#1 |
Lower Rover 45 Saloon
Hi, been reading up on using ZS springs from a 120+ to lower my 45.
Trouble is some people suggest swapping over springs & shocks, other people suggest just springs, with top arms swapped over. Would it be as simple as finding a ZS 120+ and just removing the springs and swapping them onto my 45? I know for best handling etc i would be better off with the whole lot, springs, shocks etc, but just want a slight difference. So would just the springs from a ZS 120+ (hatchback) be ok to swap over onto the 45 Saloon? Cheers Kev |
| Sponsored Links | |||
Advertisement | |||
#2 |
its far more work if you just want to fit the springs.
fit the shocks and springs if you want an easier/cheaper job. |
#3 |
as above much easier to swap the whole lot over
#4 |
thanks for the replys.
So its just an unbolt / bolt in job if i swap over the springs and shocks from a ZS? Is there anything else i should think about? Cheers. |
#5 | |
but if yours is a petrol fit the MG ZS 120 set up. took around 2 hours,just have some wd40 handy,makes it easier |
#6 |
Alternitivley check out Koni STR-T kits. lowers by 40mm all round and will stiffen the ride up nicley
#7 |
#8 |
Moderator
#9 |
i have the STR-T kit fitted to my rover 400, i think im right when i say it will also fit the 45 and the ZS?
#10 |
Moderator
#11 |
Thats if you got koni money though,can be less expensive to fit the zs set up
| Bookmarks |
| Thread Tools | |
| Rover 45 TD saloon | samwilson1 | Wanted | 1 | 05-03-2008 08:51 |
| Rover 45 Saloon | georgiansoccer | MG ZS / Rover 45 & 400 | 36 | 01-02-2008 11:25 |
| Rover 45 saloon. | R.Fensome | MG ZS / Rover 45 & 400 | 2 | 24-11-2007 16:11 |
| Rover 45 1.8 Saloon Exhaust | bockers | MG ZS / Rover 45 & 400 | 2 | 12-05-2006 09:46 |
| 45 Saloon face lift and Civic Saloon | Alex_ukrover | MG / Rover Related Chat - up to 2005 | 3 | 21-10-2003 07:31 |
