#frontbumper top thread yet again CJJ
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 10-10-2008, 17:42   #5
Michiel.B
Michiel.B's Avatar
Car: MG TF 135 Trophy Blue RHD Originally on 03 plate
Michiel.B is just really nice. AwwMichiel.B is just really nice. AwwMichiel.B is just really nice. AwwMichiel.B is just really nice. AwwMichiel.B is just really nice. Aww
You wouldn't actually have to remove the liner but it does make life easier!
Great job CJJ
Michiel.B is offline   Reply With Quote
Old 10-10-2008, 17:50   #6
MoonManMike
Now with added Blue Flame
MoonManMike's Avatar
Car: MG TF 135 Sprint, Rover 25
MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.
I'm not sure if the TF is the same as the F (it does seem that removing and fitting is identical), but there is a small positional retaining lug on the front wings that the upper rim of the bumper slots into (near the rearmost part of the bumper). When you refit the bumper, it is an idea to put a couple of layers of masking tape (or similar) loosely round these lugs until you are ready to refit the bumper at the sides. This will avoid the possibility of scratching the top edge of the bumper
__________________
MoonManMike is offline   Reply With Quote
Old 10-10-2008, 18:06   #7
eagle1
Eagle Has Landed
eagle1's Avatar
Car: MGTF 160 VVC
eagle1 will become famous soon enough
Talking
I dont know if this is a TF addition, but when I took my bumper off a couple of months ago it was hanging off a strap from the centre of the bumper to just under the radiator. I had to replace it to get at the strap. So if you have a TF check for this first , and if you have one undo it.
eagle1 is offline   Reply With Quote
Old 10-10-2008, 18:44   #8
CJJ
CJJ's Avatar
Actually, that does remind me. There are two screws at the very bottom of the bumper, which, as you say, attach somewhere around the bottom of the rad.
Mine weren't attached, which is why I forgot about them. Will try to take some photos tomorrow when I finish off refitting the bumper.
__________________
Old 10-10-2008, 18:53   #9
sash
Richard
sash's Avatar
Car: BRG mg tf 120
sash will become famous soon enough
Great job CJJ a worth while job just to cleen the crud out with thanks
sash is offline   Reply With Quote
Old 10-10-2008, 20:40   #10
HarryB
Car: MGF
HarryB is a splendid one to beholdHarryB is a splendid one to beholdHarryB is a splendid one to beholdHarryB is a splendid one to beholdHarryB is a splendid one to beholdHarryB is a splendid one to beholdHarryB is a splendid one to beholdHarryB is a splendid one to behold
CJJ, don't stop there, I have a new radiator on its way up from the UK, as you have gone so far you may as well pop the radiator out so I will know the whole deal :-)
Nice "how to" by the way.
HarryB is offline   Reply With Quote
Old 10-10-2008, 20:43   #11
CJJ
CJJ's Avatar
If only you had said sooner. The bumper is nearly back on now.
Hope the rest helps.
__________________
Old 10-10-2008, 22:38   #12
Aiketgate
is back - in black
Aiketgate's Avatar
Car: MGF mk2 Freestyle 1.8mpi 16" wheels
Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.
Try reading this.
http://forums.mg-rover.org/showthrea...or+replacement
David
__________________
NORTH LAKES RUN September 11th
Aiketgate is offline   Reply With Quote
Old 10-10-2008, 22:46   #13
Ralz
I ♥ internetz
Car: BMW 3 series
Ralz has a brilliant futureRalz has a brilliant futureRalz has a brilliant futureRalz has a brilliant futureRalz has a brilliant futureRalz has a brilliant futureRalz has a brilliant futureRalz has a brilliant futureRalz has a brilliant futureRalz has a brilliant futureRalz has a brilliant future
Send a message via MSN to Ralz
Excellent guide mate, if I ever have to take the bumper off the TF I will refer to this thread.
Ralz is offline   Reply With Quote
Old 11-10-2008, 10:03   #14
HarryB
Car: MGF
Originally Posted by Aiketgate View Post
Ah, many thanks there, you saved me a lot of work there, I was so sure the bumper had to come off in order to change the radiators. I take it it is pretty much the same even with a car that has AC, just less room to play with.....
Old 11-10-2008, 11:19   #15
Fast Jan
is trying...
Fast Jan's Avatar
Car: TF 160
Fast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these parts
Surpassed yourself again CJJ - another top how to
You'll be running out of space for all those rep boxes soon
__________________
Experience is a journey, not a destination
For Sale: **17" wheels & Toyo tyres**
Fast Jan is offline   Reply With Quote
Old 11-10-2008, 11:21   #16
MikeKnight
Car: MG TF160
MikeKnight will become famous soon enough
Send a message via MSN to MikeKnight
Mine weren't attached.
Mine were and I could NOT get the buggers off, so had to leave it hanging while I worked stooped over to get to the inside. Grumble grumble.
Also.. ouch.. and I thought my rims were bad. Urge to clean your car and rust treat your rims.. rising. Why am I such a perfectionist.
MikeKnight is online now   Reply With Quote
Old 11-10-2008, 11:28   #17
Michiel.B
Michiel.B's Avatar
I had the same problem but a good pull did the trick...
Old 12-10-2008, 00:42   #18
CJJ
CJJ's Avatar
I have added some pictures of the lower strap.
__________________
Old 07-03-2009, 06:25   #19
khachim
Car: MG TF
khachim is up and running. Hey we all have to start somewhere.
Hi CJJ,
thats what I was looking for. Thanks.
Achim
khachim is offline   Reply With Quote
Old 07-03-2009, 08:02   #20
Gos
BLACK BEAUTY
Gos's Avatar
Car: MG TF Raven Black Sunstorm
Gos has much to be proud ofGos has much to be proud ofGos has much to be proud ofGos has much to be proud ofGos has much to be proud ofGos has much to be proud ofGos has much to be proud ofGos has much to be proud of
Great stuff thanks a bunch!
defo deserve some rep for that.
__________________
Brighton bunny run video link;http://www.youtube.com/watch?v=FBKSpWJlGjE
Gos is offline   Reply With Quote
Tags
f/tf how to, how to
You may not post replies
Front Bumper Removal RICH2508 MGF and MGTF (Sponsored by MG Rover Parts Ltd) 3 07-05-2007 11:50
removal of front bumper??? johnny200vi MG ZR / Rover 25, 200 & Streetwise 5 25-03-2007 17:45
Front bumper removal marts66 MG ZS / Rover 45 & 400 5 04-01-2007 09:23
front bumper removal(help please) liam 218 coupe Others 1 21-08-2006 17:43
front bumper removal help rover dude Others 3 01-03-2006 19:15
Terms and conditions of use
