#1 |
Repair of clutch master cylinder (with photos)
I am too tight to pay for a new master cylinder, so today I had a go at fitting new seals instead.
I bought AP Lockheed repair kit LK 11231 off ebay for about £8 including delivery. First, I removed the clevis pin from the top of the clutch pedal. There are no photos of this stage because it's done mostly by feel. Next, remove the plastic cover from under the bonnet. I had to give the plastic nuts a little help to come off: ![]() With that out of the way, it is easy to see the clutch master cylinder: ![]() Remove the pipe from the top, taking care to catch any drips: ![]() Remove the 2 bolts and lift the cylinder out of the bulkhead: ![]() Peel back the rubber boot and remove the circlip. The cylinder spills its guts: ![]() The cylinder in bits: ![]() Old seals removed: ![]() New seals fitted using some brake fluid to lubricate: ![]() Putting things back together with some red rubber grease. The cylinder body was cleaned using alcohol wipes and the reservoir had some brake fluid poured in and then I gave it a good shake before emptying it out: ![]() The circlip is back in. Just need to push the rubber boot back on and fit it to the car: ![]() Put it back in, fill the reservoir and then bleed using the bleed point on the slave cylinder. Total time about 4 hours. Problems: My circlip pliers were too large to fit the holes in the circlip. I made do with a pair of needle-nose pliers. The cylinder insides were different to the diagram in my repair kit. Instead of easily coming apart, it was all one unit so I had to stretch the seals over the length of the shaft to get them on. Much swearing was required, but they went on. I've disturbed the brake light switch while messing around in the footwell. I'll have to reset that tomorrow. Link to album of all images Last edited by ourmark; 06-03-2009 at 16:21. Reason: Update image links |
#2 |
Hmmm... not all of the photos are showing. Gonna try uploading them somewhere else.
#4 |
The futures orange
Location: Fife Scotland Car: MGF VVC 75th ANNIVERSARY & TF LE500
Good work there, an excellent how to
#5 |
is on the up!
You make it sound so easy to remove it from the car
That rear bolt is a right pain in the arse!!!Good job I've got the one I took of my car a few weeks back to replace the seals in, must get round to it one day
__________________
Enclosed K&N, 52mm TB, Miltek, AP fast road clutch, WON Streetblaster 150i kit, Additional brake servo bracket, MS front 280mm brakes (Black Diamond drilled & grooved discs, Predator pads), 280mm rear brakes (Greenstuff pads), SS Braided brake hoses, TF solid subframe mounts, Polybushed, Lowering pins, Gaz adjustable shocks, MS bell crank, SEAT Leon front splitter, Alpine ICE, MKII center console, Colour coded interior
Has hydragas pump - will travel ![]() |
#6 |
regained interest
excellent how to. Just one small point, you make reference to the 'slam panel' as being the plastic moulding at the back, its not, the slam panel is what the bonnet catch locks in at the front, the moulding has the grand name of an 'under bonnet cover'.
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#7 |
Thanks guys, and thanks for the correction, Pete. I've edited my post.
#10 |
Mad Norwegian.
Excellent job!
__________________
Front fogs, Trophy splitter, 17" TD wheels on Toyo T1R, AP brakes, black badges, 52 mm TB, TF airbox, decat, Daytona exhaust, Trophy lights, mk2 Tbar, TF steering rack. |
#11 |
Car: VVC
Hi
thanks for the nice tuto, but could you tell me why you have change it, what was the symptom on the clutch ? thanks |
#12 | |
First, the pedal felt slightly uneven, as if it was bouncing back at the top of the pedal travel. Second, the fluid was discoloured even though it had been replaced twice in recent months. So although the car was driveable, I thought it best to sort the master cylinder. Then I've done the whole lot and I can hopefully get another 50,000 miles out of it. One more thing to mention is that I'd replaced the clevis pins on both cylinders with stainless steel ones. Yesterday I was able to check them after 2,000 miles and they have no signs of wear. M8x16mm fits the slave cylinder and M8x20mm fits the master cylinder. If you want to use a washer, then you'll need to go one size bigger on each of these. I chose not to because where they are located, I'm more likely to drop a washer and lose it than I am to get it on to the pin. There isn't much rotation on these joints and therefore the R-clips don't suffer from not having a washer, IMO. |
#13 |
Just a little update now I've driven the car some more.
The clutch pedal feels very smooth. For some reason, I thought it might feel lighter but if anything it's got slightly heavier. But the odd "bouncy" feeling has gone so that's good. I haven't heard any squeaks from the pedal since doing this, either. Maybe it is too early to tell, as the squeak used to come and go, but if it's gone then that's really, really good. Very happy with the results from doing this work and I can't wait to do the brakes next. I'm planning a master cylinder rebuild along with braided hoses and new pads. |
#14 |
Car: Rover 75
where are the photos
i have same problem with the clutch...srry but i cant see your photos
#15 |
Images should display correctly now. Good luck with it!
| Bookmarks |
| Tags |
| clutch master cylinder, f/tf how to |
| Thread Tools | |
| clutch master cylinder | luddite | MG ZS / Rover 45 & 400 | 10 | 20-01-2009 18:10 |
| Clutch Master Cylinder | alex7127 | MG ZT / Rover 75 | 17 | 12-10-2008 22:34 |
| Clutch master cylinder | gotenks1321 | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 11 | 29-05-2008 12:52 |
| Clutch Master Cylinder | Rover Gonzo | MG ZT / Rover 75 | 8 | 10-03-2008 20:50 |
| clutch master cylinder | cookies | MG ZT / Rover 75 | 7 | 03-05-2006 18:58 |
