#1 |
Location: Dresden Germany Car: Rover 75 2.5 Tourer, AC cobra replica 5.2L
KV6 2.5 VIS balance.
Hi forum boffins,
Can anyone explain specially the function of the VIS balance valve and what controls it, a diagram would be helpful. Does it work in unison with the power valve or does it have separate operating parameters? I ask this question because, before I take it apart and glue, screw, clean and resolder as advised on the forum, I would like to know what will be achieved. From the pictures I have found in the forum I more or less understand the power valve function. Terry |
#2 |
Car: MG ZTT
balance valve
Dont quote me but does "the balance valve spilts the chambers from 3 to 6 and then back to 3 for the final torque boost".
A diagram would be nice!!! |
#3 |
http://www.mgcars.org.uk/cgi-bin/gen...6variable.html
The inlet manifold chamber incorporates a Variable Intake System (VIS). The air flow from the throttle body feeds into a “Y” piece which separates into two secondary pipes. The secondary pipes feed into two main plenums, one for each bank of three cylinders. At the closed end of the plenums is a VIS balance valve, operated by an electrical motor. This valve enables the two plenums to be connected together. From the two plenums, the primary tract length to each cylinder is approximately 500mm. Each of these tracts has a side function, fitted with a VIS power valve and feeding into the short tract plenum, approximately 350mm from the cylinder head face. All of the VIS power valves are connected to a link rod which is operated by an electric motor.
#4 |
hijackers inc
Location: Sandy, Bedfordshire Car: Volvo C70 T5 GT-255bhp and 340 NM of torque!
I've got a VIS problem shroonie. No surge of power at the 3000rpm ish mark. Do you know which one needs replacing, or is it both??
Cheers.
__________________
Alex. (Transport Manager - hi jackers inc) |
#5 |
how do you know when you have a VIS motor fault ?
does the ecu light come on ? |
#6 |
Car: MG ZTT
No faults will flash up in the car only a code reading tool will show up that the power or the blance motors are not working.
If the car fells guttless then power valve has gone, but they can be repaired as long as the little motor has not burn out, being that it has to swim in oil from the breather system!!. |
#7 |
Car: MG ZTT
I so wish i had two grand to spend on the super charger for the kv6!!
| Bookmarks |
| Thread Tools | |
| Re-Vis Balance valve | basham | MG ZT / Rover 75 | 0 | 08-01-2008 13:58 |
| Balance VIS Motor Replacement | Tim. | MG ZS / Rover 45 & 400 | 3 | 28-10-2007 21:30 |
| sticky balance valve butterfly (vis) | cainey | MG ZS / Rover 45 & 400 | 0 | 21-02-2007 21:48 |
| balance vis valve question | cainey | MG ZS / Rover 45 & 400 | 5 | 10-02-2007 22:17 |
| vis motor - balance valve | garythesnail | MG ZS / Rover 45 & 400 | 4 | 21-01-2007 20:42 |
