rear brake drum removal help!!! - MG-Rover.org Forums
Old 17-11-2008, 15:21   #1
pwuk26
Car: Classic Rover
Angry rear brake drum removal help!!!
my 214 has failed its mot on a few items one of which is rear parking brake efficiency below requirments. i have sorted most of the problems myself thanks to all your help but i cannot remove the rear brake drum to have a look inside. i had trouble gettin the screws out but got em eventually but the drum will not budge. i have tried using a screwdriver through the hole in the back plate but not really sure what i should be doing. any help would be great.
pwuk26 is offline   Reply With Quote Quick reply to this message
Old 17-11-2008, 15:57   #2
ferret9111
is there a nice big bolt in the middle if so you need to remove it
ferret9111 is offline   Reply With Quote Quick reply to this message
Old 17-11-2008, 16:46   #3
bob.s
Car: MG ZR
sounds like the drum is seized onto the shoes. Try pulling on the handbrake hard then release it. assuming the retaining screws are out on the face of the drum, give the drum a few hard smacks with a wooden mallet or if you have to a steel one, it should free off the shoes from the drums. It is not uncommon for this to happen.
bob.s is offline   Reply With Quote Quick reply to this message
Old 17-11-2008, 17:10   #4
pwuk26
Car: Classic Rover
mmmmm
would the bolt have a cover over it? there is something in the centre which i did try to get off but was worried i might cause more damage. I tried the mallot approch but no luck. will have a look to see if i can get what i think may be a cover off tomoz. cheers for help will let you know how i get on.
Old 18-11-2008, 16:32   #5
pwuk26
Car: Classic Rover
Thumbs up joy
There is a nice big bolt slap bang in the middle of it but my problem now is how do i get the ruddy thing owf? Any ideas as to what size rench i may need to get this thing movin? Cant beleive this thing was starin me in the face the whole time.I been at the bugger for two days eeek. Cheers for the info. Once again the forum saves the day
Old 18-11-2008, 17:23   #6
g.warren216si
Car: rover 216 (for sale) mk4 golf gti
it should be about a 32mm, just get a socket and a bar to get it off. when its off be carefull as the wheel bearings may fall out, the last thing you want is dirt in them. also when you have done this if the drums dont just pull off you will have to smack them off with a hammer, be carefull though as the lip on the inner edge of the drum can sometimes pull off all the inner workings, and if you dont no how they go back it can be a nightmare. if you need anymore help just ask . gaz
g.warren216si is offline   Reply With Quote Quick reply to this message
Old 18-11-2008, 17:24   #7
g.warren216si
also forgot to add that when you put the big nut back on dont over tighten it, this will kill your wheel bearing
Old 18-11-2008, 17:59   #8
SnapdragonGT
Car: Impreza Turbo, Focus diesel Estate, Rover 25 1.4.
You don't have to remove the hub nut on these, just undo the two screws on the drum centre , if they're too badly wrecked after, you don't need to replace them, they're not really necessary
If the drum won't budge (assuming you've released the handbrake before you try to remove it!) then some judicious levering at various opposite sides of the drum (eg nine o'clock and three o'clock) will get it off eventually. If the handbrake cable has been adjusted too tightly, this may also be holding the shoes close to the drum, back the adjuster off in the rear of the centre console if that's the case.
The reason why you're probably experiencing difficulty is due to the way the drum wears, it's a not a fault, all that happens is the outer edge of the drum doesn't get any contact with the linings, and eventually over the miles a slight 'lip' developes. as you try to pull the drum off, the linings catch on this 'lip', this is what makes removing the drum so difficult, so much more so on vehicles with auto adjusters within the rear drums. Removing the centre hub nut will not help with the linings catching the drum.
SnapdragonGT is offline   Reply With Quote Quick reply to this message
Old 19-11-2008, 11:27   #9
pwuk26
Car: Classic Rover
Unhappy aaarrrrggggghhhh
well with a lot of pullin, bangin, hammerin and cursin finally got the bloody thing owf. good and bad news! the good news is brakes working fine. the bad news tho, the brake cable very rust and had seized. anyhows while trying to free it up it snapped. not what i wanted really. thinkin of gettin shut now as failed mot on quite a lot most of which ive sorted but still gonna cost more than its worth. thanks for all your help guys. will be sad to see it go but i think its for the best.
broken rear drum brake. danthebangerboy MG ZR / Rover 25, 200 & Streetwise 9 31-12-2008 13:39
Removal of Rear High Level Brake Light Snowball MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 07-07-2008 20:53
rear drum brake problem after fitting jay27 MG ZR / Rover 25, 200 & Streetwise 3 18-03-2007 20:46
brand new rear drum brake shoes for mgzr/25/45 jay27 For Sale 0 14-03-2007 03:59
rear drum brake question jay27 MG ZR / Rover 25, 200 & Streetwise 4 17-01-2007 19:13
