MGTF Central locking not working - MG-Rover.org Forums
Old 08-12-2008, 08:51   #1
Bckent
Car: MG TF
Hi all
I have an issue with my new MGTF 04 plate, the central locking wont work, I press alarm button and lights flash but does not unlock the doors! When I use the car only one door unlocks, anyone got any ideas?
Ben
Bckent is offline   Reply With Quote Quick reply to this message
Old 08-12-2008, 09:01   #2
James C
Car: MG ZT 260 SE V8
Is it a 115? As if so they don't have CL (except on some of the special editions)
James C is offline   Reply With Quote Quick reply to this message
Old 08-12-2008, 09:38   #3
Reaper
Car: MG TF 160, Mini Countryman Diesel
What model and engine do you have in your TF?
Welcome to .org!
Reaper is offline   Reply With Quote Quick reply to this message
Old 08-12-2008, 11:49   #4
Bckent
Car: MG TF
Hi yes its a TF115 sunstorm, on the spec it says it does have CL with full closure alarm!
I have now got the central locking working off the drives side door key motor ceased but does not work on passengers side I know in previous model cars I have had that the central locking only works off the drivers side as this is the master unit. Is this the same with the MGTF? Alarm still not working tho with CL! Is there an interface unit? Could this be faulty?
Old 10-12-2008, 13:09   #5
Bckent
Car: MG TF
So any ideas people struggling with this one!
Old 10-12-2008, 13:46   #6
Petevick
check the lock in the door thats not working and make sure it is actually a c/l lock.
Petevick is offline   Reply With Quote Quick reply to this message
Old 11-12-2008, 11:27   #7
Storm
Car: MG TF
Yup, the door should NOT have a lock barrel for a key (if it came as standard) and if you look at the striker plate in the door it should NOT be white.
Bill
Storm is offline   Reply With Quote Quick reply to this message
Old 29-06-2014, 13:01   #8
Chris Dart
Car: MG TF
MG TF Central LOCKING
You are not alone. I've a very similar problem. My TF Sunstorm (03 Plate) the door locks sounded as if they only opened halfway , if I tried the Key it would jam in the lock. For a time I had to disconnect the battery then unlock the doors with the key. Now the drivers door will lock on the fob, but not unlock and the passenger door is permanently locked. Anyone have any ideas with this. I do not even know how to take off the door cover.
I'd appreciate any help.
Cheers,
Chris
Chris Dart is offline   Reply With Quote Quick reply to this message
Old 30-06-2014, 11:29   #9
pault39
Car: MG TF 135
Is the door switch broken ie the one that puts the light out on the dash. Broke one on my 416 years ago, it would only lock on key until fixed, don't think the alarm armed either.
pault39 is offline   Reply With Quote Quick reply to this message
Old 30-06-2014, 18:43   #10
davetech
Car: MGF
if the car has a lock barrel on either door, then it wont have cdl,....unless its got a after market cdl kit fitted, if the passenger door is blanked, then its got cdl
davetech is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Central locking half working..... guttris MGF and MGTF (Sponsored by MGFnTFBITZ) 3 15-11-2007 09:43
Remote Central Locking Not Working dazzawhipple MG ZS / Rover 45 & 400 4 07-09-2006 21:42
Central Locking MGTF HigginsH MGF and MGTF (Sponsored by MGFnTFBITZ) 15 08-06-2006 06:16
MGTF Central Locking de1 MGF and MGTF (Sponsored by MGFnTFBITZ) 2 14-01-2006 11:43
central locking not working what do I look for? rover2201 Others 4 19-12-2005 15:05
