how to: adjust clutch pedal height - MG-Rover.org Forums
Old 17-10-2008, 12:52   #1
Freedrider
Trader Supporter
Freedrider's Avatar
Car: MG ZR 2.0L TD
Thumbs down how to: adjust clutch pedal height
hey, i thought I might as well put a simple 'how to' for adjusting the clutch pedal height as mine was ridiculously high...
There is a 10mm bolt that needs to be tightened to bring the pedal down (arrowed in red). It helps to push the pedal down with one hand and feel up there and slip on a 10mm wrachet socket. It requires quite a lot of tightening before it even starts to adjust the pedal angle....
how this helps someone out there!
Freedrider is offline   Reply With Quote Quick reply to this message
Old 17-10-2008, 12:56   #2
Skibbz214
Car: Rover 214i 16v BRG ;)
Sorry to be a bubble burster but this guides been made before!
Skibbz214 is offline   Reply With Quote Quick reply to this message
Old 17-10-2008, 12:59   #3
Freedrider
Trader Supporter
Freedrider's Avatar
Car: MG ZR 2.0L TD
<bubble bursted>
Old 17-10-2008, 13:09   #4
great_kahn
Car: Focus
Well i found i useful! +1. How did you bend up there with the ratchet, you must be more flexible than me.
great_kahn is offline   Reply With Quote Quick reply to this message
Old 17-10-2008, 13:15   #5
Freedrider
Trader Supporter
Freedrider's Avatar
Car: MG ZR 2.0L TD
well i have heard horror stories of small children being made to climb up into the pedal assembly area to tighten those bolts with very little pay...
but dont worry if you cant afford one, simply lie on the ground upper body in the foot well and you should be able to reach up in there, using other hand to push down the clutch pedal....
Old 17-10-2008, 13:21   #6
Skibbz214
This is how I did mine Feet either side of the headrest, shoes off of course.
Also what I needed to do when fitting my central locking to the 5AS.
Old 17-10-2008, 13:24   #7
great_kahn
Car: Focus
sod that, im rounding up some orphans
Old 17-10-2008, 13:28   #8
Freedrider
Trader Supporter
Freedrider's Avatar
Car: MG ZR 2.0L TD
hahah!!
if you get any spare ones let me know as my exhaust needs sweeping out....
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Clutch pedal height johnthemilk MG ZS / Rover 45 & 400 9 12-03-2008 00:15
Clutch pedal height?? R118GTA MG ZS / Rover 45 & 400 1 05-01-2008 21:11
How to adjust clutch pedal on 45 gavp8 MG ZS / Rover 45 & 400 1 09-01-2007 14:53
clutch pedal height shugs Others 4 16-10-2005 23:10
Clutch Pedal Height.??? gibby5764 Others 5 02-08-2005 21:22
