"How To" Adjust the boot light within the latch mechanism on 200/25/ZR/SW - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > How Do I - Answers To Common Problems.
Old 31-10-2008, 14:00   #1
HotTubRepairer
Moderator
Car: Astravan 165
Send a message via MSN to HotTubRepairer
Here's another little "How To" guide to a common problem.
If your boot light doesn't work when you open the hatchback this may be the answer to your problem...... but before you do this make sure that the bulb and the connections on the bulb holder are all ok.
Tools needed:
1x medium flat scredriver.
Step one:
Open the hatchback and at the bottom in the centre you'll see the locking mechanism covered by a plastic cover.
On the rear of the cover you'll see a small rectangular peg which holds the cover on, you can see it in the pic below.
Use the flat screwdriver to gently pull the cover away from the rectangular peg and then pull the cover down to remove it. Mine was a tight fit and I had to wiggle it slightly from side to side to remove it.
Once removed you'll see something like this. The arrow is pointing to the problem. This copper strip has bent out of position over time.
The easy way of bending it back into position is to use your screwdriver to close the mechanism (like it would be when the hatch has been shut). Insert the screwdriver into the mechanism and rotate it until it locks closed.
Now you can bend the copper strip, you need to bend it downwards in the direction of the arrow.
Don't bend it too far, this should be about enough for it to work.
Now press the silver button on the hatchback, the one that opens it and....... hey presto the contact should be made and the light should be on.
Now all you need to do is slide the plastic cover back over the locking mechanism and you're all done.
I hope that this little guide helps someone out and apologies for the poor pictures, the camera was on the wrong setting. Any questions please post them on this thread or pm me.
Thanks,
Ian.
P.S: If your mechanism is making a good contact your problem might be due to a wiring fault, this is usually where the wiring enters the hatchback near the hinge. My wiring is begining to become damaged with the opening and closing of the boot so this will probably be the next "How To" unless it has already been done.
HotTubRepairer is offline   Reply With Quote
Old 31-10-2008, 15:00   #2
Richy
Uncomfortably Karabaraba!
Car: R25
You my friend are a legend. Rep for you.
Richy is offline   Reply With Quote
Old 31-10-2008, 15:08   #3
HotTubRepairer
Moderator
Car: Astravan 165
No problem mate, my pleasure. Let me know how you get on.
Old 31-10-2008, 15:44   #4
Richy
Car: R25
Sorted mate give yourself a pat on the back from me!
Old 31-10-2008, 15:58   #5
HotTubRepairer
Moderator
Car: Astravan 165
I'll just wait for you t buy me a beer.
Glad that you got it sorted mate. Was the guide ok or does anything need changing, adding or rewording to make it easier to understand?
Old 31-10-2008, 17:08   #6
Richy
Car: R25
Made perfect sense mate. Job well done!
Old 31-10-2008, 17:54   #7
ROVER-25X
MERSEYSIDE MEET FOUNDER
ROVER-25X's Avatar
Car: 25X 200X MGF-X6 400X Rep:■■■■■□□□□□
Great guide mate, as always, them scales are top heavy now PMSL !!!
__________________
The MAY MERSEYSIDE MEET & TUNNEL RUN 8 - 05/05/13
MG-ROVER - MERSEYSIDE facebook PAGE
The 25X Custom Engine Build Thread
QUOTE of the MONTH:
Originally Posted by Stu View Post
Keep trying new things everyone, its the only way the community learns
ROVER-25X is offline   Reply With Quote
Old 31-10-2008, 20:01   #8
HotTubRepairer
Moderator
Car: Astravan 165
Thanks mate.
Yeah the scales have been pressed a few times now.... I must be doing something right.
Old 26-12-2008, 11:13   #9
alan carter
Hi i had this problum as well your guide was 100% thanks
alan carter is offline   Reply With Quote
Old 26-12-2008, 11:51   #10
eddiesolo
Car: MAZDA BONGO!
Top guide.
Have to spread some love around first, before giving it to you...
But you have my respect.
Si
eddiesolo is offline   Reply With Quote
Old 29-12-2008, 16:31   #11
Dave882
Car: MG ZT and Rover 25 Impression
Boot warning light
Thank you for this information, excellent help.
My problem is slightly different. The boot warning light is staying on but the boot is closed properly. The boot used to pop open on bumps but I have had the boot lock reassembled a year or two ago and have no further problems with this.
Recently, however, the boot warning light remains on and on checking the boot I have noticed the boot light remains on even when closed. Is it possible that my problem is the reverse to the light not coming on? Should I adjust the contact the other way?
With thanks.
Dave882 is offline   Reply With Quote
Old 30-12-2008, 11:57   #12
HotTubRepairer
Moderator
Car: Astravan 165
With thanks.
It would be worth checking, use my pictures for reference when you have a look and if you're unsure post a pic of your mechanism. Also check the wiring where it enters the hatch near the hinge for any possible problems. Apologies for the short reply, I'm using a mobile phone to access the forum and it's a right pain.
Old 02-01-2009, 09:55   #13
Dave882
Thank you, I will have a look as mentioned and post a reply.
Old 06-01-2009, 13:36   #14
Dave882
I removed the cover and found a 1 inch brass bolt loose in the lock. I cannot see any which would suggest a missing bolt and can only assume that the bolt has been left in by other means, possibly when the garage rebuilt the lock. The boot light is off now and it will just be a case of following your instructions.
I could not repair the light this time as the 25 broke down. It is running again but the revs on idel are too high.
Once again thanks
Old 07-01-2009, 17:17   #15
HotTubRepairer
Moderator
Car: Astravan 165
No problem Dave, I'm glad that parts of the guide are useful for you, it makes the time spent making the guides seem much more worthwhile. If you need any help with anything you can contact me via pm. Cheers, Ian.
Old 19-01-2009, 09:14   #16
Waddum
Car: MG ZR
Simple and easy to follow so cheers for that - was really bugging me not having a light in the boot.
Waddum is offline   Reply With Quote
Old 19-01-2009, 11:41   #17
HotTubRepairer
Moderator
Car: Astravan 165
It bugged me for ages too. I'm glad that you can understand it ok, it's sometimes not easy putting actions into words.
Cheers,
Ian.
Old 23-01-2009, 11:23   #18
jabin88
Talking
Hi,
worked great the bending costs some time but the rest is easy. You said to lock it first bij using the screwdriver before bending it but you forgot to mention how to unlock it in order to lock the boot when ready.
But other than that THANKYOU!!!
jabin88 is offline   Reply With Quote
Old 23-01-2009, 11:36   #19
HotTubRepairer
Moderator
Car: Astravan 165
Originally Posted by jabin88 View Post
Hi,
Yes I did.
Just above Picture #8:
Glad you got it sorted.
Old 23-01-2009, 16:02   #20
jabin88
Im sorry your right i just pushed the block on the right up that also solved the problem.
You may not post replies
"How To" Tighten the steering column height adjuster. 200/25/ZR/SW HotTubRepairer How Do I - Answers To Common Problems. 8 10-06-2012 11:38
Rover 25 / MG ZR "How To" Replace 200/25/ZR seats. HotTubRepairer How Do I - Answers To Common Problems. 54 17-01-2012 22:43
200 / 25 / ZR parcel shelf "clip" empsburna For Sale 12 07-07-2006 20:26
Boot light and "boot open" indicator - R200 Vi garlum MG ZR / Rover 25, 200 & Streetwise 4 14-04-2006 18:19
New "lexus" Rear Tailights for 200/25/ZR dave0109 MG/R Modification & Tuning 21 10-11-2003 16:19
