Heater blowing cold then hot - MG-Rover.org Forums
Old 14-01-2009, 11:58   #1
TonyAKM
Car: Rover 45
Driving to work this morning it took ages for the heater to warm up, then when it did it blew cold when car slowed down and the temp guage fluctuates between mid guage and hot. Any ideas what maybe prob?
TonyAKM is offline   Reply With Quote
Old 14-01-2009, 14:52   #2
Aftershock
Car: MG ZS 120
The same happened to me the other morning then this morning had steam coming out of the header tank on my way to work. Im told i have a leaking radiator that is causing this so i would start there.
Aftershock is offline   Reply With Quote
Old 14-01-2009, 15:18   #3
creature
Car: MG ZS
along the same lines happened to me after heavy breaking heaters blew cold air whilst temperature guage showed hot. Ive been told its a sign of HG failure can anyone confirm this?
creature is offline   Reply With Quote
Old 14-01-2009, 15:33   #4
warwickswinger
warwickswinger's Avatar
Car: MG ZS 120+ & Suzuki TL-1000R
Air in the cooling system would be my guess.
It could be getting in for a variety of reasons, including but not limited to:
  • Split or perished rad hose
  • Holed radiator
  • Leaking gasket (check around the thermostat and water pump)
If you don't sort it then you'll get problems but just because the temperature guage has moved doesn't automatically mean the engine's broken or the head gasket's failed
I had an airlock in my heating system last week (the garage drained the cooling system and didn't refill it properly) so my heaters blew cold and the temperature guage climbed slightly. Bled the cooling system and hey-presto! Problem solved. Touch wood.
There wouldn't be any harm in looking for signs of oil in the water or water in the oil though. They're easy enough to check.
warwickswinger is offline   Reply With Quote
Old 27-01-2009, 13:50   #5
AcC8braman
Car: MG ZS
I had this problem, no water in the system = blown head = £1300 repair bill for new head etc!! boooo
AcC8braman is offline   Reply With Quote
Old 27-01-2009, 21:01   #6
Carl
One off a full set
Carl's Avatar
Car: MG ZS 180 MG ZT CDTi 135+ ,MGF 75th Anniversary, MG ZT 120+
Send a message via MSN to Carl Send a message via Skype™ to Carl
My dad had this type of problem on his 25v , new expansion tank cap solved it - they go faulty quiet often , so it an easy fix they are about £5 from rimmer bros
Carl is online now   Reply With Quote
You may not post replies
heater not blowing hot air!!! davidmgzr MG ZR / Rover 25, 200 & Streetwise 4 08-01-2009 13:05
Heater blowing hot and cold??? craigsrover MG ZS / Rover 45 & 400 15 19-09-2008 06:41
Heater Blowing Hot Villager MGF and MGTF (Sponsored by MGF Mania) 4 29-04-2008 14:41
Heater blowing out cold when set to hot? Ste MG ZR / Rover 25, 200 & Streetwise 15 23-12-2007 19:52
